cudaGetExportTable a total hack
Those of you who work with wrapper libraries for the CUDA runtime may have noticed the quiet introduction of ‘cudaGetExportTable’ and ‘cuGetExportTable’ around version 3.0 of the runtime and that several nvidia libraries such as cublas and cufft started making calls into them.
This has been particularly painful for re-implementations of the CUDA runtime, such as the one in Ocelot or other GPU emulators/simulators, because they are not documented and as we will see, extend the CUDA API to include internal driver functions. I spent some time poking around these functions and believe that I have an explanation of what they do and how to work around them if the CUDA driver is not installed.
My first successful implementation of ‘cudaGetExportTable’ looked like this:
cudaError_t cuda::CudaRuntime::cudaGetExportTable(const void **ppExportTable,
	const cudaUUID_t *pExportTableId) {
	report("Getting export table");
	cuda::CudaDriver::cuInit(0);
	CUcontext context;
	cuda::CudaDriver::cuCtxCreate(&context, 0, 0);
	cuda::CudaDriver::cuGetExportTable(ppExportTable, pExportTableId);
	return cudaSuccess;
This passes the parameters straight through into a newly created driver context, but the rest of the calls are executed on Ocelot’s emulated device. Getting this far allowed me to determine a few things:
  1. The export table ppExportTable returned by the driver is an array of pointers. Manual inspection with a debugger showed that these addresses were mapped into the address space of the driver.
  2. Assembly level debugging showed that the internal functions in CUBLAS and CUFFT retrieve elements from this array of pointers and call them using a standard calling convention.
  3. From 1) and 2), I concluded that the export table is a list of function pointers into internal driver functions.
Armed with this knowledge I continued to step through CUBLAS assembly until several of these function pointers were called, and their results were returned. My options at this point was to dump the assembly of the individual functions being called and re implement them in C (which would consume more of my time than I would like and I would have to deal with calls to other internal driver functions ad naseum) or write some dummy functions that returned close enough results. The following code also passes through enough of CUBLAS and CUFFT to execute the SDK samples.
// This is a horrible hack to deal with another horrible hack
// Thanks nvidia for creating a backdoor interface to your driver rather than extending the API in a sane and documented way
int dummy0() { return 0; }
int dummy1() { return 2 << 20; }
typedef int (*ExportedFunction)();
static ExportedFunction exportTable[3] = {&dummy0, &dummy1, &dummy1};
	*ppExportTable = &exportTable;
	return cudaSuccess;
I thought that I would post this here in case anyone else was having trouble simulating CUBLAS/CUFFT.
Someone could probably take this further by going back to my first approach and memcopying out the regions pointed to by the function pointers in the table returned by the driver, disassembling and decompiling them, then re-implementing them in a more correct way. Or nvidia could actually document these functions…
Hi Greg, Thanks for the info! I gave up trying to figure it out (while debugging cudaMalloc) because, as you say, there are a lot of other important functions to emulate. It would be nice if NVIDIA could simply document the cudaGetExportTable, so we don’t have to waste time trying to figure out what it does. Ken
Thank you Greg!
But I wonder, how can a user-space program call a driver function without going through a system call? I am a bit confused here. Can you clarify?
Sorry about that, when I say that the code is part of the driver, I mean that it is part of the CUDA Driver API library (libcuda.so), which apparently is not part of the kernel mode driver.
Oh! Sorry… Thanks for the clarification. Must be very difficult being author of Ocelot. Keep up the good work!
I am going to hazard a guess that this is how the CUBLAS and CUFFT driver API interop has been done so that the libraries can hook into existing driver API contexts.
It is pretty sucky to have completely undocumented API calls in the runtime though.
I was just reading the NVCC options.
I find this:
–export-dir (-dir)
Specify the name of a file to which all ‘external’ code images will be
copied, intended as a device code repository that can be inspected by
the cuda driver at application runtime when it occurs in the
appropriate device code search paths.
This file can be either a directory, or a zip file. In either case,
this tool will maintain a directory structure in order to facilitate
code lookup by the cuda driver. When this option is not used, all
‘external’ images will be silently discarded. When a directory is
specified, but does not currently exist, then it will be created as a
common directory (not a zip file).
May be related to Export Table?
Possibly, but it doesn’t look like it from what I can tell. It seems like the device code is already available via cudaRegisterFatBinary that is contained within libcufft.so.
Also, here is a bit more information. It looks like my hack that I posted before fails for CUFFT on 64-bit machines. Here is a bit more information in-case other people want to try to take this further.
It looks like the export table ID is always the same for CUFFT and CUBLAS ( 0x11df21116e3393c6 0x9395d855f368c3a8 ), and that the table contains only three function pointers.
Here is a complete assembly dump of the third function returned including the entire reachable call graph in libcuda.so:
exported_function_3_of_3:
=> 0x00007fffecf17190:	push   %rbp
   0x00007fffecf17191:	mov    %rdi,%rbp
   0x00007fffecf17194:	xor    %edi,%edi
   0x00007fffecf17196:	push   %rbx
   0x00007fffecf17197:	mov    %rdx,%rbx
   0x00007fffecf1719a:	sub    $0x8,%rsp
   0x00007fffecf1719e:	test   %rsi,%rsi
   0x00007fffecf171a1:	cmove  %rsp,%rdi
   0x00007fffecf171a5:	mov    %rsi,(%rsp)
   0x00007fffecf171a9:	callq  0x7fffecea23a0   # begin_function_1
   0x00007fffecf171ae:	test   %eax,%eax
   0x00007fffecf171b0:	mov    %eax,%edx
   0x00007fffecf171b2:	jne    0x7fffecf171dd
   0x00007fffecf171b4:	mov    (%rsp),%rcx
   0x00007fffecf171b8:	mov    0x88(%rcx),%rax
   0x00007fffecf171bf:	test   %rax,%rax
   0x00007fffecf171c2:	jne    0x7fffecf171cf
   0x00007fffecf171c4:	jmp    0x7fffecf171e6
   0x00007fffecf171c6:	mov    0x28(%rax),%rax
   0x00007fffecf171ca:	test   %rax,%rax
   0x00007fffecf171cd:	je     0x7fffecf171e6
   0x00007fffecf171cf:	cmp    %rbx,0x8(%rax)
   0x00007fffecf171d3:	jne    0x7fffecf171c6
   0x00007fffecf171d5:	mov    0x10(%rax),%rbx
   0x00007fffecf171d9:	mov    %rbx,0x0(%rbp)
   0x00007fffecf171dd:	add    $0x8,%rsp
   0x00007fffecf171e1:	mov    %edx,%eax
   0x00007fffecf171e3:	pop    %rbx
   0x00007fffecf171e4:	pop    %rbp
   0x00007fffecf171e5:	retq
   0x00007fffecf171e6:	add    $0x8,%rsp
   0x00007fffecf171ea:	mov    $0x190,%edx
   0x00007fffecf171ef:	pop    %rbx
   0x00007fffecf171f0:	pop    %rbp
   0x00007fffecf171f1:	mov    %edx,%eax
   0x00007fffecf171f3:	retq
begin_function_1:
   0x00007fffecea23a0:	mov    %rbp,-0x10(%rsp)
   0x00007fffecea23a5:	mov    %r12,-0x8(%rsp)
   0x00007fffecea23aa:	mov    %rdi,%r12
   0x00007fffecea23ad:	mov    %rbx,-0x18(%rsp)
   0x00007fffecea23b2:	sub    $0x18,%rsp
   0x00007fffecea23b6:	mov    0x9706db(%rip),%rbp        # 0x7fffed812a98
   0x00007fffecea23bd:	mov    0x578(%rbp),%ebx
   0x00007fffecea23c3:	callq  0x7fffed4b39b0       # begin_function_2
   0x00007fffecea23c8:	cmp    %eax,%ebx
   0x00007fffecea23ca:	jne    0x7fffecea23e7
   0x00007fffecea23cc:	mov    0x1d0(%rbp),%edx
   0x00007fffecea23d2:	mov    $0x4,%ecx
   0x00007fffecea23d7:	cmp    $0x321cba00,%edx
   0x00007fffecea23dd:	je     0x7fffecea23ec
   0x00007fffecea23df:	cmp    $0xabc123,%edx
   0x00007fffecea23e5:	je     0x7fffecea2401
   0x00007fffecea23e7:	mov    $0x3,%ecx
   0x00007fffecea23ec:	mov    (%rsp),%rbx
   0x00007fffecea23f0:	mov    0x8(%rsp),%rbp
   0x00007fffecea23f5:	mov    %ecx,%eax
   0x00007fffecea23f7:	mov    0x10(%rsp),%r12
   0x00007fffecea23fc:	add    $0x18,%rsp
   0x00007fffecea2400:	retq
   0x00007fffecea2401:	xor    %cl,%cl
   0x00007fffecea2403:	test   %r12,%r12
   0x00007fffecea2406:	je     0x7fffecea23ec
   0x00007fffecea2408:	mov    0x0(%rbp),%edi
   0x00007fffecea240b:	callq  0x7fffed4b3aa0     # begin_function_3
   0x00007fffecea2410:	test   %rax,%rax
   0x00007fffecea2413:	mov    %rax,(%r12)
   0x00007fffecea2417:	mov    $0xc9,%ecx
   0x00007fffecea241c:	je     0x7fffecea23ec
begin_function_2:
   0x00007fffed4b39b0:	jmpq   0x7fffece88064 <getpid@plt>
   0x00007fffed4b39b5:	data32 nopw %cs:0x0(%rax,%rax,1)
   0x00007fffed4b39c0:	jmpq   0x7fffece887e4 <pthread_mutex_unlock@plt>
   0x00007fffed4b39c5:	data32 nopw %cs:0x0(%rax,%rax,1)
   0x00007fffed4b39d0:	jmpq   0x7fffece886e4 <pthread_mutex_lock@plt>
   0x00007fffed4b39d5:	data32 nopw %cs:0x0(%rax,%rax,1)
   0x00007fffed4b39e0:	jmpq   0x7fffece88784 <pthread_mutex_destroy@plt>
   0x00007fffed4b39e5:	data32 nopw %cs:0x0(%rax,%rax,1)
   0x00007fffed4b39f0:	xor    %esi,%esi
   0x00007fffed4b39f2:	jmpq   0x7fffece88074 <pthread_mutex_init@plt>
   0x00007fffed4b39f7:	nopw   0x0(%rax,%rax,1)
   0x00007fffed4b3a00:	push   %r12
   0x00007fffed4b3a02:	mov    %edi,%eax
   0x00007fffed4b3a04:	push   %rbp
   0x00007fffed4b3a05:	push   %rbx
   0x00007fffed4b3a06:	mov    $0x10624dd3,%ebx
   0x00007fffed4b3a0b:	mul    %ebx
   0x00007fffed4b3a0d:	sub    $0x20,%rsp
   0x00007fffed4b3a11:	lea    0x10(%rsp),%rbp
   0x00007fffed4b3a16:	mov    %rsp,%rsi
   0x00007fffed4b3a19:	shr    $0x6,%edx
   0x00007fffed4b3a1c:	mov    %edx,%ecx
   0x00007fffed4b3a1e:	imul   $0x3e8,%edx,%edx
   0x00007fffed4b3a24:	mov    %rcx,0x10(%rsp)
   0x00007fffed4b3a29:	sub    %edx,%edi
   0x00007fffed4b3a2b:	imul   $0xf4240,%edi,%eax
   0x00007fffed4b3a31:	mov    %eax,%edi
   0x00007fffed4b3a33:	mov    %rdi,0x18(%rsp)
   0x00007fffed4b3a38:	mov    %rbp,%rdi
   0x00007fffed4b3a3b:	callq  0x7fffece88514 <nanosleep@plt>
   0x00007fffed4b3a40:	test   %eax,%eax
   0x00007fffed4b3a42:	je     0x7fffed4b3a79
   0x00007fffed4b3a44:	callq  0x7fffece88424 <__errno_location@plt>
   0x00007fffed4b3a49:	mov    %rax,%rbx
   0x00007fffed4b3a4c:	nopl   0x0(%rax)
   0x00007fffed4b3a50:	jmp    0x7fffed4b3a74
   0x00007fffed4b3a52:	mov    0x8(%rsp),%rsi
   0x00007fffed4b3a57:	mov    (%rsp),%r8
   0x00007fffed4b3a5b:	mov    %rbp,%rdi
   0x00007fffed4b3a5e:	mov    %rsi,0x18(%rsp)
   0x00007fffed4b3a63:	mov    %rsp,%rsi
   0x00007fffed4b3a66:	mov    %r8,0x10(%rsp)
   0x00007fffed4b3a6b:	callq  0x7fffece88514 <nanosleep@plt>
   0x00007fffed4b3a70:	test   %eax,%eax
   0x00007fffed4b3a72:	je     0x7fffed4b3a79
   0x00007fffed4b3a74:	cmpl   $0x4,(%rbx)
   0x00007fffed4b3a77:	je     0x7fffed4b3a52
   0x00007fffed4b3a79:	add    $0x20,%rsp
   0x00007fffed4b3a7d:	pop    %rbx
   0x00007fffed4b3a7e:	pop    %rbp
   0x00007fffed4b3a7f:	pop    %r12
   0x00007fffed4b3a81:	retq
begin_function_3:
   0x00007fffed4b3aa0:	dec    %edi
   0x00007fffed4b3aa2:	jmpq   0x7fffece87db4 <pthread_getspecific@plt>
   0x00007fffed4b3aa7:	nopw   0x0(%rax,%rax,1)
   0x00007fffed4b3ab0:	jmpq   0x7fffece88194 <pthread_key_delete@plt>
   0x00007fffed4b3ab5:	data32 nopw %cs:0x0(%rax,%rax,1)
   0x00007fffed4b3ac0:	sub    $0x18,%rsp
   0x00007fffed4b3ac4:	mov    %rdi,%rsi
   0x00007fffed4b3ac7:	lea    0x14(%rsp),%rax
   0x00007fffed4b3acc:	mov    %rax,%rdi
   0x00007fffed4b3acf:	callq  0x7fffece88754 <pthread_key_create@plt>
   0x00007fffed4b3ad4:	mov    0x14(%rsp),%ecx
   0x00007fffed4b3ad8:	mov    %eax,%edx
   0x00007fffed4b3ada:	xor    %eax,%eax
   0x00007fffed4b3adc:	inc    %ecx
   0x00007fffed4b3ade:	test   %edx,%edx
   0x00007fffed4b3ae0:	cmove  %ecx,%eax
   0x00007fffed4b3ae3:	add    $0x18,%rsp
   0x00007fffed4b3ae7:	retq
This assembly uses the GNU/C ATT syntax. It looks like all of these functions obey the stdcall calling convention, which makes life slightly easier. So there is a single result of each function that is returned in $eax, similar to the cudaError_t style of most other API calls. The returned values of this function are either 0 (probably something like cuda_success) or 400 (not sure what this means). begin_function_2 seems mutex related, possibly a spin lock or condition variable due to the nanosleep and mutex related calls.
Anyone want to take a crack at reverse engineering this one?
Hi Greg,
Though I dont understand much of what is being returned, I would atleast guess that the API is written to opaquely handle kernels present in external files and kernels present in the same executable… Like an abstract base class interface…
It would be useful to compile an executable with and without --export-dir option and note the behaviour of compiler, the API function itself etc…
I dont have time for that. Its way too off my work,
Thanks,
Best Regards,
Sarnath
