The following code fragment is a replacement of runTest() in simpleCUFFT.cu using Driver API.
It works.
S.
[codebox]void runTest(int argc, char** argv)
CUfunction ComplexPointwiseMulAndScale = NULL;
CU_SAFE_CALL(initCUDA(argv[0], & ComplexPointwiseMulAndScale, argc, argv));
// CUT_DEVICE_INIT(argc, argv);
// Allocate host memory for the signal
Complex* h_signal = (Complex*)malloc(sizeof(Complex) * SIGNAL_SIZE);
// Initalize the memory for the signal
printf("d_signal_before padding-----------------\n");
for (unsigned int i = 0; i < SIGNAL_SIZE; ++i) {
h_signal[i].x = rand() / (float)RAND_MAX;
h_signal[i].y = 0;
printf("(%f, %f)\t", h_signal[i].x, h_signal[i].y);
// Allocate host memory for the filter
Complex* h_filter_kernel = (Complex*)malloc(sizeof(Complex) * FILTER_KERNEL_SIZE);
// Initalize the memory for the filter
printf("d_filter_kernel_before padding----------------\n");
for (unsigned int i = 0; i < FILTER_KERNEL_SIZE; ++i) {
h_filter_kernel[i].x = rand() / (float)RAND_MAX;
h_filter_kernel[i].y = 0;
printf("(%f, %f)\t", h_filter_kernel[i].x, h_filter_kernel[i].y);
// Pad signal and filter kernel
Complex* h_padded_signal;
Complex* h_padded_filter_kernel;
int new_size = PadData(h_signal, &h_padded_signal, SIGNAL_SIZE,
h_filter_kernel, &h_padded_filter_kernel, FILTER_KERNEL_SIZE);
int mem_size = sizeof(Complex) * new_size;
printf(“newsize = %d\t, memsize = %d\n”, new_size, mem_size);
printf("h_padded_signal--------------------\n");
for (unsigned int i = 0; i < new_size; ++i) {
printf("(%f, %f)\t", h_padded_signal[i].x, h_padded_signal[i].y);
printf(“h_padded_filter kernel--------------------\n”);
h_padded_filter_kernel[i].x, h_padded_filter_kernel[i].y);
// Allocate device memory for signal
CUdeviceptr d_signal;
CU_SAFE_CALL(cuMemAlloc(&d_signal, mem_size));
// Copy host memory to device
CU_SAFE_CALL(cuMemcpyHtoD(d_signal, h_padded_signal, mem_size));
// Allocate device memory for filter kernel
CUdeviceptr d_filter_kernel;
CU_SAFE_CALL(cuMemAlloc(&d_filter_kernel, mem_size));
CU_SAFE_CALL(cuMemcpyHtoD(d_filter_kernel, h_padded_filter_kernel, mem_size));
// CUFFT plan
cufftHandle plan;
CUFFT_SAFE_CALL(cufftPlan1d(&plan, new_size, CUFFT_C2C, 1));
printf("plan returned = %d\n", plan);
// Transform signal and kernel
CUFFT_SAFE_CALL(cufftExecC2C(plan, (cufftComplex *)d_signal,
(cufftComplex *)d_signal, CUFFT_FORWARD));
cufftComplex* z = (cufftComplex*)malloc(sizeof(cufftComplex) * new_size);
cuMemcpyDtoH(z, d_signal, mem_size);
for(int i = 0 ; i < new_size ; i++)
cufftComplex z1 = (cufftComplex)z[i];
printf("real, img (%d)= %f, %f\n", i, z1.x, z1.y);
CUFFT_SAFE_CALL(cufftExecC2C(plan, (cufftComplex *)d_filter_kernel, (cufftComplex *)d_filter_kernel, CUFFT_FORWARD));
// Multiply the coefficients together and normalize the result
// ComplexPointwiseMulAndScale<<<32, 256>>>(d_signal, d_filter_kernel, new_size, 1.0f / new_size);
CU_SAFE_CALL(cuFuncSetBlockShape (ComplexPointwiseMulAndScale, 256, 1, 1));
CU_SAFE_CALL(cuParamSeti (ComplexPointwiseMulAndScale, 0, d_signal));
CU_SAFE_CALL(cuParamSeti (ComplexPointwiseMulAndScale, 4, d_filter_kernel));
CU_SAFE_CALL(cuParamSeti (ComplexPointwiseMulAndScale, 8, new_size));
CU_SAFE_CALL(cuParamSetf (ComplexPointwiseMulAndScale, 12, 1.0f / new_size));
CU_SAFE_CALL(cuParamSetSize (ComplexPointwiseMulAndScale, 16));
CU_SAFE_CALL(cuLaunchGrid (ComplexPointwiseMulAndScale, 32, 1));
// Check if kernel execution generated and error
CUT_CHECK_ERROR("Kernel execution failed [ ComplexPointwiseMulAndScale ]");
// Transform signal back
CUFFT_SAFE_CALL(cufftExecC2C(plan, (cufftComplex *)d_signal, (cufftComplex *)d_signal, CUFFT_INVERSE));
// Copy device memory to host
Complex* h_convolved_signal = h_padded_signal;
CU_SAFE_CALL(cuMemcpyDtoH((void*)h_convolved_signal, d_signal, mem_size));
// Allocate host memory for the convolution result
Complex* h_convolved_signal_ref = (Complex*)malloc(sizeof(Complex) * SIGNAL_SIZE);
// Convolve on the host
Convolve(h_signal, SIGNAL_SIZE,
h_filter_kernel, FILTER_KERNEL_SIZE,
h_convolved_signal_ref);
// check result
for(int k = 0 ; k < SIGNAL_SIZE ; k++)
Complex cpxr = h_convolved_signal_ref[k];
// printf("h_convolved_Signal_ref (%f, %f)\t", cpxr.x, cpxr.y);
Complex cpx = h_convolved_signal[k];
//printf("h_convolved_Signal (%f, %f)\n", cpx.x, cpx.y);
CUTBoolean res = cutCompareL2fe((float*)h_convolved_signal_ref, (float*)h_convolved_signal, 2 * SIGNAL_SIZE, 1e-5f);
printf("Test %s\n", (1 == res) ? "PASSED" : "FAILED");
//Destroy CUFFT context
CUFFT_SAFE_CALL(cufftDestroy(plan));
// cleanup memory
free(h_signal);
free(h_filter_kernel);
free(h_padded_signal);
free(h_padded_filter_kernel);
free(h_convolved_signal_ref);
CU_SAFE_CALL(cuMemFree(d_signal));
CU_SAFE_CALL(cuMemFree(d_filter_kernel));
[/codebox]
