I understand that when cudaMemcpyAsync involves host, it will be a blocking call. However, what exactly does “blocking” mean? I was under the impression that it would block the calling CPU thread until the copy is done and that’s it. However I ran into a problem in a particular use case that goes to show that it will in fact block even irrelevant empty kernel launches in a separate thread, on a separate stream.
The behaviour could be reproduced in below standalone program, some of the constructs are borrowed from this other post
So I will have a cpu_block_stream, on which I launch a host function to block it to wait for a CPU semaphore to be signalled. Then I queue an event on it, let default stream wait for that event, and then perform a D2H memcpy on default stream. Now from my understanding, this memcpy will now block the main thread, unless a separate thread comes to signal the CPU semaphore (I understand this is a weird sequence, but this is what I ran into and partly involves the PyTorch ProcessGroupNCCL call flow).
Then in a separate thread function, if I only signal the CPU semaphore, it works as expected. However, if before that cpu_event->Signal() line, I launch an empty kernel on an irrelevant stream, that will get blocked(I suppose by the memcpy involving host) and causes a deadlock.
Is this the expected behaviour? Does the “blocking” mean that it will block the entire cuda world?
#include <iostream>
#include <thread>
#include <mutex>
#include <condition_variable>
#include "cuda_runtime.h"
#include "errorcheck.h"
// cpu event construct
class Event {
private:
std::mutex mtx_condition_;
std::condition_variable condition_;
bool signalled = false;
public:
void Signal() {
std::lock_guard<decltype(mtx_condition_)> lock(mtx_condition_);
signalled = true;
condition_.notify_all();
void Wait() {
std::unique_lock<decltype(mtx_condition_)> lock(mtx_condition_);
while (!signalled) {
condition_.wait(lock);
// host function launched on cpu_block_stream that blocks it until cpu event signaled
void CUDART_CB block_op_host_fn(void* arg) {
Event* evt = (Event*)arg;
evt->Wait();
__global__ void NoOpKernel() {}
static void ThreadFn(cudaStream_t irrelevant_stream, Event* cpu_event) {
std::cout << "Launching empty kernel on irrelevant_stream in ThreadFn" << std::endl;
NoOpKernel<<<1, 1, 0, irrelevant_stream>>>(); // HANGS HERE, BLOCKED BY D2H MEM COPY
std::cout << "Launched empty kernel on irrelevant_stream in ThreadFn" << std::endl;
cpu_event->Signal(); // for unblocking cpu_block_stream, however code won't get here
int main() {
// create minimal CPU & GPU buffer for the cudaMemcpyAsync later
size_t numel = 1;
float *h_input;
float *input;
h_input = (float*)malloc(numel * sizeof(float));
CUDACHECK(cudaMalloc(&input, numel * sizeof(float)));
cudaStream_t cpu_block_stream, irrelevant_stream;
CUDACHECK(cudaStreamCreateWithFlags(&cpu_block_stream, cudaStreamNonBlocking));
CUDACHECK(cudaStreamCreateWithFlags(&irrelevant_stream, cudaStreamNonBlocking));
cudaEvent_t cpu_unblock_event;
CUDACHECK(cudaEventCreate(&cpu_unblock_event));
// launch the CPU function on cpu_block_stream to block it until cpu_event is signaled
Event* cpu_event = new Event();
CUDACHECK(cudaLaunchHostFunc(cpu_block_stream, block_op_host_fn, cpu_event));
// record cpu_unblock_event, which will be triggered after the cpu_event gets signaled
CUDACHECK(cudaEventRecord(cpu_unblock_event, cpu_block_stream));
// make default stream wait for it
CUDACHECK(cudaStreamWaitEvent(0, cpu_unblock_event));
// launch separate thread that does two things:
// 1. launch noop kernel on an irrelevant stream
// 2. signal the cpu_event to unblock cpu_block_stream
std::thread t = std::thread(ThreadFn, irrelevant_stream, cpu_event);
// issue async D2H memcpy on default stream
// blocks the empty kernel in thread function and causes a deadlock
std::cout << "issuing cudaMemcpyAsync\n" << std::endl;
CUDACHECK(cudaMemcpyAsync(h_input, input, numel * sizeof(float), cudaMemcpyDeviceToHost, 0));
// clean up
CUDACHECK(cudaStreamSynchronize(0));
t.join();
delete cpu_event;
free(h_input);
CUDACHECK(cudaFree(input));
CUDACHECK(cudaStreamDestroy(cpu_block_stream));
CUDACHECK(cudaStreamDestroy(irrelevant_stream));
CUDACHECK(cudaEventDestroy(cpu_unblock_event));
return 0;
