I tried to compile cuda sdk sample programs after installing cuda 3.2RC.
The compiler is unable to compile some of the programs, e.g. simpleTextureDrv,
vectorAddDrv, threadMigration, matrixMulDrv, deviceQueryDrv
Typical linker error:
simpleTextureDrv.cpp:(.text+0x152): undefined reference to `cuCtxCreate_v2’
my workaround: modification of some Makefiles to comment out the offending cpp file and
adding a trivial cpp (with emty main) file to please the make and compiler.
My platform:
Ubuntu 10.4
Cuda compilation tools, release 3.2, V0.2.1221
NVidia 260.19.12 driver installed from UBUNTU packages
My platform:
Ubuntu 10.4
There is your problem. The linking error you are seeing is because the linker cannot find libcuda.so in the standard paths it is looking to find it.
I am willing to get that the repackaged drivers in the Ubuntu repository either don’t include the CUDA libraries or have moved them to a non-standard place. The simple solution is only use the NVIDIA official driver distribution - then things like CUDA and OpenCL will work as advertised.
