I have some problem to compile CUDA files.
I have VC 2008.
I installed Cuda Tooilkit.
After that I installed CUDA SDK.
In “Custom Build Rules” i used the Cuda.rules, from SDK.
I created a new projects Win32 Console Project, assign Cuda Rules, but my problem is when I compiled some simple code, I get this error:
1>------ Build started: Project: TestCuda01, Configuration: Debug Win32 ------
1>Compiling with CUDA Build Rule...
1>"C:\CUDA\bin64\nvcc.exe" -ccbin "C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\bin" -I"C:\CUDA\include" -I"./" -I"../../common/inc" -I"../../../shared/inc" -Xcompiler "/EHsc /W3 /nologo /O2 /Zi /MT " -maxrregcount=32 -gencode=arch=compute_10,code=\"sm_10,compute_10\" -gencode=arch=compute_20,code=\"sm_20,compute_20\" --compile -o "Debug\startcuda.cu.obj" "c:\Users\administrador\Documents\Visual Studio 2008\Projects\TestCuda01\TestCuda01\startcuda.cu"
1>nvcc Hâý(Ç=y░: Visual Studio configuration file '(null)' could not be found for installation at 'C:/Program Files (x86)/Microsoft Visual Studio 9.0/VC/bin/../..'
1>Linking...
1><b>LINK : fatal error LNK1104: cannot open file '.\Debug\startcuda.cu.obj'</b>
1>Build log was saved at "file://c:\Users\administrador\Documents\Visual Studio 2008\Projects\TestCuda01\TestCuda01\Debug\BuildLog.htm"
1>TestCuda01 - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
I probed in two machines and the same error happend.
But, If I open any projects of CUDA SDK, the project compile PERFECT with the Cuda Rules.
What is the problem??..
Eduardo
