CUDA 2.0 Beta 2 GTX support, more Linux distros...
We’re releasing a new CUDA 2.0 beta today. Support for GT200-based cards with new features (double precision, shared atomics, voting, double registers–compile with --arch compute_13), more documentation, more support for newer Linux distributions. more examples, and more…
It should be on the website soon, but in the interim, download links:
Linux 177.13 driver for x86
Linux 177.13 driver for x86-64
UPDATED WINDOWS DRIVERS - now works on all CUDA cards
This is a beta driver intended for CUDA development only.
WinXP 177.35 driver
WinXP 64-bit 177.35 driver
Vista 32-bit 177.35 driver
Vista 64-bit 177.35 driver
CUDA Toolkit 2.0b2:
Fedora 8 x86
Fedora 8 x86-64
RHEL 4.6 x86
RHEL 4.6 x86-64
RHEL 5.1 x86
RHEL 5.1 x86-64
SuSE 10.2 x86
SuSE 10.2 x86-64
SuSE 10.3 x86
SuSE 10.3 x86-64
SLED 10 SP1 x86
SLED 10 SP1 x86-64
Ubuntu 7.04 x86
Ubuntu 7.04 x86-64
Ubuntu 7.10 x86
Ubuntu 7.10 x86-64
32-bit WinXP or Vista
64-bit WinXP or Vista
CUDA SDK 2.0b2:
UPDATED WINDOWS RELEASE
Fixes glew64.dll errors.
Linux
CUDA Visual Profiler:
Windows
Linux
Docs (included, but in case you’re curious before downloading):
CUDA 2.0b2 Programmers Guide
CUDA 2.0b2 Programmers Guide Revision History
CUDA 2.0b2 Reference Manual
CUDA 2.0b2 SDK Release Notes - Windows
CUDA 2.0b2 SDK Release Notes - Linux
CUDA 2.0b2 Visual Profiler Readme
CUDA 2.0b2 Visual Profiler Release Notes - Windows
CUDA 2.0b2 Visual Profiler Release Notes - Linux
so what is about the osx users which are still stuck with 1.1 beta…
do we get some love too?
The new beta installed fine in Suse 10.3 and seems to work fine - SDK compiled, tests passed, etc. Thx.
The new beta does not seem to want to let me overclock my 8800GT like the previous beta, however. Attempts to do so have locked up the system. Before I was getting 600->700 MHz core, 900->1000 MHz memory, now not so much. The autoscan for overclocking in nvidia-settings suggested 700/1100, which promptly froze the system.
(AMD Phenom 9600 on a Gigabyte MA790X motherboard; PNY 8800GT.)
(Still searching for code for matrix division: solution to A*X=B; glimmers of happiness over the horizon, but no joy yet…)
It seems that the 177.35 driver for windows only support GT200 gpu.
Which version is the best for g80/g92 gpu?
  1. The 177.35 don’t work with my GF8500GT/GF8600GTS under Vista x64(SP1).
  2. On the other hand, to separate the x86 and x64 installers is a very bad idea… because if I want to cross-compile from Vista x64 to winXP 32 I cannot… the toolkit says it’s already installed and I need to uninstall it… why you cannot just make one installer and deploy the DLLS and .LIBs into two different folders(x86 and x64)? External Image
  3. On the other hand you continue deploying only the /MT(Multithreaded ) cudart.lib… For IJW/CLI/CLR/.NET/.NET STL we NEED also the /MD ( Multithreaded DLL) libraries <img src=‘http://hqnveipbwb20/public/style_emoticons/<#EMO_DIR#>/crying.gif’ class=‘bbc_emoticon’ alt=‘:’(’ /> If not, it’s impossible to link the CUDA libraries without getting a zillion of linking errors, /NODEFAULTLIB problems, etc…
  4. And, finally, the libraries generates memory leaks under VS2008… because the deployment you did its for VS2005… and the VS2008 crt is different…
For example… see the FBX SDK… Autodesk deploys the .LIB as:
fbx_vs2003_mt.lib → x86, Multithread for Visual Studio 2003
fbx_vs2003_md.lib → x86, Multithread DLL for Visual Studio 2003
fbx_vs2003_mtd.lib → x86, Multithread Debug for Visual Studio 2003
fbx_vs2003_mdd.lib → x86, Multithread DLL Debug for Visual Studio 2003
fbx_vs2003_mt_x64.lib → x64, Multithread for Visual Studio 2003
fbx_vs2003_md_x64.lib → x64, Multithread DLL for Visual Studio 2003
fbx_vs2003_mtd_x64.lib → x64, Multithread Debug for Visual Studio 2003
fbx_vs2003_mdd_x64.lib → x64, Multithread DLL Debug for Visual Studio 2003
fbx_vs2005_mt.lib → x86, Multithread for Visual Studio 2005
fbx_vs2005_md.lib → x86, Multithread DLL for Visual Studio 2005
fbx_vs2005_mtd.lib → x86, Multithread Debug for Visual Studio 2005
fbx_vs2005_mdd.lib → x86, Multithread DLL Debug for Visual Studio 2005
fbx_vs2005_mt_x64.lib → x64, Multithread for Visual Studio 2005
fbx_vs2005_md_x64.lib → x64, Multithread DLL for Visual Studio 2005
fbx_vs2005_mtd_x64.lib → x64, Multithread Debug for Visual Studio 2005
fbx_vs2005_mdd_x64.lib → x64, Multithread DLL Debug for Visual Studio 2005
fbx_vs2008_mt.lib → x86, Multithread for Visual Studio 2008
fbx_vs2008_md.lib → x86, Multithread DLL for Visual Studio 2008
fbx_vs2008_mtd.lib → x86, Multithread Debug for Visual Studio 2008
fbx_vs2008_mdd.lib → x86, Multithread DLL Debug for Visual Studio 2008
fbx_vs2008_mt_x64.lib → x64, Multithread for Visual Studio 2008
fbx_vs2008_md_x64.lib → x64, Multithread DLL for Visual Studio 2008
fbx_vs2008_mtd_x64.lib → x64, Multithread Debug for Visual Studio 2008
fbx_vs2008_mdd_x64.lib → x64, Multithread DLL Debug for Visual Studio 2008
That’s a correct deployment… the current CUDA 2 toolkit/sdk is incomplete… because without that you will get lots of problems with .NET and memory leaks due to C CRT incompatibilities… If you could add a very simple Managed C++/CLR/IJW/WinForms/.NET STL example to the SDK you could see what i’m referrering to…
  1. some examples complain because can’t find glew64.dll
Installed and on XP64 and it seems to work fine except for the demos requiring glew64.dll.
External Image
Any idea why it is not part of the distrib?
I agree with the above issues regarding the /MD and cross compiling.
But I am already quite happy to have a GTX280 and a CUDA version for it so soon :)
Good work guys. External Image
The driver does not work with FX570m on Vista, even with a modded .inf. Very sad :(
However, on XP it works (with modded .inf), and slightly faster than the previous.
has anyone successfully installed the new driver 177.35 (NVIDIADisplayWin2K_177.35,…)? What kind of hardware is required?
I tried to install two drivers on two different setups:
Windows XP (x86), GeForce 8600 GT, NVIDIADisplayWin2K_177.35
Windows Vista (x64), GeForce 9600 GT, NVIDIADisplayWinVista64_177.35
In both cases setup is terminated:
“NVIDIA Setup Error
The NVIDIA Setup program could not locate any drivers that are compatible with your current hardware. …”
Any ideas?
Thanks & best regards
GTX280 , Driver 177.35 and CUDA 2.0 Beta 2 works fine on XP64 for me.
I have not tried yet under Vista64.
Would it be possible to have the reference manual either in HTML form or to include links within the PDF? It’s nice to be able to scroll through the list of function names and then jump straight to ones of interest.
Additionally, could you please kill the “see also” sections? Searching for a function name always finds these, but not the function you’re looking for.
Same problem here on Vista 64 + 8800GTX:
“The NVIDIA Setup program could not locate any drivers that are compatible with your current hardware.”
Hey, have you noticed the NVIDIA’s web still selects the 177.35 driver when you select the “download CUDA”? That driver does not work with GF8/9 series… only with the GTX … any idea how to fix that, pls? Touching the .ini file or…?
That is not the first time nvidia makes real mess with official driver. Somebody should be fired for such mistake. I expect after spending over 2000$ for Tesla, 9800GX2 and 790i Ultra mobo, drivers for those expensive pieces should work without mods and tweaks. Unfortunately history repeats and it looks like nvidia doesn’t feel responsible (again). Hey NGuys wtf you are doing?
This is the last time I do their job.
This is workaround for windows
  1. Find display driver 175.70 (www.guru3d.com) and download it
  2. Uninstal current Nvidia Display driver
  3. start 175.70 selfextracting exe but DO NOT install that driver
  4. find folder where exe extracts files and copy nv4_disp.inf file from that folder to some temp location
  5. start installation of 177.35 driver
  6. when setup fails (it reports error and terminate installation but all files are extracted usually in C:\NVIDIA)Winblablabla\177.35\english)
  7. take nv4_disp.inf from temp location and paste (overwrite) existing nv4_disp.inf file in 177.35\english folder
  8. start setup again
  9. now it should recognize your hardware
  10. reboot your comp
Followed steps are necessary only if you use nTune and have problems with GPU’s fan(s) when windows boot (it is necessary only once)
11. when windows boots go to folder
C:\Documents and Settings\Administrator\Local Settings\Application Data\NVIDIA Corporation\nTune\Profiles
12. using wordpad open file osbootpf.nsu
13. find lines:
GPUFAN3D0=0
GPUFAN3D1=0 // this line exists only if you have more than one GPU
GPUFAN3D2=0 // this line exists only if you have more than two GPU
and replace zeros with percentage initial values. For example if you want GPU0 fan works on 60% when windows boot then line should looks like
GPUFAN3D0=60
  1. Save changes
  2. reboot
thats it
Note: if you have new Nvidia g2xx card you shouldn’t do this because original nv4_disp.inf already has support for it
Mandrak is completely right. This is a huge mess. This driver only works for a VERY small subset of CUDA compatible cards. (just do a diff between beta1-174.55 and beta2-177.35 inf files to see) I thought about doing the workaround, but I would much rather have a “supported” driver. NV guys, any idea when you will get this fixed?? Very few people can use beta2 in its current form on windows. And how did this ever get past QA?!
if you look at your post, you see in each driver the word beta.
A simple question: Cuda 2.0 b2 (or the final version) support Visual C++ 2008?
This is a FAQ and the answer is no.
The official 175.19(released yesterday) does not support CUDA2… and I still cannot download the old-working 174.77… I only can download the 177.35 for GT200… but I need the old 174.77 because I use a GF8600GTS… but I deleted the 174.77 and now I cannot continue programming CUDA2 anymore… could you pls solve that? I think the web’s guys need to add a combo box to select your GPU… and download the 174.77 for GF8/9 or 177.35 for GTX…
We’re sorry about the driver problems–obviously there’s been a mix-up with the driver INF. We’re working on getting this fixed right now, and we should have a new driver package up for WinXP and Vista that resolves these issues.
I’ll update the first post as soon as the new driver is up.
Again, our apologies for the inconvenience.
