I have been struggling with cross compiling for my TX2 for a few weeks and there is an issue I have been unable so solve (been only able to bypass it with nasty scripts).
Setup:
An host with ubuntu 16.04 and the Jetpack 3.2.1 installed. Also installed the cross compiler aarch64.
A TX2 board flashed and set-up according to my host.
I am performing the build & install with CMake so I set up a large quantity of variables in order to position everything properly.
But I am getting stuck with this error :
error: unknown value ‘native’ for -march
After deep investigation (lots of generated makefile reading) it turns out that the march flag actually doesn’t work with the current cross-compiler (aarch64-linux-gnu) so the error make sense.
What doesn’t; is that even though I try to force these compiler flags into all the CMake files, the option -march=native stays first and trigger the error.
The only way I found to bypass this error is actually pretty simple but it doesn’t “feel” right:
function correctCmakeFlags() {
flagFile=$(find ./ -type f -name "flags.make")
for f in $flagFile; do
sed -i.bak 's/-march=native/-march=armv8-a/g' $f
done
I guess as some people are cross-compiling without any issue, there is probably some parameter that either I missed or misinterpreted, is there anyone having the same issue and solved it ?
Thanks !
If you compile single threaded (“-j1”) to avoid seeing several operations being mixed together, and compile as much as possible before running with “-j1” again, what do you see logged? You can use the “code” icon (looks like “</>” when editing your post) and paste directly into that, or else attach it as a file with a “.txt” suffix.
Building NVCC (Device) object src/Kernel/processing.cu.o
Scanning dependencies of target initial
[25%] Building CXX object src/initial_values.cpp.o
/home/user/code/src/initial_values.cpp:1:0: error: unknown value 'native' for -march
build.make:69: recipe for target 'src/initial_values.cpp.o' failed
What is strange with the -j1 argument is that it seems to reach some point in building before throwing the error…
It seems that when it starts reaching CUDA code, the build fails…
I will investigate more deeply my CMake script building CUDA, I might have an issue here, I actually don’t really know how I should position my flags for CUDA TX2 cross-compiling.
Hello, thanks for to advise. Actually, that was something I already did in order to program my nasty script up there. Instead of having an “overly-verbose” console (which sometime make things hard to find) I used the
-D"CMAKE_EXPORT_COMPILE_COMMANDS"=ON
Command which allow me to have all the compile commands exported into “compile_commands.json” file.
Anyway, I did what you recommended and found the full command giving the error:
As you can see I’m depending on different external libraries. In order to include them, I mounted the board as a folder in “/mnt” and included them.
I was expecting this to work (and it does with nasty script) but I don’t fully understand why is the “native” value isn’t working.
I checked other references to get a better view of the problem and from what I understood, changing the compiler flags should do the trick. But when I go into my toolchain file and change the flags, they just add-up to the left side of the Makefile, keeping the “-march=native” triggering the error.
In the end, the information I am looking for is “Where can I override the CMake compiler flags while cross-compiling when I’m using CUDA among the process ?”
You’re cross compiling, and “/usr/bin/aarch64-linux-gnu-g++” supports only one architecture, so probably you can skip “-march=…”. If not, then “native” is not an architecture when cross compiling. “aarch64” or “arm64” would be valid if you need to state “-march”. I’m unsure of the CMake cross compile overrides, someone else can probably help with that. If it were a kernel compile you just “export ARCH=arm64” prior to starting the build, or else a literal “ARCH=arm64 aarch64-linux-gnu=g++ …” preceding the build line. Sorry, I don’t use CMake much.
Very nice ! Thanks a lot for the advice, this allowed me to solve the issue. I didn’t knew that this flag could be totally removed without any side-effect…
In fact the script responsible of setting this parameter was out of my scope (actually PCLConfig.cmake which was locally compiled -and not cross-compiled-).
And later, when cross compiling, the remote cmake set your flag, triggering the error. The issue is specific to our particular configuration we got here.
Good solution: cross-compile your libraries from sources
Bad solution: simulate the cross compiling flag option (even though you have not).
