Just adding this. & kind of progressing
I am able to see the GPU devices here
>>> import tensorflow as tf
>>> from tensorflow.python.client import device_lib
>>> print(device_lib.list_local_devices())
2019-12-28 22:04:51.491137: I tensorflow/core/platform/cpu_feature_guard.cc:142] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2019-12-28 22:04:51.521296: I tensorflow/core/platform/profile_utils/cpu_utils.cc:94] CPU Frequency: 3298250000 Hz
2019-12-28 22:04:51.522539: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x51538a0 executing computations on platform Host. Devices:
2019-12-28 22:04:51.522584: I tensorflow/compiler/xla/service/service.cc:175] StreamExecutor device (0): Host, Default Version
2019-12-28 22:04:51.526595: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcuda.so.1
2019-12-28 22:04:51.841513: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x51e9110 executing computations on platform CUDA. Devices:
2019-12-28 22:04:51.841562: I tensorflow/compiler/xla/service/service.cc:175] StreamExecutor device (0): TITAN Xp, Compute Capability 6.1
2019-12-28 22:04:51.841586: I tensorflow/compiler/xla/service/service.cc:175] StreamExecutor device (1): TITAN X (Pascal), Compute Capability 6.1
2019-12-28 22:04:51.846348: I te
However when I test again Tensorflow with following command…Looks like issues with loading specific libraries within lib64. Those libraries are related to Cuda 10.0. Example: ‘libcudart.so.10.0’ Doesn’t exist should be 10.2…Please let me know what you think. Do you have a solution? Build Tf from source may be a solution. For now I am going to have to install cuda 10.0
tf.test.is_gpu_available()
2019-12-28 22:08:23.329723: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
name: TITAN Xp major: 6 minor: 1 memoryClockRate(GHz): 1.582
pciBusID: 0000:02:00.0
2019-12-28 22:08:23.331713: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 1 with properties:
name: TITAN X (Pascal) major: 6 minor: 1 memoryClockRate(GHz): 1.531
pciBusID: 0000:01:00.0
2019-12-28 22:08:23.331944: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libcudart.so.10.0'; dlerror: libcudart.so.10.0: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda-10.2/lib64
2019-12-28 22:08:23.332091: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libcublas.so.10.0'; dlerror: libcublas.so.10.0: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda-10.2/lib64
2019-12-28 22:08:23.332226: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libcufft.so.10.0'; dlerror: libcufft.so.10.0: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda-10.2/lib64
2019-12-28 22:08:23.332355: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libcurand.so.10.0'; dlerror: libcurand.so.10.0: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda-10.2/lib64
2019-12-28 22:08:23.332484: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libcusolver.so.10.0'; dlerror: libcusolver.so.10.0: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda-10.2/lib64
2019-12-28 22:08:23.332614: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libcusparse.so.10.0'; dlerror: libcusparse.so.10.0: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda-10.2/lib64
2019-12-28 22:08:23.332653: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2019-12-28 22:08:23.332672: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1641] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
Skipping registering GPU devices...
2019-12-28 22:08:23.332773: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-12-28 22:08:23.332796: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0 1
2019-12-28 22:08:23.332811: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N Y
2019-12-28 22:08:23.332825: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 1: Y N
False
