I get hundreds of these sorts of errors when trying to build CTranslate2 against CUDA 12.2.0 with GCC 13.1:
/usr/include/bits/mathcalls.h(101): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(104): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(107): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(110): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(53): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(55): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(57): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(59): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(62): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(64): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(66): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(71): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(73): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(75): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(79): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(85): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(87): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(89): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(95): error: identifier "_Float32" is undefined
/usr/include/bits/mathcalls.h(98): error: identifier "_Float32" is undefined
/usr/include/stdlib.h(141): error: identifier "_Float32" is undefined
/usr/include/stdlib.h(147): error: identifier "_Float64" is undefined
/usr/include/stdlib.h(153): error: identifier "_Float128" is undefined
/usr/include/stdlib.h(159): error: identifier "_Float32x" is undefined
/usr/include/stdlib.h(165): error: identifier "_Float64x" is undefined
/usr/include/stdlib.h(234): error: identifier "_Float32" is undefined
/usr/include/stdlib.h(240): error: identifier "_Float64" is undefined
/usr/include/stdlib.h(246): error: identifier "_Float128" is undefined
/usr/include/stdlib.h(252): error: identifier "_Float32x" is undefined
/usr/include/stdlib.h(258): error: identifier "_Float64x" is undefined
/usr/include/stdlib.h(317): error: identifier "_Float32" is undefined
/usr/include/stdlib.h(324): error: identifier "_Float64" is undefined
/usr/include/stdlib.h(331): error: identifier "_Float128" is undefined
/usr/include/stdlib.h(338): error: identifier "_Float32x" is undefined
/usr/include/stdlib.h(345): error: identifier "_Float64x" is undefined
Error limit reached.
100 errors detected in the compilation of "/tmp/CTranslate2/src/ops/topp_mask_gpu.cu".
Compilation terminated.
CMake Error at ctranslate2_generated_topp_mask_gpu.cu.o.Release.cmake:280 (message):
Error generating file
/tmp/usr/CTranslate2/build/CMakeFiles/ctranslate2.dir/src/ops/./ctranslate2_generated_topp_mask_gpu.cu.o
make[2]: *** [CMakeFiles/ctranslate2.dir/build.make:14853: CMakeFiles/ctranslate2.dir/src/ops/ctranslate2_generated_topp_mask_gpu.cu.o] Fehler 1
make[1]: *** [CMakeFiles/Makefile2:137: CMakeFiles/ctranslate2.dir/all] Fehler 2
make: *** [Makefile:136: all] Fehler 2
Is there a workaround to this that doesn’t involve downgrading GCC?
The docs say 12.2 is the latest supported version.
