Hi all,
is the following syntax correct?
cublasCgemm (‘N’,‘N’, N1_pad, M_pad, M_pad, alpha, Kernel_y_pad, N1_pad, DATA_pad, M_pad, beta, res_y, N1_pad);
where Kernel_y_pad is a N1_padXM_pad (rowsXcols) matrix and DATA_pad is a M_padxM_pad matrix.
It should work properly and provide a matrix res_y N1_pad X M_pad sized.
The results is very strange and not correct.
alpha and beta are cuFloatComplex equal to 1 and 0, respectively.
Thank you,
P
