I’ve tried reading other solutions but my problem seems different.
I’ve followed the guide at GPU 支持 | TensorFlow (for the most part).
Running the command (in venv)
python -c "import tensorflow as tf;print(tf.reduce_sum(tf.random.normal([1000, 1000])))"
outputs
$ python -c "import tensorflow as tf;print(tf.reduce_sum(tf.random.normal([1000, 1000])))"
2020-02-08 11:43:21.944657: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libnvinfer.so.6
2020-02-08 11:43:21.946221: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libnvinfer_plugin.so.6'; dlerror: libnvrtc.so.10.1: cannot open shared object file: No such file or directory
2020-02-08 11:43:21.946258: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:30] Cannot dlopen some TensorRT libraries. If you would like to use Nvidia GPU with TensorRT, please make sure the missing libraries mentioned above are installed properly.
2020-02-08 11:43:22.977924: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcuda.so.1
2020-02-08 11:43:23.008777: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:981] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-02-08 11:43:23.009295: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1555] Found device 0 with properties:
pciBusID: 0000:01:00.0 name: GeForce GTX 1080 computeCapability: 6.1
coreClock: 1.7335GHz coreCount: 20 deviceMemorySize: 7.93GiB deviceMemoryBandwidth: 298.32GiB/s
2020-02-08 11:43:23.009334: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.1
2020-02-08 11:43:23.009360: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10
2020-02-08 11:43:23.009446: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libcufft.so.10'; dlerror: libcufft.so.10: cannot open shared object file: No such file or directory
2020-02-08 11:43:23.009488: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libcurand.so.10'; dlerror: libcurand.so.10: cannot open shared object file: No such file or directory
2020-02-08 11:43:23.009525: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libcusolver.so.10'; dlerror: libcusolver.so.10: cannot open shared object file: No such file or directory
2020-02-08 11:43:23.009570: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library 'libcusparse.so.10'; dlerror: libcusparse.so.10: cannot open shared object file: No such file or directory
2020-02-08 11:43:23.009592: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-02-08 11:43:23.009597: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1592] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
Skipping registering GPU devices...
2020-02-08 11:43:23.009968: I tensorflow/core/platform/cpu_feature_guard.cc:142] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2 FMA
2020-02-08 11:43:23.039141: I tensorflow/core/platform/profile_utils/cpu_utils.cc:94] CPU Frequency: 3593135000 Hz
2020-02-08 11:43:23.040033: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x5b3fad0 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2020-02-08 11:43:23.040055: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Host, Default Version
2020-02-08 11:43:23.123931: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:981] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-02-08 11:43:23.124538: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x5bc5a20 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices:
2020-02-08 11:43:23.124570: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): GeForce GTX 1080, Compute Capability 6.1
2020-02-08 11:43:23.124683: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1096] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-02-08 11:43:23.124700: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1102]
tf.Tensor(317.43338, shape=(), dtype=float32)
Clearly I’m missing
nvidia-smi is
| NVIDIA-SMI 430.50 Driver Version: 430.50 CUDA Version: 10.1 |
| 0 GeForce GTX 1080 Off | 00000000:01:00.0 On | N/A |
| 28% 27C P8 6W / 180W | 256MiB / 8118MiB | 0% Default |
l /usr/local/cuda-10.1/lib64/
outputs
libcudadevrt.a libcudart.so.10.1@ libcudart_static.a libOpenCL.so@ libOpenCL.so.1.1
libcudart.so@ libcudart.so.10.1.243 libculibos.a libOpenCL.so.1@ stubs/
Additional ask: why is
not found for TensorRT?
