CUBLAS failing on cublasAlloc from C
I suspect that I am making an incorrect assumption somewhere, but I cannot get the cublasAlloc command to work in a simple C code. The manual says that CUBLAS is self-contained at the API level, so I presume that I don’t have to use nvcc to compile. Here is my code:
#include <stdio.h>
#include <stdlib.h>
#include <malloc.h>
#include "cublas.h"
int main () {
 int order = 256;
  int i,j;
  float* cpuA;
  float* cpuB;
  float* cpuC;
  const float* gpuA;
  const float* gpuB;
  float* gpuC;
  cublasStatus retStatus;
 printf("order is %d\n",order);
 // set up matrix values
  cpuA = (float*) malloc (order*order*sizeof(float));
  for (i=1; i<=order; i++) {
    for (j=1; j<=order; j++) {
      cpuA[(i-1)*order+j-1] = (float)i*order + j;
  // ...same for cpuB and cpuC ...
 retStatus = cublasInit ();
  // test for error
  retStatus = cublasGetError ();
  if (retStatus != CUBLAS_STATUS_SUCCESS) {
    printf("CUBLAS: an error occured in cublasInit\n");
  } else {
    printf("CUBLAS: cublasInit worked\n");
 // set up gpu matrix --- DIES HERE ---
  cublasAlloc (order*order, sizeof(float), (void**)gpuA);
  // test for error
    printf("CUBLAS: an error occured in cublasAlloc\n");
  } else {
    printf("CUBLAS: cublasAlloc worked\n");
  retStatus = cublasSetMatrix (order, order, sizeof(float),
                cpuA, order, (void*)gpuA, order);
  // ...same for gpuB, gpuC...
 // call BLAS routine
  (void) cublasSgemm ('N','T',order,order,order,0.5,
                gpuA,order,gpuB,order,0.5,gpuC,order);
  retStatus = cublasGetMatrix (order, order, sizeof(float),
                gpuC, order, cpuC, order);
 return(0);
It compiles with
gcc -pg -ggdb -o aloneCUBLAS aloneCUBLAS.c -I/usr/local/cuda/include -L/usr/local/cuda/lib -lcublas
It segfaults at the cublasAlloc command when I run it, and gdb doesn’t seem to be helping:
(gdb) run
Starting program: /home/mstock/testBLAS/aloneCUBLAS
[Thread debugging using libthread_db enabled]
[New Thread -1208863040 (LWP 13234)]
order is 256
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1208863040 (LWP 13234)]
0x007ec3f2 in cublasAlloc () from /usr/local/cuda/lib/libcublas.so
(gdb) bt
#0  0x007ec3f2 in cublasAlloc () from /usr/local/cuda/lib/libcublas.so
#1  0x08048923 in main () at aloneCUBLAS.c:53
Does anybody have an idea what I doing wrong?
Other CUDA codes run, but I have not tried other CUBLAS calls. This is on a RHEL4u3 system with an 8800GTX.
Change the cublasAlloc to:
cublasAlloc (order*order, sizeof(float), (void**)&gpuA);
Thanks! Oftentimes my programming knowledge extends only far enough to know when I screwed up.
