Tensorflow fails to find libcudart
All of the following is under a venv but I tried without it and still get the same result.
I’m using Ubuntu-20.04.
I start with
import tensorflow as tf
and I get the following warning:
2020-09-15 13:27:32.929958: W tensorflow/stream_executor/platform/default/dso_loader.cc:59] Could not load dynamic library 'libcudart.so.10.1'; dlerror: libcudart.so.10.1: cannot open shared object file: No such file or directory
although I installed the cuda drivers:
$ /usr/local/cuda-11.0/samples/bin/x86_64/linux/release/deviceQuery
/usr/local/cuda-11.0/samples/bin/x86_64/linux/release/deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce MX150"
  CUDA Driver Version / Runtime Version          11.1 / 11.0
  CUDA Capability Major/Minor version number:    6.1
  Total amount of global memory:                 2048 MBytes (2147483648 bytes)
  ( 3) Multiprocessors, (128) CUDA Cores/MP:     384 CUDA Cores
  GPU Max Clock rate:                            1532 MHz (1.53 GHz)
  Memory Clock rate:                             3004 Mhz
  Memory Bus Width:                              64-bit
  L2 Cache Size:                                 524288 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
  Maximum Layered 1D Texture Size, (num) layers  1D=(32768), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(32768, 32768), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 65536
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 1 copy engine(s)
  Run time limit on kernels:                     Yes
  Integrated GPU sharing Host Memory:            No
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  Device supports Unified Addressing (UVA):      Yes
  Device supports Managed Memory:                Yes
  Device supports Compute Preemption:            Yes
  Supports Cooperative Kernel Launch:            Yes
  Supports MultiDevice Co-op Kernel Launch:      Yes
  Device PCI Domain ID / Bus ID / location ID:   0 / 1 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.1, CUDA Runtime Version = 11.0, NumDevs = 1
Result = PASS
Should I try to install cuda driver v10.1 that tensorflow can’t find? Seems wrong to me.
The output of find /usr -name *libcudart*:
/usr/local/cuda-11.0/doc/man/man7/libcudart.7
/usr/local/cuda-11.0/doc/man/man7/libcudart.so.7
/usr/local/cuda-11.0/targets/x86_64-linux/lib/libcudart.so.11.0.221
/usr/local/cuda-11.0/targets/x86_64-linux/lib/libcudart_static.a
Did you try installing it separately?
sudo apt-get install cuda-cudart-10-1
or
sudo apt-get install libcudart10.1
Thanks for the reply.
I installed the first one, and now there is no problem with libcudart.
However, here is the output of tf.config.list_physical_devices('GPU') in python:
2020-09-15 13:54:26.701571: E tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:968] could not open file to read NUMA node: /sys/bus/pci/devices/0000:01:00.0/numa_node
Your kernel may have been built without NUMA support.
2020-09-15 13:54:27.164582: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1716] Found device 0 with properties:
pciBusID: 0000:01:00.0 name: GeForce MX150 computeCapability: 6.1
coreClock: 1.5315GHz coreCount: 3 deviceMemorySize: 2.00GiB deviceMemoryBandwidth: 44.76GiB/s
2020-09-15 13:54:27.164686: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.1
2020-09-15 13:54:27.164818: W tensorflow/stream_executor/platform/default/dso_loader.cc:59] Could not load dynamic library 'libcublas.so.10'; dlerror: libcublas.so.10: cannot open shared object file: No such file or directory
2020-09-15 13:54:27.164856: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcufft.so.10
2020-09-15 13:54:27.164868: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcurand.so.10
2020-09-15 13:54:27.164890: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcusolver.so.10
2020-09-15 13:54:27.164945: W tensorflow/stream_executor/platform/default/dso_loader.cc:59] Could not load dynamic library 'libcusparse.so.10'; dlerror: libcusparse.so.10: cannot open shared object file: No such file or directory
2020-09-15 13:54:27.165027: W tensorflow/stream_executor/platform/default/dso_loader.cc:59] Could not load dynamic library 'libcudnn.so.7'; dlerror: libcudnn.so.7: cannot open shared object file: No such file or directory
2020-09-15 13:54:27.165062: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1753] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
Skipping registering GPU devices...
and I didn’t really want to use standard tensorflow-gpu guides because they may install the linux drivers instead of using the wsl drivers
Install each missing library same way
sudo apt install cuda-cublas-10-0
sudo apt install cuda-cusparse-10-0
For libcudnn I think you need to download it separately in cuDNN Archive | NVIDIA Developer
you will need the Runtime deb file from cuDNN v7.6.5
Although it manages to find libcudnn now, it’s not the case for cublas and cusparse:
2020-09-15 14:36:41.488086: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcuda.so.1
2020-09-15 14:36:42.474206: E tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:968] could not open file to read NUMA node: /sys/bus/pci/devices/0000:01:00.0/numa_node
2020-09-15 14:36:42.474484: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1716] Found device 0 with properties:
2020-09-15 14:36:42.474552: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.1
2020-09-15 14:36:42.474718: W tensorflow/stream_executor/platform/default/dso_loader.cc:59] Could not load dynamic library 'libcublas.so.10'; dlerror: libcublas.so.10: cannot open shared object file: No such file or directory
2020-09-15 14:36:42.476096: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcufft.so.10
2020-09-15 14:36:42.476432: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcurand.so.10
2020-09-15 14:36:42.479048: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcusolver.so.10
2020-09-15 14:36:42.479140: W tensorflow/stream_executor/platform/default/dso_loader.cc:59] Could not load dynamic library 'libcusparse.so.10'; dlerror: libcusparse.so.10: cannot open shared object file: No such file or directory
2020-09-15 14:36:42.481933: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudnn.so.7
2020-09-15 14:36:42.481980: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1753] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
Maybe you need another version of the libraries. You can search for the packages you need like this sudo apt search cublas
Install CUDA using the runfile method
wget http://developer.download.nvidia.com/compute/cuda/10.1/Prod/local_installers/cuda_10.1.243_418.87.00_linux.run
chmod +x cuda_10.1.243_418.87.00_linux.run
sudo sh cuda_10.1.243_418.87.00_linux.run
Do not install Nvidia-Driver, NVML is currently not supported so you won’t be able to run nvidia-smi
Export path to .bashrc
export PATH=/usr/local/cuda/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda/lib64/${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
Then install cuDNN for v10.1 - v7.6.5.32-1 using the deb file method:
sudo dpkg -i libcudnn7_7.6.5.32-1+cuda10.1_amd64.deb
sudo dpkg -i libcudnn7-dev_7.6.5.32-1+cuda10.1_amd64.deb
sudo dpkg -i libcudnn7-doc_7.6.5.32-1+cuda10.1_amd64.deb
Hopefully, TensorFlow will be able to detect your GPU inside WSL2
I don’t know why but my libcublas is installed under /usr/local/cuda-10.2. If you add it to your LD path everything works fine. Those 4 lines are inside my .zshrc
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/cuda/extras/CUPTI/lib64
export LD_LIBRARY_PATH=/usr/local/cuda-10.1/lib64:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH=/usr/local/cuda-10.2/lib64:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH=/usr/local/cuda-10.1/include:$LD_LIBRARY_PATH
