texture references were deprecated and are now no longer supported in recent CUDA versions. You should now use texture objects. See here and here and here You can find many codes on various forums that show how to use texture objects.
Related topics
| CUDA 12.9, failed to compile VS 2022 on Window | 1 | 75 | January 21, 2026 | |
| Unable to use cuda with visual studio 2022 | 3 | 4086 | March 22, 2023 | |
| Using Win11 VS & CUDA, trying to just build some solution samples, endless MSB4019's | 2 | 132 | January 15, 2025 | |
| Nothing with CUDA works on this 1 device | 4 | 1146 | March 8, 2023 | |
| Nvcc fatal : Host compiler targets unsupported OS. (GPU=MX150, CUDA, Win 11 Pro, VS 2022/17.8.2) | 2 | 682 | December 4, 2023 | |
| CUDA Toolkit support for VS 2022 | 4 | 5667 | May 13, 2022 | |
| Trouble verifying CUDA installation on Windows 10 using cuda-samples and Visual Studio | 1 | 562 | May 14, 2024 | |
| Problems with latest vs2022 update | 15 | 10750 | April 11, 2025 | |
| Compatibility Issue for Visual Studio 2019 | 4 | 1339 | April 24, 2023 | |
| Unable to compile cuda kernel in Visual Studio 2022 MSB6003 The specified task executable "cl.exe" could not be run | 0 | 128 | June 22, 2025 |
