CUDA compilation error (just a few)
1>------ Build started: Project: clock, Configuration: Debug Win32 ------
1>Compiling…
1>nvcc fatal : Visual Studio configuration file ‘(null)’ could not be found for installation at ‘C:/Program Files (x86)/Microsoft Visual Studio 8/VC/bin’
1>Performing Custom Build Step
1>Linking…
1>LINK : fatal error LNK1181: cannot open input file ‘.\debug\clock.obj’
1>Build log was saved at “file://c:\Program Files (x86)\NVIDIA Corporation\NVIDIA CUDA SDK\projects\clock\Debug\BuildLog.htm”
1>clock - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
I have compiled the cutil project in my SDK folder, and im getting these errors in every CUDA project i try to run. I have the custom build rules set, and i dont even know why im getting these errors. People seem to have run into this problem before and i didnt find any real solution.
Im running in Vista 64-bit, using VS2005 Professional.
Any help would be excellent!
Try building the 64-bit target.
Thanks for the reply. That worked, i can now COMPILE the project
For some reason VS didnt initially install the x64 debugger…
However, now that i can build the projects, how come its not producing an .exe for me to run/test
thanks again
sorry, didnt pay enough attention to the project i was compiling, it doesnt produce exe so problem solved!
thanks again
