I’m working with CUDA 7.5. I’ve got CUDA working with VS2013, now I want to get CuBLAS working.
I’m referring to the CuBlAS documentation here and the sample code provided. http://docs.nvidia.com/cuda/cublas/#axzz4Cr1laZ6o
This shows a kernel which uses the vector scale function thus:
cublasSscal (handle, n-p+1, &alpha, &m[IDX2F(p,q,ldm)], ldm);
However when I try to run this code I get an error because the cublasSscal function in the version of the CuBLAS library which ships with CUDA 7.5 appears to take different function parameters:
void CUBLASWINAPI cublasSscal (int n, float alpha, float *x, int incx);
It appears the handle has gone from all these functions? I can’t find current documentation explaining this. Please can someone point me in the direction of a working example?
My ultimate aim is to use CAFFE to do image classification in a windows application but I want to make sure I understand and can use each of the underlying components first.
