CSI camera pipeline failure on Xavier NX
I am trying to run a GStreamer pipeline to grab frames from an Arducam CSI camera module. Please see the pipeline below.
gst-launch-1.0 -v nvarguscamerasrc ! "video/x-raw(memory:NVMM), width=1280, height=720" ! nvvidconv ! fakesink
Experiencing the below error
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)21/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)21/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)21/1
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)21/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)21/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)21/1
GST_ARGUS: Creating output stream
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function initialize(), line 89)
(Argus) Error BadParameter: (propagating from src/eglstream/FrameConsumerImpl.cpp, function create(), line 44)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadInitialize:320 Failed to create FrameConsumer
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:241 (propagating)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, waitRunning:203 Invalid thread state 3
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:806 (propagating)
Am I missing anything here.?
This is the board information.
Hardware:
  CPU: 6 cores, Max:1907.2 MHz, Min:115.2 MHz
  RAM: 6854 MB
  Disk: Device:mmcblk0p1, Total:29G, Used:22G, Available:5.2G
  Board Model: NVIDIA Jetson Xavier NX Developer Kit
Software:
  L4T: 35.4.1
  JetPack: 5.1.2
  OpenCV: 4.5.4 (without CUDA)
  GStreamer: 1.16.3
  CUDA: 12.6
  TensorRT: 8.5.2
  cuDNN: 8.6.0
  SDL: 1.2.15
Power:
  Current Power Model: MODE_20W_6CORE
System info:
  Linux Distribution: Ubuntu 20.04.6 LTS
  Linux Version: 5.10.120-tegra
  Uptime: up 33 minutes
Do you confirm the sensor driver by v4l2-ctl?
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1280,height=720,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap
Hi Shane,
These are the camera details using v4l2-ctl. It is using ‘tegra-video’ driver
$ v4l2-ctl --info -d0
Driver Info:
Driver name : tegra-video
Card type : vi-output, imx219 9-0010
Bus info : platform:tegra-capture-vi:0
Driver version : 5.10.120
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Driver name : tegra-camrtc-ca
Model : NVIDIA Tegra Video Input Device
Serial :
Bus info :
Media version : 5.10.120
Hardware revision: 0x00000003 (3)
Interface Info:
Type : V4L Video
Entity Info:
Name : vi-output, imx219 9-0010
Function : V4L2 I/O
Pad 0x0100000a : 0: Sink
Link 0x0200000f: from remote pad 0x1000003 of entity ‘13e10000.host1x:nvcsi@15a00000-’: Data, Enabled
Your command is producing the following console output
ubuntu@gpucoder-hyd-xaviernx-1:~$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1280,height=720,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap
<<<<<<<<<<<<<<<<<<<<<<< 21.19 fps
Try below command.
gst-launch-1.0 -v nvarguscamerasrc ! "video/x-raw(memory:NVMM), width=1280, height=720, framerate=(fraction)21/1" ! nvvidconv ! fakesink
