Environment
- GPU: NVIDIA GeForce RTX 5090 Laptop GPU (compute capability 12.0, sm_120, Blackwell)
- Driver: 595.71.05
- OS: Linux 6.17.0 (x86_64)
- CUDA toolkit: 13.3 (nvcc V13.3.33)
- cuBLAS / cuBLASLt: 13.5.1.27
- Application: llama.cpp (CUDA backend), FP32 GEMMs issued via cuBLASLt
Summary
Under sustained inference, an internal cuBLASLt JIT kernel raises a Warp Barrier Arrival Mismatch device exception. It surfaces intermittently as either cudaErrorIllegalAddress (“an illegal memory access was encountered”) or a GPU hang (100% SM utilization, ~0% memory throughput — warps spinning at a named barrier that never completes). The failure is timing-dependent (stochastic threshold, ~15–180 GEMM-heavy iterations) and vanishes under any serialization (compute-sanitizer, or a cudaStreamSynchronize after each op) — a classic async heisenbug.
Faulting kernel (from CUDA device coredump)
CUDA Exception: Warp Barrier Arrival Mismatch
kernel: nvjet_sm120_sss_tf32_mma_32x32x64_6_16x16x64_tmaAB_alignCD4_splitK_TNNN
GridDim (8,1,16) BlockDim (64,2,1)
This is the TF32 tensor-core, split-K GEMM kernel cuBLASLt selects for certain FP32 GEMM shapes on sm_120.
Kernel-name provenance: this kernel name and grid/block were captured by cuda-gdb from a device coredump during initial isolation on 2026-06-08. The original core was not retained, but the crash is reproducible — a fresh core can be regenerated in ~20 min with the recipe below (note: experts must be on the GPU, -ngl 99, not CPU-offloaded — the bug does not reproduce when expert matmuls run on CPU, since the cuBLAS FP32 path is then not exercised).
How it was captured
The bug vanishes under compute-sanitizer, so the faulting kernel was named via a CUDA device coredump (a host ulimit -c core does not capture device state):
CUDA_ENABLE_COREDUMP_ON_EXCEPTION=1 CUDA_ENABLE_LIGHTWEIGHT_COREDUMP=1 \
CUDA_COREDUMP_FILE=core_%p.nvcudmp <run FP32-GEMM workload until it faults>
cuda-gdb -q -ex "target cudacore core_<pid>.nvcudmp" -ex "info cuda kernels" -ex "bt"
Reproduction
- Run an FP32 GEMM workload that cuBLASLt routes to the TF32 split-K kernel above on an RTX 5090, with experts on GPU — e.g. llama.cpp decoding
google/gemma-4-26B-A4B-itMXFP4_MOE GGUF,-ngl 99(TF32 enabled, i.e. default). - Apply sustained load (hundreds of GEMMs). The crash/hang appears stochastically, typically before ~180 iterations.
Proven workaround
Disabling TF32 (NVIDIA_TF32_OVERRIDE=0) makes cuBLASLt select a non-TF32 FP32 kernel and the failure disappears: 3 independent runs of 300 generations each completed cleanly (vs systematic failure < ~180 with TF32 enabled), and the fix has since run cleanly for 960+ generations in a workload whose FP32 path is exercised even more heavily. Throughput impact is negligible (token-generation unchanged; prompt-GEMM −1.6%, within noise).
Questions for NVIDIA
- Is the barrier-arrival mismatch a known issue in the
nvjet_sm120_..._tf32_..._splitK_TNNNkernel’s intra-block named-barrier logic on sm_120 (Blackwell)? It looks like divergent / under-counted barrier participation in the split-K path for this tile configuration. - Is there a supported per-handle / per-operation way to force the non-TF32 FP32 kernel on sm_120 short of the global
NVIDIA_TF32_OVERRIDE=0— e.g. does cuBLASLt honor aCUBLAS_COMPUTE_32F_PEDANTICcompute type or an algo/heuristic flag to avoid this split-K TF32 kernel on Blackwell?
This is one of three distinct sm_120 GPU bugs isolated on the same workload; the other two are ggml/llama.cpp device-kernel issues: CUDA sm_120 (Blackwell, RTX 5090): `flash_attn_ext_f16<256,256,32,2>` raises "Warp Misaligned Register" device exception — intermittent crash; `-fa off` works around it · Issue #24398 · ggml-org/llama.cpp · GitHub (flash_attn_ext_f16, Warp Misaligned Register) and CUDA sm_120 (Blackwell, RTX 5090): out-of-range shared-memory store in `mul_mat_q<Q8_0,128>` MMA write-back epilogue — intermittent crash; eliminated by removing Q8_0 weights · Issue #24399 · ggml-org/llama.cpp · GitHub (mul_mat_q Q8_0, out-of-range shared store).
