When I try compiling the cuda code (.cu) with nvcc (with visual studio 2008), it fails i.e. produces no results. The commands executes as a dummy statement and exits. It was working fine till recently. When I checked, all the environments have been set properly. I even tried the command line option and getting the same results, any hep is appreciated, thank you
The command below just exits
nvcc -m32 -ccbin “C:\Program Files\Microsoft Visual Studio 9.0\VC\bin” -D_DEBUG -D_WIN32 -I"D:\CUDA\include" -I"./" -I"…/…/common/inc" -I"…/…/…/shared/inc" -Xcompiler "/EHsc /W3 /nologo /Od /Zi /MTd " -maxrregcount=32 -gencode=arch=compute_10,code=“sm_10,compute_10” -gencode=arch=compute_20,code=“sm_
20,compute_20” --compile -o “Debug\test1.cu.obj” test1.cu
