Creating a shared library that utilises OpenMP offloading
Hey there,
I am trying to create a shared library utilising OpenMP offloading and nvc++. Unfortunately, I ran into some trouble using the library.
Let’s consider the following files:
  • test_compute.cpp // does some computation with OpenMP offloading
  • test.cpp // has int main() and uses the computation
Creating the library works fine:
nvc++ -g -O3 -std=c++17 -fpic -mp=gpu -shared test_compute.cpp -o libtest_compute.so
Compiling and linking with test.cpp works also:
nvc++ -std=c++17 test.cpp -o test -L${PWD} -ltest_compute
However, when I execute the code, using OMP_TARGET_OFFLOAD=MANDATORY, I’ll get the following error:
$ LD_LIBRARY_PATH=${PWD}:$LD_LIBRARY_PATH OMP_TARGET_OFFLOAD=MANDATORY ./test
Fatal error: Could not run target region on device 0, execution terminated.
Aborted
When I add -mp=gpu to the compilation and linking of test.cpp:
nvc++ -std=c++17 -mp=gpu test.cpp -o test -L${PWD} -ltest_compute
everything works fine:
//some output
However, as I’d like to create a library that might be linked by any other program or compiler or even work as a Python module, specifying -mp=gpu is not a solution for me.
Is there any way to make the library “self-contained”, i.e. I do not need to add -mp=gpu while compiling test.cpp?
If needed, I can also provide some test files.
I am using NVHPC 21.5:
$ nvc++ --version
nvc++ 21.5-0 LLVM 64-bit target on x86-64 Linux -tp zen
NVIDIA Compilers and Tools
Copyright (c) 2021, NVIDIA CORPORATION.  All rights reserved.
Best,
Andreas
Hi Andreas,
Unfortunately, I don’t believe we have support for this when using OpenMP Target Offload as of yet. Though, I added an RFE (TPR #31121) and sent it to engineering to see what they can do.
Note that we do have this support in for OpenACC, so you may consider using it instead, at least until support can be added for OpenMP as well.
Example:
% cat test_compute.h
void addone(double * Arr, int sze);
% cat test_compute.cpp
#include "test_compute.h"
void addone(double * Arr, int sze) {
#pragma omp target teams distribute parallel for map(tofrom:Arr[0:sze])
#pragma acc parallel loop copy(Arr[0:sze])
for (int i=0; i<sze; ++i) {
Arr[i]+=1.0;
% cat test.cpp
#include <iostream>
#include <cstdlib>
int main () {
int sze = 1024;
double * Arr = new double[sze];
for (int i=0; i < sze; ++i) {
Arr[i] = i;
addone(Arr,sze);
for (int i=0; i < 10; ++i) {
std::cout << i << ": " << Arr[i] << std::endl;
% nvc++ -g -O3 -fpic -mp=gpu -shared test_compute.cpp -o libtest_compute.so
% export OMP_TARGET_OFFLOAD=MANDATORY
% g++ test.cpp -L. -ltest_compute -o test; ./test
Abort
% nvc++ test.cpp -L. -ltest_compute -o test; ./test
Abort
% nvc++ test.cpp -L. -ltest_compute -o test -mp=gpu; ./test
0: 1
1: 2
2: 3
3: 4
4: 5
5: 6
6: 7
7: 8
8: 9
9: 10
// Ok if using OpenACC:
% nvc++ -g -O3 -fpic -acc=gpu -shared test_compute.cpp -o libtest_compute.so
% export NV_ACC_TIME=1
% g++ test.cpp -L. -ltest_compute -o test ; ./test
0: 1
1: 2
2: 3
3: 4
4: 5
5: 6
6: 7
7: 8
8: 9
9: 10
Accelerator Kernel Timing data
test_compute.cpp
_Z6addonePdi NVIDIA devicenum=0
time(us): 49
3: compute region reached 1 time
3: kernel launched 1 time
grid: [8] block: [128]
device time(us): total=5 max=5 min=5 avg=5
elapsed time(us): total=360 max=360 min=360 avg=360
3: data region reached 2 times
3: data copyin transfers: 1
device time(us): total=23 max=23 min=23 avg=23
8: data copyout transfers: 1
device time(us): total=21 max=21 min=21 avg=21
Thanks for the fast reply. I’m not sure if we are going to look into OpenACC. However, thanks for the hint to the possibility of co usage.
Best,
Andreas
Hi Andreas,
Our team was able to add this support in the 22.5 release. I’ve confirmed that my simple tests work as expected, but please let us know if you see any issues when using it in you’re larger code.
-Mat
