I try to setup a VISTA 64-bit machine with CUDA 2.1. I get the following error message. I tried re-installing the packages.
Your help is much appreciated,
- Wolf
1>------ Build started: Project: simpleD3D10Texture, Configuration: Debug Win32 ------
1>Compiling with CUDA Build Rule…
1>“C:\CUDA\bin\nvcc.exe” -arch sm_10 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\bin” -Xcompiler "/EHsc /W3 /nologo /Od /Zi /MTd " -IC:\CUDA\include -I./ -I…/…/common/inc -maxrregcount=32 --compile -o Debug\texture_cube.cu.obj texture_cube.cu
1>nvcc fatal : Visual Studio configuration file ‘(null)’ could not be found for installation at ‘C:/Program Files (x86)/Microsoft Visual Studio 9.0/VC/bin/…/…’
1>“C:\CUDA\bin\nvcc.exe” -arch sm_10 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\bin” -Xcompiler "/EHsc /W3 /nologo /Od /Zi /MTd " -IC:\CUDA\include -I./ -I…/…/common/inc -maxrregcount=32 --compile -o Debug\texture_3d.cu.obj texture_3d.cu
1>“C:\CUDA\bin\nvcc.exe” -arch sm_10 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\bin” -Xcompiler "/EHsc /W3 /nologo /Od /Zi /MTd " -IC:\CUDA\include -I./ -I…/…/common/inc -maxrregcount=32 --compile -o Debug\texture_2d.cu.obj texture_2d.cu
1>Linking…
1>LINK : fatal error LNK1181: cannot open input file ‘cutil32D.lib’
1>Build log was saved at “file://c:\ProgramData\NVIDIA Corporation\NVIDIA CUDA SDK\projects\simpleD3D10Texture\Debug\BuildLog.htm”
1>simpleD3D10Texture - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
