cuda 4.2 update issue with cuda 9.1 tool kit with VS 2015
Hello Team,
Now days i am trying to update the cuda toolkit 4.2 with 9.1, installed the VS 2015 and cuda toolkit 9.1.
My application is openGL based project.
I upgraded my working solution(vs 2010 and cuda 4.2) in VS 2015, i made changes in the .vcxproj and loaded.
when compiling the solution i am getting too many errors and tried to solve but not compiled.
Please check the below errors and guide me to resolve the issue-
[b]Severity Code Description Project File Line Suppression State
Error namespace “std” has no member “min” ClothsimLib C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include\thrust\system\cuda\detail\detail\stable_merge_sort.inl 123
Error type name is not allowed ClothsimLib C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include\thrust\system\cuda\detail\detail\stable_merge_sort.inl 123
Error namespace “std” has no member “min” ClothsimLib C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include\thrust\system\detail\generic\find.inl 88
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\collision_manager.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\collision_solver\collision_manager.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\core_cloth.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\gpu_solver\core_cloth.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\collision_engine_derived.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\collision_solver\collision_engine_derived.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\block_solver_kernels.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\gpu_solver\block_solver_kernels.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\collision_engine.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\collision_solver\collision_engine.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\constraint_based_collision_engine.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\collision_solver\constraint_based_collision_engine.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\mpcg.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\gpu_solver\mpcg.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\quick_mpcg.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\gpu_solver\quick_mpcg.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\gpu_cloth_solver_block.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\gpu_solver\gpu_cloth_solver_block.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\raw_func.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\gpu_solver\raw_func.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\gpu_cloth_solver.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\gpu_solver\gpu_cloth_solver.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\SparseMatrix_block3x3.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\gpu_solver\SparseMatrix_block3x3.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error MSB3721 The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\bin\nvcc.exe” -gencode=arch=compute_30,code=“sm_30,compute_30” --use-local-env --cl-version 2015 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.1\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DNDEBUG -D_LIB -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -o x64\Debug\core_func.cu.obj “C:\Users\ivasa\Desktop\Cuda\VS2015\tuka_cloth-simulator_2015\Clothsim\solvers\gpu_solver\core_func.cu”” exited with code 2. ClothsimLib C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\BuildCustomizations\CUDA 9.1.targets 707
Error C2011 ‘HKEY__’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 239
Error C2011 ‘HMETAFILE__’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 241
Error C2011 ‘HINSTANCE__’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 242
Error C2011 ‘HRGN__’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 244
Error C2011 ‘HRSRC__’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 245
Error C2011 ‘HSPRITE__’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 246
Error C2011 ‘HLSURF__’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 247
Error C2011 ‘HSTR__’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 248
Error C2011 ‘HTASK__’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 249
Error C2011 ‘HWINSTA__’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 250
Error C2011 ‘HKL__’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 251
Error C2011 ‘_FILETIME’: ‘struct’ type redefinition Clothsim c:\program files (x86)\windows kits\8.1\include\shared\minwindef.h 263
Error C2079 ‘_WIN32_FILE_ATTRIBUTE_DATA::ftCreationTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\fileapi.h 566
Error C2079 ‘_WIN32_FILE_ATTRIBUTE_DATA::ftLastAccessTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\fileapi.h 567
Error C2079 ‘_WIN32_FILE_ATTRIBUTE_DATA::ftLastWriteTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\fileapi.h 568
Error C2079 ‘_BY_HANDLE_FILE_INFORMATION::ftCreationTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\fileapi.h 613
Error C2079 ‘_BY_HANDLE_FILE_INFORMATION::ftLastAccessTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\fileapi.h 614
Error C2079 ‘_BY_HANDLE_FILE_INFORMATION::ftLastWriteTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\fileapi.h 615
Error C2079 ‘tagRPC_EXTENDED_ERROR_INFO::FileTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\shared\rpcasync.h 286
Error C2079 ‘_CERT_INFO::NotBefore’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 2688
Error C2079 ‘_CERT_INFO::NotAfter’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 2689
Error C2079 ‘_CRL_ENTRY::RevocationDate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 2734
Error C2079 ‘_CRL_INFO::ThisUpdate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 2749
Error C2079 ‘_CRL_INFO::NextUpdate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 2750
Error C2079 ‘_CTL_INFO::ThisUpdate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 2860
Error C2079 ‘_CTL_INFO::NextUpdate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 2861
Error C2079 ‘_CERT_PRIVATE_KEY_VALIDITY::NotBefore’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 4173
Error C2079 ‘_CERT_PRIVATE_KEY_VALIDITY::NotAfter’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 4174
Error C2079 ‘_CMC_PEND_INFO::PendTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 5550
Error C2079 ‘_OCSP_BASIC_REVOKED_INFO::RevocationDate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 5939
Error C2079 ‘_OCSP_BASIC_RESPONSE_ENTRY::ThisUpdate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 5957
Error C2079 ‘_OCSP_BASIC_RESPONSE_ENTRY::NextUpdate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 5958
Error C2079 ‘_OCSP_BASIC_RESPONSE_INFO::ProducedAt’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 5978
Error C2079 ‘_CMSG_RECIPIENT_ENCRYPTED_KEY_ENCODE_INFO::Date’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 7160
Error C2079 ‘_CMSG_MAIL_LIST_RECIPIENT_ENCODE_INFO::Date’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 7236
Error C2079 ‘_CMSG_RECIPIENT_ENCRYPTED_KEY_INFO::Date’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 8023
Error C2079 ‘_CMSG_MAIL_LIST_RECIPIENT_INFO::Date’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 8054
Error C2079 ‘_CRYPTNET_URL_CACHE_PRE_FETCH_INFO::ThisUpdateTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 17305
Error C2079 ‘_CRYPTNET_URL_CACHE_PRE_FETCH_INFO::NextUpdateTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 17306
Error C2079 ‘_CRYPTNET_URL_CACHE_PRE_FETCH_INFO::PublishTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 17307
Error C2079 ‘_CRYPTNET_URL_CACHE_FLUSH_INFO::ExpireTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 17334
Error C2079 ‘_CRYPTNET_URL_CACHE_RESPONSE_INFO::LastModifiedTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 17350
Error C2079 ‘_CRYPT_TIMESTAMP_INFO::ftTime’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\wincrypt.h 20595
Error C2079 ‘_DRIVER_INFO_6A::ftDriverDate’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 691
Error C2079 'DRIVER_INFO_6W::ftDriverDate’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 710
Error C2079 'DRIVER_INFO_8A::ftDriverDate’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 753
Error C2079 'DRIVER_INFO_8A::ftMinInboxDriverVerDate’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 765
Error C2079 'DRIVER_INFO_8W::ftDriverDate’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 780
Error C2079 'DRIVER_INFO_8W::ftMinInboxDriverVerDate’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 792
Error C2079 'CORE_PRINTER_DRIVERA::ftDriverDate’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 3525
Error C2079 'CORE_PRINTER_DRIVERW::ftDriverDate’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 3532
Error C2079 ‘tagSTATSTG::mtime’ uses undefined struct 'FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\objidlbase.h 2214
Error C2079 ‘tagSTATSTG::ctime’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\objidlbase.h 2215
Error C2079 ‘tagSTATSTG::atime’ uses undefined struct 'FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\objidlbase.h 2216
Error C2079 ‘tagPROPVARIANT::::::filetime’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\propidl.h 322
Error C2079 ‘tagSTATPROPSETSTG::mtime’ uses undefined struct 'FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\propidl.h 548
Error C2079 ‘tagSTATPROPSETSTG::ctime’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\propidl.h 549
Error C2079 ‘tagSTATPROPSETSTG::atime’ uses undefined struct 'FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\propidl.h 550
Error C2011 'HKEY
Error C2011 'HMETAFILE
Error C2011 'HINSTANCE
Error C2011 'HRGN
Error C2011 'HRSRC
Error C2011 'HSPRITE
Error C2011 'HLSURF
Error C2011 'HSTR
Error C2011 'HTASK
Error C2011 'HWINSTA
Error C2011 'HKL
Error C2011 'HKEY
Error C2011 'HRGN
Error C2011 'HRSRC
Error C2011 'HLSURF
Error C2011 'HSTR
Error C2011 'HTASK
Error C2011 'HKL
Error C2011 'HKEY
Error C2011 'HRGN
Error C2011 'HRSRC
Error C2011 'HLSURF
Error C2011 'HSTR
Error C2011 'HTASK
Error C2011 'HKL
Error C2011 'HKEY
Error C2011 'HRGN
Error C2011 'HRSRC
Error C2011 'HLSURF
Error C2011 'HSTR
Error C2011 'HTASK
Error C2011 'HKL
Error C2079 ‘_DRIVER_INFO_6A::ftDriverDate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 691
Error C2079 ‘_DRIVER_INFO_6W::ftDriverDate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 710
Error C2079 ‘_DRIVER_INFO_8A::ftDriverDate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 753
Error C2079 ‘_DRIVER_INFO_8A::ftMinInboxDriverVerDate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 765
Error C2079 ‘_DRIVER_INFO_8W::ftDriverDate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 780
Error C2079 ‘_DRIVER_INFO_8W::ftMinInboxDriverVerDate’ uses undefined struct ‘_FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 792
Error C2079 ‘_CORE_PRINTER_DRIVERA::ftDriverDate’ uses undefined struct ‘FILETIME’ Clothsim c:\program files (x86)\windows kits\8.1\include\um\winspool.h 3525
Error C2011 'HKEY
Error C2011 'HRGN
Error C2011 'HRSRC
