Hi, I am trying to understand a concurrency behavior I observed with CUDA from Python/PyTorch.
I have a minimal setup with two Python threads in the same process:
- Thread A repeatedly performs a GPU-to-CPU copy into pageable host memory
- Thread B repeatedly launches a small CUDA kernel
In Nsight Systems, I observe that:
- Thread A is inside a pageable D2H path (
copy_to CPU) - At the same time, Thread B appears stuck in
cudaLaunchKernel - The long duration appears on the host API call
cudaLaunchKernel, not on the GPU kernel execution itself
So it looks like a D2H copy issued from one host thread is delaying another host thread’s kernel launch at the CUDA runtime/API level.
My questions are:
- Is this expected behavior for pageable D2H copies?
- Can pageable D2H introduce process-wide or context-wide serialization that delays
cudaLaunchKernelfrom another host thread? - Is this mainly due to:
- internal CUDA runtime locks,
- pageable-memory staging/synchronization,
- or something else?
By the way, I figured out that the simplest solution is to use pinned memory so that the copy is performed asynchronously. Below is a minimal PyTorch repro that also exports a trace:
import time
import threading
import torch
from torch.profiler import profile, ProfilerActivity
start_event = threading.Event()
stop_event = threading.Event()
def d2h_worker(src: torch.Tensor):
Thread A:
Repeatedly perform GPU -> CPU copies into pageable host memory.
start_event.wait()
iters = 0
while not stop_event.is_set():
dst = torch.empty_like(src, device="cpu") # pageable host memory
dst.copy_(src, non_blocking=False) # blocking D2H copy
iters += 1
print(f"[d2h_worker] iterations = {iters}")
def launch_worker(x: torch.Tensor):
Thread B:
Repeatedly launch a small CUDA kernel.
start_event.wait()
iters = 0
y = torch.sin(x) # small CUDA kernel
_ = y
iters += 1
print(f"[launch_worker] iterations = {iters}")
def main():
assert torch.cuda.is_available(), "CUDA is required."
print("PyTorch version:", torch.__version__)
print("GPU:", torch.cuda.get_device_name(0))
# Large tensor for D2H so the copy takes noticeable time.
# 64M float32 elements ~= 256 MB.
d2h_src = torch.empty(64 * 1024 * 1024, dtype=torch.float32, device="cuda")
d2h_src.uniform_(0, 1)
# Small tensor for kernel launch so the kernel itself is short.
launch_x = torch.randn(1024, device="cuda")
# Warmup.
for _ in range(5):
tmp = torch.empty_like(d2h_src, device="cpu")
tmp.copy_(d2h_src, non_blocking=False)
_ = torch.sin(launch_x)
torch.cuda.synchronize()
t1 = threading.Thread(target=d2h_worker, args=(d2h_src,), daemon=True)
t2 = threading.Thread(target=launch_worker, args=(launch_x,), daemon=True)
with profile(
activities=[ProfilerActivity.CPU, ProfilerActivity.CUDA],
record_shapes=False,
profile_memory=False,
with_stack=True,
) as prof:
t1.start()
t2.start()
start_event.set()
time.sleep(3.0)
stop_event.set()
t1.join()
t2.join()
output_path = "repro_d2h_pageable_vs_launch.json"
prof.export_chrome_trace(output_path)
print(f"Trace saved to: {output_path}")
print("Open it with chrome://tracing or Perfetto.")
if __name__ == "__main__":
main()
