Hi Robert,
Thanks for the reply. I increased the output verbosity to “detailed” (I tried “diagnostic” but the output was too long to successfully paste here, please let me know if there’s some way to share it if that would be informative), and now see 44 warnings in addition to the error.
The first warning is:
"Warning 1 The element 'ItemGroup' in namespace
'http://schemas.microsoft.com/developer/msbuild/2003' has invalid child element 'PropertyPageSchema' in
namespace 'http://schemas.microsoft.com/developer/msbuild/2003'. List of possible elements expected: 'Item,
Reference, COMReference, COMFileReference, Xdcmake, Bscmake, ClCompile, ClInclude, Midl, ResourceCompile,
PreLinkEvent, CustomBuildStep, Manifest, ProjectConfiguration, ProjectCapability, NativeReference,
ProjectReference, Compile, EmbeddedResource, Content, Page, Resource, ApplicationDefinition, None,
BaseApplicationManifest, Folder, Import, Service, WebReferences, WebReferenceUrl, FileAssociation,
BootstrapperFile, PublishFile, PRIResource, AppxSystemBinary, AppxReservedFileName,
AppxManifestFileNameQuery, AppxManifest, StoreAssociationFile, CodeAnalysisDependentAssemblyPaths,
CodeAnalysisDictionary, CodeAnalysisImport, Link, ResourceCompile, PreBuildEvent, PostBuildEvent' in
namespace 'http://schemas.microsoft.com/developer/msbuild/2003'. C:\Program Files
(x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets 5 10 Miscellaneous
Files"
The other warnings are similar, but referring to the element “PropertyGroup” with invalid child element “CudaBuildRulesPath” or “CudaHostItemName”; “Target” with “LogMetaData”; “ItemGroup” with “CudaCompile”; etc.
The detailed output was:
[code]1>------ Build started: Project: nbody, Configuration: Debug x64 ------
1>Build started 7/15/2019 1:32:56 AM.
1>Building with tools version “12.0”.
1>Project file contains ToolsVersion=“4.0”. This toolset may be unknown or missing, in which case you may be able to resolve this by installing the appropriate version of MSBuild, or the build may have been forced to a particular ToolsVersion for policy reasons. Treating the project as if it had ToolsVersion=“12.0”. For more information, please see MSBuild Toolset (ToolsVersion) - MSBuild | Microsoft Docs.
1>Target “_CheckForInvalidConfigurationAndPlatform” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (entry point):
1>Task “Error” skipped, due to false condition; ( ‘$(_InvalidConfigurationError)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1>Task “Warning” skipped, due to false condition; ( ‘$(_InvalidConfigurationWarning)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1>Using “Message” task from assembly “Microsoft.Build.Tasks.v12.0, Version=12.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “Message”
1> Configuration=Debug
1>Done executing task “Message”.
1>Task “Message”
1> Platform=x64
1>Task “Error” skipped, due to false condition; (‘$(OutDir)’ != ‘’ and !HasTrailingSlash(‘$(OutDir)’)) was evaluated as (‘…/…/bin/win64/Debug/’ != ‘’ and !HasTrailingSlash(‘…/…/bin/win64/Debug/’)).
1>Task “Error” skipped, due to false condition; (‘$(BaseIntermediateOutputPath)’ != ‘’ and !HasTrailingSlash(‘$(BaseIntermediateOutputPath)’)) was evaluated as (‘obj' != ‘’ and !HasTrailingSlash(‘obj')).
1>Task “Error” skipped, due to false condition; (’$(IntermediateOutputPath)’ != ‘’ and !HasTrailingSlash(‘$(IntermediateOutputPath)’)) was evaluated as (‘x64/Debug/’ != ‘’ and !HasTrailingSlash(‘x64/Debug/’)).
1>Done building target “_CheckForInvalidConfigurationAndPlatform” in project “nbody_vs2013.vcxproj”.
1>Target “_PrepareForBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.BuildSteps.Targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “Build” depends on it):
1>Task “CreateItem” skipped, due to false condition; (‘%(CustomBuild.IncludeFileToTool)’!=‘’) was evaluated as (‘’!=‘’).
1>Done building target “_PrepareForBuild” in project “nbody_vs2013.vcxproj”.
1>Target “_PrepareForReferenceResolution” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.CppBuild.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveReferences” depends on it):
1>Task “Message” skipped, due to false condition; (‘$(_REFERENCE_DEBUG)’==‘true’) was evaluated as (‘’==‘true’).
1>Done building target “_PrepareForReferenceResolution” in project “nbody_vs2013.vcxproj”.
1>Target “ComputeCrtSDKReference” skipped, due to false condition; (‘@(ClCompile)’!=‘’ and ‘$(WindowsAppContainer)’==‘true’ and ‘$(UseCrtSDKReference)’ != ‘false’) was evaluated as (‘nbody.cpp;render_particles.cpp’!=‘’ and ‘false’==‘true’ and ‘’ != ‘false’).
1>Target “BeforeResolveReferences” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveReferences” depends on it):
1>Done building target “BeforeResolveReferences” in project “nbody_vs2013.vcxproj”.
1>Target “AssignProjectConfiguration” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveReferences” depends on it):
1>Using “AssignProjectConfiguration” task from assembly “Microsoft.Build.Tasks.v12.0, Version=12.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “AssignProjectConfiguration”
1>Done executing task “AssignProjectConfiguration”.
1>Done building target “AssignProjectConfiguration” in project “nbody_vs2013.vcxproj”.
1>Target “AssignProjectConfiguration” skipped. Previously built successfully.
1>Target “_SplitProjectReferencesByFileExistence” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveProjectReferences” depends on it):
1>Task “ResolveNonMSBuildProjectOutput” skipped, due to false condition; (‘$(BuildingInsideVisualStudio)’==‘true’ and ‘@(ProjectReferenceWithConfiguration)’!=‘’) was evaluated as (‘true’==‘true’ and ‘’!=‘’).
1>Done building target “_SplitProjectReferencesByFileExistence” in project “nbody_vs2013.vcxproj”.
1>Target “_RemoveNameMetadataFromProjectReferenceItems” skipped, due to false condition; (‘@(ProjectReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “ResolveProjectReferences” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveReferences” depends on it):
1>Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and (‘$(BuildingInsideVisualStudio)’ == ‘true’ or ‘$(BuildProjectReferences)’ != ‘true’) and ‘$(VisualStudioVersion)’ != ‘10.0’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and (‘true’ == ‘true’ or ‘true’ != ‘true’) and ‘12.0’ != ‘10.0’ and ‘’ != ‘’).
1>Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and (‘$(BuildingInsideVisualStudio)’ == ‘true’ or ‘$(BuildProjectReferences)’ != ‘true’) and ‘$(VisualStudioVersion)’ == ‘10.0’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and (‘true’ == ‘true’ or ‘true’ != ‘true’) and ‘12.0’ == ‘10.0’ and ‘’ != ‘’).
1>Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘$(BuildingInsideVisualStudio)’ != ‘true’ and ‘$(BuildProjectReferences)’ == ‘true’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and ‘true’ != ‘true’ and ‘true’ == ‘true’ and ‘’ != ‘’).
1>Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘$(BuildingProject)’ == ‘true’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and ‘true’ == ‘true’ and ‘’ != ‘’).
1>Task “Warning” skipped, due to false condition; (‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘@(_MSBuildProjectReferenceNonexistent)’ != ‘’) was evaluated as (‘’ != ‘’ and ‘’ != ‘’).
1>Done building target “ResolveProjectReferences” in project “nbody_vs2013.vcxproj”.
1>Target “FindInvalidProjectReferences” skipped, due to false condition; (‘$(FindInvalidProjectReferences)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1>Target “ResolveNativeReferences” skipped, due to false condition; (‘@(NativeReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “_PrepareForReferenceResolution” skipped. Previously built successfully.
1>Target “GetFrameworkPaths” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.NetFramework.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1>Done building target “GetFrameworkPaths” in project “nbody_vs2013.vcxproj”.
1>Target “GetWinFXPath” skipped, due to false condition; ((‘@(Page)’ != ‘’ or ‘@(ApplicationDefinition)’ != ‘’ or ‘@(Resource)’ != ‘’) and (‘$(GetWinFXNativePath)’ != ‘’ or ‘$(GetWinFXWoWPath)’ != ‘’ )) was evaluated as ((‘’ != ‘’ or ‘’ != ‘’ or ‘’ != ‘’) and (‘’ != ‘’ or ‘’ != ‘’ )).
1>Target “GetReferenceAssemblyPaths” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1>Task “GetReferenceAssemblyPaths” skipped, due to false condition; (‘$(TargetFrameworkMoniker)’ != ‘’ and (‘$(_TargetFrameworkDirectories)’ == ‘’ or ‘$(_FullFrameworkReferenceAssemblyPaths)’ == ‘’)) was evaluated as (‘’ != ‘’ and (‘C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.0’ == ‘’ or ‘C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.0’ == ‘’)).
1>Done building target “GetReferenceAssemblyPaths” in project “nbody_vs2013.vcxproj”.
1>Target “SetBuildDefaultEnvironmentVariables” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.Cpp.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “PrepareForBuild” depends on it):
1>Using “SetEnv” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.Build.CppTasks.Common.dll”.
1>Task “SetEnv”
1> PATH=C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\x86_amd64;C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin;C:\Program Files (x86)\Windows Kits\8.1\bin\x86;;C:\Program Files (x86)\Microsoft SDKs\Windows\v8.1A\bin\NETFX 4.5.1 Tools;C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\Tools\bin;C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\tools;C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\ide;C:\Program Files (x86)\HTML Help Workshop;;C:\Program Files (x86)\MSBuild\12.0\bin;C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\libnvvp;;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\Program Files\MATLAB\R2018a\runtime\win64;C:\Program Files\MATLAB\R2018a\bin;C:\WINDOWS\System32\OpenSSH;C:\Program Files\Git\cmd;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit;C:\Program Files\Microsoft SQL Server\110\Tools\Binn;C:\Program Files (x86)\Microsoft SDKs\TypeScript\1.0;
1>Done executing task “SetEnv”.
1>Task “SetEnv”
1> LIB=C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\lib\amd64;C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\atlmfc\lib\amd64;C:\Program Files (x86)\Windows Kits\8.1\lib\winv6.3\um\x64;;
1>Task “SetEnv”
1> LIBPATH=C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\atlmfc\lib\amd64;C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\lib\amd64;
1>Task “SetEnv”
1> INCLUDE=C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\include;C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\atlmfc\include;C:\Program Files (x86)\Windows Kits\8.1\Include\um;C:\Program Files (x86)\Windows Kits\8.1\Include\shared;C:\Program Files (x86)\Windows Kits\8.1\Include\winrt;;
1>Done building target “SetBuildDefaultEnvironmentVariables” in project “nbody_vs2013.vcxproj”.
1>Target “SetUserMacroEnvironmentVariables” skipped, due to false condition; (‘@(BuildMacro)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “GetResolvedWinMD” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.CppBuild.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “PrepareForBuild” depends on it):
1>Done building target “GetResolvedWinMD” in project “nbody_vs2013.vcxproj”.
1>Target “PlatformPrepareForBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.Cpp.Platform.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “PrepareForBuild” depends on it):
1>Task “VCMessage” skipped, due to false condition; (‘$(_Error64bitToolsNotInstalled)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(ConfigurationPlatformExists)’ != ‘true’) was evaluated as (‘true’ != ‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(ToolsetTargetsFound)’ != ‘true’) was evaluated as (‘true’ != ‘true’).
1>Done building target “PlatformPrepareForBuild” in project “nbody_vs2013.vcxproj”.
1>Target “GetFrameworkPaths” skipped. Previously built successfully.
1>Target “GetReferenceAssemblyPaths” skipped. Previously built successfully.
1>Target “AssignLinkMetadata” skipped, due to false condition; ( ‘$(SynthesizeLinkMetadata)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1>Target “SetCABuildNativeEnvironmentVariables” in file “C:\Program Files (x86)\MSBuild\Microsoft\VisualStudio\v12.0\CodeAnalysis\Microsoft.CodeAnalysis.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “PrepareForBuild” depends on it):
1>Initializing task factory “CodeTaskFactory” from assembly “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Build.Tasks.v12.0.dll”.
1>Using “SetEnvironmentVariable” task from the task factory “Code Task Factory”.
1>Task “SetEnvironmentVariable”
1>Done executing task “SetEnvironmentVariable”.
1>Done building target “SetCABuildNativeEnvironmentVariables” in project “nbody_vs2013.vcxproj”.
1>Target “PrepareForBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.CppBuild.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1>Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’ != ‘true’ and ‘$(ConfigurationPlatformExists)’ != ‘true’) was evaluated as (‘’ != ‘true’ and ‘true’ != ‘true’).
1>Using “MakeDir” task from assembly “Microsoft.Build.Tasks.v12.0, Version=12.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “MakeDir”
1>Done executing task “MakeDir”.
1>Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(WindowsAppContainer)’==‘true’ and ‘$(ConfigurationType)’!=‘Application’ and ‘$(ConfigurationType)’!=‘DynamicLibrary’ and ‘$(ConfigurationType)’!=‘StaticLibrary’) was evaluated as (‘’!=‘true’ and ‘false’==‘true’ and ‘Application’!=‘Application’ and ‘Application’!=‘DynamicLibrary’ and ‘Application’!=‘StaticLibrary’).
1>Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’ and (‘$(TargetFrameworkVersion)’==‘v3.5’ or ‘$(TargetFrameworkVersion)’==‘v3.0’ or ‘$(TargetFrameworkVersion)’==‘v2.0’ )) was evaluated as (‘’!=‘true’ and ‘C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC'==’’ and ‘’ != ‘true’ and (‘v4.0’==‘v3.5’ or ‘v4.0’==‘v3.0’ or ‘v4.0’==‘v2.0’ )).
1>Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’ and ‘$(PlatformToolset)’==‘v90’) was evaluated as (‘’!=‘true’ and ‘C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC'==’’ and ‘’ != ‘true’ and ‘v120’==‘v90’).
1>Task “VCMessage” skipped, due to false condition; (‘$(VCInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’) was evaluated as (‘C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC'==’’ and ‘’ != ‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(WindowsSDKDir)’==‘’ and ‘$(UseEnv)’ != ‘true’) was evaluated as (‘C:\Program Files (x86)\Windows Kits\8.1'==’’ and ‘’ != ‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(IntDirTrailingSlashWarning)’==‘true’) was evaluated as (‘’==‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(OutDirTrailingSlashWarning)’==‘true’) was evaluated as (‘’==‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘%(CompatibilityIssues.Identity)’ != ‘’ and ‘$(DesignTimeBuild)’!=‘true’) was evaluated as (‘’ != ‘’ and ‘’!=‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(_MBCS_Using)’ == ‘true’ and ‘$(_MBCS_Installed)’ != ‘true’ and ‘$(DesignTimeBuild)’ != ‘true’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘true’ and ‘’ != ‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(IgnoreWarnIntDirSharingDetected)’ != ‘true’ and ‘$(IntDirSharingDetected)’ == ‘true’) was evaluated as (‘’ != ‘true’ and ‘’ == ‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(IgnoreWarnIntDirInTempDetected)’ != ‘true’ and (‘$(_IntDirFullpath.StartsWith($(Tmp), true, null))’ == ‘true’ or ‘$(_IntDirFullpath.StartsWith($(Temp), true, null))’ == ‘true’ or ‘$(_OutDirFullpath.StartsWith($(Tmp), true, null))’ == ‘true’ or ‘$(_OutDirFullpath.StartsWith($(Temp), true, null))’ == ‘true’)) was evaluated as (‘’ != ‘true’ and (‘False’ == ‘true’ or ‘False’ == ‘true’ or ‘False’ == ‘true’ or ‘False’ == ‘true’)).
1>Task “MakeDir”
1>Done building target “PrepareForBuild” in project “nbody_vs2013.vcxproj”.
1>Target “GetInstalledSDKLocations” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveSDKReferences” depends on it):
1>Task “GetInstalledSDKLocations” skipped, due to false condition; (‘@(SDKReference)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Done building target “GetInstalledSDKLocations” in project “nbody_vs2013.vcxproj”.
1>Target “ResolveSDKReferences” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1>Task “ResolveSDKReference” skipped, due to false condition; (‘@(SDKReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Done building target “ResolveSDKReferences” in project “nbody_vs2013.vcxproj”.
1>Target “ResolveSDKReferences” skipped. Previously built successfully.
1>Target “ExpandSDKReferences” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1>Task “GetSDKReferenceFiles” skipped, due to false condition; (‘@(ResolvedSDKReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Done building target “ExpandSDKReferences” in project “nbody_vs2013.vcxproj”.
1>Target “ResolveAssemblyReferences” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveReferences” depends on it):
1>Task “ResolveAssemblyReference” skipped, due to false condition; (‘@(Reference)’!=‘’ or ‘@(_ResolvedProjectReferencePaths)’!=‘’ or ‘@(_ExplicitReference)’ != ‘’) was evaluated as (‘’!=‘’ or ‘’!=‘’ or ‘’ != ‘’).
1>Done building target “ResolveAssemblyReferences” in project “nbody_vs2013.vcxproj”.
1>Target “GenerateBindingRedirects” skipped, due to false condition; (‘$(AutoGenerateBindingRedirects)’ == ‘true’ and ‘$(GenerateBindingRedirectsOutputType)’ == ‘true’) was evaluated as (‘’ == ‘true’ and ‘true’ == ‘true’).
1>Target “GenerateBindingRedirectsUpdateAppConfig” skipped, due to false condition; (‘$(AutoGenerateBindingRedirects)’ == ‘true’ and ‘$(GenerateBindingRedirectsOutputType)’ == ‘true’ and Exists(‘$(_GenerateBindingRedirectsIntermediateAppConfig)’)) was evaluated as (‘’ == ‘true’ and ‘true’ == ‘true’ and Exists(‘x64/Debug/nbody_vs2013.vcxproj.nbody.exe.config’)).
1>Target “ResolveComReferences” skipped, due to false condition; (‘@(COMReference)’!=‘’ or ‘@(COMFileReference)’!=‘’) was evaluated as (‘’!=‘’ or ‘’!=‘’).
1>Target “AfterResolveReferences” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “ResolveReferences” depends on it):
1>Done building target “AfterResolveReferences” in project “nbody_vs2013.vcxproj”.
1>Target “ImplicitlyExpandDesignTimeFacades” skipped, due to false condition; (‘$(ImplicitlyExpandDesignTimeFacades)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1>Target “ResolveTestReferences” skipped, due to false condition; (‘@(Shadow)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “ResolveReferences” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “Build” depends on it):
1>Done building target “ResolveReferences” in project “nbody_vs2013.vcxproj”.
1>Target “PrepareForBuild” skipped. Previously built successfully.
1>Target “InitializeBuildStatus” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.CppBuild.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “Build” depends on it):
1>Using “ReadLinesFromFile” task from assembly “Microsoft.Build.Tasks.v12.0, Version=12.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “ReadLinesFromFile”
1>Done executing task “ReadLinesFromFile”.
1>Using “WriteLinesToFile” task from assembly “Microsoft.Build.Tasks.v12.0, Version=12.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “WriteLinesToFile”
1>Done executing task “WriteLinesToFile”.
1>Using “Touch” task from assembly “Microsoft.Build.Tasks.v12.0, Version=12.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “Touch”
1> Touching “x64/Debug/nbody.tlog\unsuccessfulbuild”.
1>Done executing task “Touch”.
1>Done building target “InitializeBuildStatus” in project “nbody_vs2013.vcxproj”.
1>Target “_SplitProjectReferencesByFileExistence” skipped. Previously built successfully.
1>Target “BuildGenerateSourcesTraverse” in file “C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “BuildGenerateSources” depends on it):
1>Task “MSBuild” skipped, due to false condition; (‘$(BuildPassReferences)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’ and ‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and ‘’ != ‘’ and ‘’ == ‘true’).
1>Done building target “BuildGenerateSourcesTraverse” in project “nbody_vs2013.vcxproj”.
1>Target “ResolveReferences” skipped. Previously built successfully.
1>Target “BeforeBuildGenerateSources” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.BuildSteps.Targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “_BuildGenerateSourcesAction” depends on it):
1>Done building target “BeforeBuildGenerateSources” in project “nbody_vs2013.vcxproj”.
1>Target “PreBuildEvent” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.CppCommon.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “_BuildGenerateSourcesAction” depends on it):
1>Task “Message” skipped, due to false condition; (‘%(PreBuildEvent.Message)’ != ‘’ and ‘%(PreBuildEvent.Command)’ != ‘’) was evaluated as (‘’ != ‘’ and ‘’ != ‘’).
1>Task “Exec” skipped, due to false condition; (‘%(PreBuildEvent.Command)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Done building target “PreBuildEvent” in project “nbody_vs2013.vcxproj”.
1>Target “CustomBuild” skipped, due to false condition; (‘@(CustomBuild)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “FxCompile” skipped, due to false condition; (‘@(FxCompile)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “SetBuildDefaultEnvironmentVariables” skipped. Previously built successfully.
1>Target “_SelectedFiles” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.CppBuild.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “CudaBuild” depends on it):
1>Done building target “_SelectedFiles” in project “nbody_vs2013.vcxproj”.
1>Target “CudaFilterSelectedFiles” skipped, due to false condition; (‘@(SelectedFiles)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “InitializeCudaHostProperties” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “AddCudaCompileMetadata” depends on it):
1>Done building target “InitializeCudaHostProperties” in project “nbody_vs2013.vcxproj”.
1>Target “AddCudaCompileMetadata” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “CudaBuild” depends on it):
1>Building target “AddCudaCompileMetadata” completely.
1>No input files were specified.
1>Using “SanitizePaths” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “SanitizePaths”
1>Done executing task “SanitizePaths”.
1>Using “SplitToItemMetadata” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “SplitToItemMetadata”
1>Done executing task “SplitToItemMetadata”.
1>Done building target “AddCudaCompileMetadata” in project “nbody_vs2013.vcxproj”.
1>Target “AddCudaCompileMetadata” skipped. Previously built successfully.
1>Target “InitializeCudaHostProperties” skipped. Previously built successfully.
1>Target “InitializeCudaProjectProperties” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “AddCudaLinkMetadata” depends on it):
1>Done building target “InitializeCudaProjectProperties” in project “nbody_vs2013.vcxproj”.
1>Target “AddCudaLinkMetadata” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “CudaBuild” depends on it):
1>Building target “AddCudaLinkMetadata” completely.
1>Using “ResolvePaths” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “ResolvePaths”
1>Done executing task “ResolvePaths”.
1>Done building target “AddCudaLinkMetadata” in project “nbody_vs2013.vcxproj”.
1>Target “AddCudaCompileDeps” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “CudaBuild” depends on it):
1>Skipping target “AddCudaCompileDeps” because all output files are up-to-date with respect to the input files.
1>Input files: bodysystemcuda.cu;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0/include\cuda_runtime.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_config.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_config.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\sal.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\ConcurrencySal.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\vadefs.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\limits.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\stddef.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\library_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\channel_descriptor.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_device_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\common_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/common_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\host_defines.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\string.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\time.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\wtime.inl;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\time.inl;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\math_functions.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\math.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\stdlib.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\cmath;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\yvals.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xkeycheck.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\use_ansi.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xtgmath.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xtr1common;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\cstdlib;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\math_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/device_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\device_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\device_double_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\device_double_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_20_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_32_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_35_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_60_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_20_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_30_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_32_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_35_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_61_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\sm_70_rt.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_fetch_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_indirect_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_indirect_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_launch_parameters.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\stdio.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\swprintf.inl;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\fstream;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\istream;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\ostream;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\ios;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xlocnum;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\climits;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\cstdio;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\streambuf;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xiosbase;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xlocale;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\cstring;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\stdexcept;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\exception;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xstddef;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\cstddef;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\initializer_list;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\eh.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\malloc.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xstring;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xmemory0;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\limits;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\ymath.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\cfloat;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\float.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\crtwrn.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\cwchar;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\wchar.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\new;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xutility;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\utility;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\iosfwd;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\crtdbg.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\type_traits;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xrefwrap;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xatomic0.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\intrin.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\setjmp.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\immintrin.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\wmmintrin.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\nmmintrin.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\smmintrin.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\tmmintrin.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\pmmintrin.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\emmintrin.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xmmintrin.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\mmintrin.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\ammintrin.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\typeinfo;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xlocinfo;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xlocinfo.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\ctype.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\locale.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xdebug;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xfacet;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\system_error;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\cerrno;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\errno.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\share.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\string;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\iterator;c:\programdata\nvidia corporation\cuda samples\v9.0\common\inc\gl\freeglut_std.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\windows.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\winapifamily.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\sdkddkver.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\excpt.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\stdarg.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\windef.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\minwindef.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\specstrings.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\specstrings_strict.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\specstrings_undef.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\driverspecs.h;c:\program files %28x86%29\windows kits\8.1\include\shared\sdv_driverspecs.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winnt.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\kernelspecs.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\basetsd.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\guiddef.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\pshpack4.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\poppack.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\pshpack2.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\pshpack8.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\apiset.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\ktmtypes.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winbase.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\apisetcconv.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\minwinbase.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\processenv.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\fileapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\debugapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\utilapiset.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\handleapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\errhandlingapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\fibersapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\namedpipeapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\profileapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\heapapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\ioapiset.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\synchapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\interlockedapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\processthreadsapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\sysinfoapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\memoryapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\threadpoollegacyapiset.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\threadpoolapiset.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\bemapiset.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\jobapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\wow64apiset.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\libloaderapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\securitybaseapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\namespaceapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\systemtopologyapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\processtopologyapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\securityappcontainer.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\realtimeapiset.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\winerror.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\timezoneapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\wingdi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\pshpack1.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winuser.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\tvout.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winnls.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\datetimeapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\stringapiset.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\wincon.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\consoleapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winver.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\verrsrc.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winreg.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\reason.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winnetwk.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\wnnc.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\cderr.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\dde.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\ddeml.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\dlgs.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\lzexpand.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\mmsystem.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\mmsyscom.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\mciapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\mmiscapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\mmiscapi2.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\playsoundapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\mmeapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\timeapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\joystickapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\nb30.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\rpc.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\rpcdce.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\rpcdcep.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\rpcnsi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\rpcnterr.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\rpcasync.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\shellapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winperf.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winsock.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\inaddr.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\wincrypt.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\bcrypt.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\ncrypt.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\dpapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winefs.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winscard.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\wtypes.h;c:\program files %28x86%29\windows kits\8.1\include\shared\rpcndr.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\rpcnsip.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\rpcsal.h;c:\program files %28x86%29\windows kits\8.1\include\shared\wtypesbase.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winioctl.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\winsmcrd.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winspool.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\prsht.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\ole2.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\objbase.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\combaseapi.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\unknwnbase.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\objidlbase.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\cguid.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\objidl.h;c:\program files %28x86%29\windows kits\8.1\include\um\unknwn.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\urlmon.h;c:\program files %28x86%29\windows kits\8.1\include\um\oleidl.h;c:\program files %28x86%29\windows kits\8.1\include\um\servprov.h;c:\program files %28x86%29\windows kits\8.1\include\um\msxml.h;c:\program files %28x86%29\windows kits\8.1\include\um\oaidl.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\propidl.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\oleauto.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\commdlg.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\stralign.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\winsvc.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\mcx.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\imm.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\ime_cmodes.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\shared\windowsx.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\GL/gl.h;C:\Program Files %28x86%29\Windows Kits\8.1\Include\um\GL/glu.h;c:\programdata\nvidia corporation\cuda samples\v9.0\common\inc\gl\freeglut_ext.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0/include\cuda_gl_interop.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0/include\cooperative_groups.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cooperative_groups_helpers.h;c:\programdata\nvidia corporation\cuda samples\v9.0\5_simulations\nbody\bodysystem.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\algorithm;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\xmemory
1>Output files: x64/Debug/bodysystemcuda.cu2047395339.deps
1>Done building target “AddCudaCompileDeps” in project “nbody_vs2013.vcxproj”.
1>Target “AddCudaCompilePropsDeps” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “CudaBuild” depends on it):
1>Skipping target “AddCudaCompilePropsDeps” because all output files are up-to-date with respect to the input files.
1>Input files: nbody_vs2013.vcxproj
1>Output files: x64/Debug/bodysystemcuda.cu.cache
1>Done building target “AddCudaCompilePropsDeps” in project “nbody_vs2013.vcxproj”.
1>Target “ValidateCudaBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “CudaBuild” depends on it):
1>Task “Error” skipped, due to false condition; (!Exists($(CudaToolkitDir))) was evaluated as (!Exists(C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0)).
1>Done building target “ValidateCudaBuild” in project “nbody_vs2013.vcxproj”.
1>Target “ValidateCudaCodeGeneration” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “CudaBuild” depends on it):
1>Building target “ValidateCudaCodeGeneration” completely.
1>Using “CountItems” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “CountItems”
1>Done executing task “CountItems”.
1>Task “Error” skipped, due to false condition; (‘%(CudaCompile.NvccCompilation)’ != ‘compile’ AND $(ValidateCudaCodeGenerationCount) > 1) was evaluated as (‘compile’ != ‘compile’ AND 7 > 1).
1>Done building target “ValidateCudaCodeGeneration” in project “nbody_vs2013.vcxproj”.
1>Target “ComputeCudaCompileOutput” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “CudaBuild” depends on it):
1>Building target “ComputeCudaCompileOutput” completely.
1>Done building target “ComputeCudaCompileOutput” in project “nbody_vs2013.vcxproj”.
1>Target “PrepareForCudaBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “CudaBuild” depends on it):
1>Using “CudaSetEnvironmentVariable” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “CudaSetEnvironmentVariable”
1> Nvda.Build.CudaTasks.CudaSetEnvironmentVariable: Setting ‘CUDAFE_FLAGS’ to ‘–sdk_dir “C:\Program Files (x86)\Windows Kits\8.1”’
1>Done executing task “CudaSetEnvironmentVariable”.
1>Done building target “PrepareForCudaBuild” in project “nbody_vs2013.vcxproj”.
1>Target “CudaBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 9.0.targets” from project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” (target “_BuildGenerateSourcesAction” depends on it):
1>Using “MSBuild” task from assembly “Microsoft.Build.Tasks.v12.0, Version=12.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “MSBuild”
1> Overriding Global Properties for project “C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\nbody_vs2013.vcxproj” with:
1> Platform=x64
1> __CompileIn=C:\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\5_Simulations\nbody\bodysystemcuda.cu
1> __CompileRelativeDir=
1> __CompileFilename=bodysystemcuda
1> __CompileOut=x64/Debug/bodysystemcuda.cu.obj
1> __ProjectDeps=
1> __Deps=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0/include\cuda_runtime.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_config.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_config.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\sal.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\ConcurrencySal.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\vadefs.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\limits.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\stddef.h;C:\Program Files %28x86%29\Microsoft Visual Studio 12.0\VC\include\crtdefs.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\library_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\channel_descriptor.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_device_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_functions.hpp;c:\program
