CUDA 9 on Windows 8.0
I have installed CUDA 9.0 on Windows 8 (64 bit) machine. I have Visual Studio 2012. Now, i tried to run a simple CUDA code as below:
#include <stdio.h>
#include <cuda.h>
int main(){
printf("\n Hello World ");
return 0;
Problem faced:
error MSB3721: The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" --use-local-env --cl-version 2012 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Zi /RTC1 /MDd " -o x64\Debug\test.cu.obj “D:\test_cuda\test_source\test_source\test.cu”” exited with code 1. C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets 707 9 test_source
Could anyone please inform how to resolve this error.
The proper way to verify a new CUDA install is to follow the instructions in the install guide. Did you compile and run any sample projects?
Regarding your MSB 3721 error, it’s impossible to determine the issue - you should turn up the verbosity on your VS output, so that the error from nvcc itself is displayed. After you turn up the verbosity (google for that, please), the nvcc error should be displayed right before the MSB 3721 error. Then it will be evident what the issue is.
Thanks txbob. As suggested, I did enable the verbosity output.
1>------ Build started: Project: test_nv, Configuration: Debug x64 ------
1>Build started 09-11-2017 06:32:26 PM.
1>Building with tools version “4.0”.
1>Target “_CheckForInvalidConfigurationAndPlatform” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (entry point):
1>Task “Error” skipped, due to false condition; ( ‘$(_InvalidConfigurationError)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1>Task “Warning” skipped, due to false condition; ( ‘$(_InvalidConfigurationWarning)’ == ‘true’ ) was evaluated as ( ‘’ == ‘true’ ).
1>Using “Message” task from assembly “Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “Message”
1> Configuration=Debug
1>Done executing task “Message”.
1>Task “Message”
1> Platform=x64
1>Task “Error” skipped, due to false condition; (‘$(OutDir)’ != ‘’ and !HasTrailingSlash(‘$(OutDir)’)) was evaluated as (‘D:\test_nv\test_nv\x64\Debug' != ‘’ and !HasTrailingSlash(‘D:\test_nv\test_nv\x64\Debug')).
1>Task “Error” skipped, due to false condition; (’$(BaseIntermediateOutputPath)’ != ‘’ and !HasTrailingSlash(‘$(BaseIntermediateOutputPath)’)) was evaluated as (‘obj' != ‘’ and !HasTrailingSlash(‘obj')).
1>Task “Error” skipped, due to false condition; (’$(IntermediateOutputPath)’ != ‘’ and !HasTrailingSlash(‘$(IntermediateOutputPath)’)) was evaluated as (‘x64\Debug' != ‘’ and !HasTrailingSlash(‘x64\Debug')).
1>Done building target “_CheckForInvalidConfigurationAndPlatform” in project “test_nv.vcxproj”.
1>Target “_PrepareForBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.BuildSteps.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “Build” depends on it):
1>Task “CreateItem” skipped, due to false condition; (’%(CustomBuild.IncludeFileToTool)’!=‘’) was evaluated as (‘’!=‘’).
1>Done building target “_PrepareForBuild” in project “test_nv.vcxproj”.
1>Target “_PrepareForReferenceResolution” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppBuild.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveReferences” depends on it):
1>Task “Message” skipped, due to false condition; (‘$(_REFERENCE_DEBUG)’==‘true’) was evaluated as (‘’==‘true’).
1>Done building target “_PrepareForReferenceResolution” in project “test_nv.vcxproj”.
1>Target “ComputeCrtSDKReference” skipped, due to false condition; (‘@(ClCompile)’!=‘’ and ‘$(WindowsAppContainer)’==‘true’ and ‘$(UseCrtSDKReference)’ != ‘false’) was evaluated as (‘’!=‘’ and ‘false’==‘true’ and ‘’ != ‘false’).
1>Target “BeforeResolveReferences” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveReferences” depends on it):
1>Done building target “BeforeResolveReferences” in project “test_nv.vcxproj”.
1>Target “AssignProjectConfiguration” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveReferences” depends on it):
1>Using “AssignProjectConfiguration” task from assembly “Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “AssignProjectConfiguration”
1>Done executing task “AssignProjectConfiguration”.
1>Done building target “AssignProjectConfiguration” in project “test_nv.vcxproj”.
1>Target “AssignProjectConfiguration” skipped. Previously built successfully.
1>Target “_SplitProjectReferencesByFileExistence” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveProjectReferences” depends on it):
1>Task “ResolveNonMSBuildProjectOutput” skipped, due to false condition; (‘$(BuildingInsideVisualStudio)’==‘true’ and ‘@(ProjectReferenceWithConfiguration)’!=‘’) was evaluated as (‘true’==‘true’ and ‘’!=‘’).
1>Done building target “_SplitProjectReferencesByFileExistence” in project “test_nv.vcxproj”.
1>Target “_RemoveNameMetadataFromProjectReferenceItems” skipped, due to false condition; (‘@(ProjectReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “ResolveProjectReferences” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveReferences” depends on it):
1>Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and (‘$(BuildingInsideVisualStudio)’ == ‘true’ or ‘$(BuildProjectReferences)’ != ‘true’) and ‘$(VisualStudioVersion)’ != ‘10.0’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and (‘true’ == ‘true’ or ‘true’ != ‘true’) and ‘11.0’ != ‘10.0’ and ‘’ != ‘’).
1>Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and (‘$(BuildingInsideVisualStudio)’ == ‘true’ or ‘$(BuildProjectReferences)’ != ‘true’) and ‘$(VisualStudioVersion)’ == ‘10.0’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and (‘true’ == ‘true’ or ‘true’ != ‘true’) and ‘11.0’ == ‘10.0’ and ‘’ != ‘’).
1>Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘$(BuildingInsideVisualStudio)’ != ‘true’ and ‘$(BuildProjectReferences)’ == ‘true’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and ‘true’ != ‘true’ and ‘true’ == ‘true’ and ‘’ != ‘’).
1>Task “MSBuild” skipped, due to false condition; (‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘$(BuildingProject)’ == ‘true’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and ‘true’ == ‘true’ and ‘’ != ‘’).
1>Task “Warning” skipped, due to false condition; (‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘@(_MSBuildProjectReferenceNonexistent)’ != ‘’) was evaluated as (‘’ != ‘’ and ‘’ != ‘’).
1>Done building target “ResolveProjectReferences” in project “test_nv.vcxproj”.
1>Target “ResolveNativeReferences” skipped, due to false condition; (‘@(NativeReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “_PrepareForReferenceResolution” skipped. Previously built successfully.
1>Target “GetFrameworkPaths” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.NETFramework.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1>Done building target “GetFrameworkPaths” in project “test_nv.vcxproj”.
1>Target “GetWinFXPath” skipped, due to false condition; ((‘@(Page)’ != ‘’ or ‘@(ApplicationDefinition)’ != ‘’ or ‘@(Resource)’ != ‘’) and (‘$(GetWinFXNativePath)’ != ‘’ or ‘$(GetWinFXWoWPath)’ != ‘’ )) was evaluated as ((‘’ != ‘’ or ‘’ != ‘’ or ‘’ != ‘’) and (‘’ != ‘’ or ‘’ != ‘’ )).
1>Target “GetReferenceAssemblyPaths” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1>Task “GetReferenceAssemblyPaths” skipped, due to false condition; (‘$(TargetFrameworkMoniker)’ != ‘’ and (‘$(_TargetFrameworkDirectories)’ == ‘’ or ‘$(_FullFrameworkReferenceAssemblyPaths)’ == ‘’)) was evaluated as (‘’ != ‘’ and (‘C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.0’ == ‘’ or ‘C:\Program Files (x86)\Reference Assemblies\Microsoft\Framework.NETFramework\v4.0’ == ‘’)).
1>Done building target “GetReferenceAssemblyPaths” in project “test_nv.vcxproj”.
1>Target “SetBuildDefaultEnvironmentVariables” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.Cpp.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “PrepareForBuild” depends on it):
1>Using “SetEnv” task from assembly “Microsoft.Build.CppTasks.Common.v110, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “SetEnv”
1> PATH=C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\x86_amd64;C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin;C:\Program Files (x86)\Windows Kits\8.0\bin\x86;;C:\Program Files (x86)\Microsoft SDKs\Windows\v8.0A\bin\NETFX 4.0 Tools;C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\Tools\bin;C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\tools;C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\ide;C:\Program Files (x86)\HTML Help Workshop;C:\Windows\Microsoft.NET\Framework\v4.0.30319;;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\libnvvp;C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Microsoft\Web Platform Installer;C:\Program Files (x86)\Microsoft ASP.NET\ASP.NET Web Pages\v1.0;C:\Program Files (x86)\Windows Kits\8.0\Windows Performance Toolkit;C:\Program Files\Microsoft SQL Server\110\Tools\Binn;c:\Program Files (x86)\NVIDIA Corporation\Physx\Common;
1>Done executing task “SetEnv”.
1>Task “SetEnv” skipped, due to false condition; (‘$(_IsNativeEnvironment)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1>Task “SetEnv”
1> LIB=C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\lib\amd64;C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\atlmfc\lib\amd64;C:\Program Files (x86)\Windows Kits\8.0\lib\win8\um\x64;;
1>Task “SetEnv”
1> LIBPATH=C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\atlmfc\lib\amd64;C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\lib\amd64;
1>Task “SetEnv”
1> INCLUDE=C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\include;C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\atlmfc\include;C:\Program Files (x86)\Windows Kits\8.0\Include\um;C:\Program Files (x86)\Windows Kits\8.0\Include\shared;C:\Program Files (x86)\Windows Kits\8.0\Include\winrt;;
1>Done building target “SetBuildDefaultEnvironmentVariables” in project “test_nv.vcxproj”.
1>Target “SetUserMacroEnvironmentVariables” skipped, due to false condition; (‘@(BuildMacro)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “GetResolvedWinMD” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppBuild.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “PrepareForBuild” depends on it):
1>Done building target “GetResolvedWinMD” in project “test_nv.vcxproj”.
1>Target “PlatformPrepareForBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.Cpp.Platform.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “PrepareForBuild” depends on it):
1>Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(ConfigurationPlatformExists)’ != ‘true’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(ToolsetTargetsFound)’ != ‘true’ and ‘$(PlatformToolset)’ == ‘v100’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v110’ == ‘v100’).
1>Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(ToolsetTargetsFound)’ != ‘true’ and ‘$(PlatformToolset)’ == ‘v90’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v110’ == ‘v90’).
1>Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(ToolsetTargetsFound)’ != ‘true’ and ‘$(PlatformToolset)’ != ‘v90’ and ‘$(PlatformToolset)’ != ‘v100’) was evaluated as (‘’!=‘true’ and ‘true’ != ‘true’ and ‘v110’ != ‘v90’ and ‘v110’ != ‘v100’).
1>Done building target “PlatformPrepareForBuild” in project “test_nv.vcxproj”.
1>Target “GetFrameworkPaths” skipped. Previously built successfully.
1>Target “GetReferenceAssemblyPaths” skipped. Previously built successfully.
1>Target “PrepareForBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppBuild.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1>Using “MakeDir” task from assembly “Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “MakeDir”
1>Done executing task “MakeDir”.
1>Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(WindowsAppContainer)’==‘true’ and ‘$(ConfigurationType)’!=‘Application’ and ‘$(ConfigurationType)’!=‘DynamicLibrary’ and ‘$(ConfigurationType)’!=‘StaticLibrary’) was evaluated as (‘’!=‘true’ and ‘false’==‘true’ and ‘Application’!=‘Application’ and ‘Application’!=‘DynamicLibrary’ and ‘Application’!=‘StaticLibrary’).
1>Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’ and ($(TargetFrameworkVersion)==‘v3.5’ or $(TargetFrameworkVersion)==‘v3.0’ or $(TargetFrameworkVersion)==‘v2.0’ )) was evaluated as (‘’!=‘true’ and ‘C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC'==’’ and ‘’ != ‘true’ and (v4.0==‘v3.5’ or v4.0==‘v3.0’ or v4.0==‘v2.0’ )).
1>Task “VCMessage” skipped, due to false condition; (‘$(DesignTimeBuild)’!=‘true’ and ‘$(VCInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’ and ‘$(PlatformToolset)’==‘v90’) was evaluated as (‘’!=‘true’ and ‘C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC'==’’ and ‘’ != ‘true’ and ‘v110’==‘v90’).
1>Task “VCMessage” skipped, due to false condition; (‘$(VCInstallDir)’==‘’ and ‘$(UseEnv)’ != ‘true’) was evaluated as (‘C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC'==’’ and ‘’ != ‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(WindowsSDKDir)’==‘’ and ‘$(UseEnv)’ != ‘true’) was evaluated as (‘C:\Program Files (x86)\Windows Kits\8.0'==’’ and ‘’ != ‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(IntDirTrailingSlashWarning)’==‘true’) was evaluated as (‘’==‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘$(OutDirTrailingSlashWarning)’==‘true’) was evaluated as (‘’==‘true’).
1>Task “VCMessage” skipped, due to false condition; (‘%(CompatibilityIssues.Identity)’ != ‘’ and ‘$(DesignTimeBuild)’!=‘true’) was evaluated as (‘’ != ‘’ and ‘’!=‘true’).
1>Task “MakeDir”
1>Done building target “PrepareForBuild” in project “test_nv.vcxproj”.
1>Target “GetInstalledSDKLocations” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveSDKReferences” depends on it):
1>Task “GetInstalledSDKLocations” skipped, due to false condition; (‘@(SDKReference)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Done building target “GetInstalledSDKLocations” in project “test_nv.vcxproj”.
1>Target “ResolveSDKReferences” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1>Task “ResolveSDKReference” skipped, due to false condition; (‘@(SDKReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Done building target “ResolveSDKReferences” in project “test_nv.vcxproj”.
1>Target “ResolveSDKReferences” skipped. Previously built successfully.
1>Target “ExpandSDKReferences” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveAssemblyReferences” depends on it):
1>Task “GetSDKReferenceFiles” skipped, due to false condition; (‘@(ResolvedSDKReference)’!=‘’) was evaluated as (‘’!=‘’).
1>Done building target “ExpandSDKReferences” in project “test_nv.vcxproj”.
1>Target “FakesGenerateBeforeBuild” skipped, due to false condition; (@(Fakes) != ‘’ AND $(BuildingProject)) was evaluated as ( != ‘’ AND true).
1>Target “ResolveAssemblyReferences” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveReferences” depends on it):
1>Task “ResolveAssemblyReference” skipped, due to false condition; (‘@(Reference)’!=‘’ or ‘@(_ResolvedProjectReferencePaths)’!=‘’ or ‘@(_ExplicitReference)’ != ‘’) was evaluated as (‘’!=‘’ or ‘’!=‘’ or ‘’ != ‘’).
1>Done building target “ResolveAssemblyReferences” in project “test_nv.vcxproj”.
1>Target “ResolveComReferences” skipped, due to false condition; (‘@(COMReference)’!=‘’ or ‘@(COMFileReference)’!=‘’) was evaluated as (‘’!=‘’ or ‘’!=‘’).
1>Target “AfterResolveReferences” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “ResolveReferences” depends on it):
1>Done building target “AfterResolveReferences” in project “test_nv.vcxproj”.
1>Target “ImplicitlyExpandDesignTimeFacades” skipped, due to false condition; (‘$(ImplicitlyExpandDesignTimeFacades)’ == ‘true’) was evaluated as (‘’ == ‘true’).
1>Target “ResolveTestReferences” skipped, due to false condition; (‘@(Shadow)’!=‘’) was evaluated as (‘’!=‘’).
1>Target “ResolveReferences” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “Build” depends on it):
1>Done building target “ResolveReferences” in project “test_nv.vcxproj”.
1>Target “PrepareForBuild” skipped. Previously built successfully.
1>Target “InitializeBuildStatus” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppBuild.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “Build” depends on it):
1>Using “ReadLinesFromFile” task from assembly “Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “ReadLinesFromFile”
1>Done executing task “ReadLinesFromFile”.
1>Using “WriteLinesToFile” task from assembly “Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “WriteLinesToFile”
1>Done executing task “WriteLinesToFile”.
1>Using “Touch” task from assembly “Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “Touch”
1> Touching “x64\Debug\test_nv.unsuccessfulbuild”.
1>Done executing task “Touch”.
1>Done building target “InitializeBuildStatus” in project “test_nv.vcxproj”.
1>Target “_SplitProjectReferencesByFileExistence” skipped. Previously built successfully.
1>Target “BuildGenerateSourcesTraverse” in file “C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “BuildGenerateSources” depends on it):
1>Task “MSBuild” skipped, due to false condition; (‘$(BuildPassReferences)’ == ‘true’ and ‘@(ProjectReferenceWithConfiguration)’ != ‘’ and ‘@(_MSBuildProjectReferenceExistent)’ != ‘’ and ‘%(_MSBuildProjectReferenceExistent.BuildReference)’ == ‘true’) was evaluated as (‘’ == ‘true’ and ‘’ != ‘’ and ‘’ != ‘’ and ‘’ == ‘true’).
1>Done building target “BuildGenerateSourcesTraverse” in project “test_nv.vcxproj”.
1>Target “ResolveReferences” skipped. Previously built successfully.
1>Target “BeforeBuildGenerateSources” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.BuildSteps.Targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “_BuildGenerateSourcesAction” depends on it):
1>Done building target “BeforeBuildGenerateSources” in project “test_nv.vcxproj”.
1>Target “PreBuildEvent” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppCommon.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “_BuildGenerateSourcesAction” depends on it):
1>Task “Message” skipped, due to false condition; (‘%(PreBuildEvent.Message)’ != ‘’ and ‘%(PreBuildEvent.Command)’ != ‘’) was evaluated as (‘’ != ‘’ and ‘’ != ‘’).
1>Task “Exec” skipped, due to false condition; (‘%(PreBuildEvent.Command)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Done building target “PreBuildEvent” in project “test_nv.vcxproj”.
1>Target “CustomBuild” skipped, due to false condition; (‘@(CustomBuild)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “FxCompile” skipped, due to false condition; (‘@(FxCompile)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “SetBuildDefaultEnvironmentVariables” skipped. Previously built successfully.
1>Target “SelectedFiles" in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppBuild.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “CudaBuild” depends on it):
1>Done building target "SelectedFiles" in project “test_nv.vcxproj”.
1>Target “CudaFilterSelectedFiles” skipped, due to false condition; (‘@(SelectedFiles)’ != ‘’) was evaluated as (‘’ != ‘’).
1>Target “InitializeCudaHostProperties” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “AddCudaCompileMetadata” depends on it):
1>Done building target “InitializeCudaHostProperties” in project “test_nv.vcxproj”.
1>Target “AddCudaCompileMetadata” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “CudaBuild” depends on it):
1>Building target “AddCudaCompileMetadata” completely.
1>No input files were specified.
1>Using “SanitizePaths” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “SanitizePaths”
1>Done executing task “SanitizePaths”.
1>Using “SplitToItemMetadata” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “SplitToItemMetadata”
1>Done executing task “SplitToItemMetadata”.
1>Done building target “AddCudaCompileMetadata” in project “test_nv.vcxproj”.
1>Target “AddCudaCompileMetadata” skipped. Previously built successfully.
1>Target “InitializeCudaHostProperties” skipped. Previously built successfully.
1>Target “InitializeCudaProjectProperties” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “AddCudaLinkMetadata” depends on it):
1>Done building target “InitializeCudaProjectProperties” in project “test_nv.vcxproj”.
1>Target “AddCudaLinkMetadata” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “CudaBuild” depends on it):
1>Building target “AddCudaLinkMetadata” completely.
1>Using “ResolvePaths” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “ResolvePaths”
1>Done executing task “ResolvePaths”.
1>Done building target “AddCudaLinkMetadata” in project “test_nv.vcxproj”.
1>Target “AddCudaCompileDeps” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “CudaBuild” depends on it):
1>Building target “AddCudaCompileDeps” completely.
1>Input file “kernel.cu” is newer than output file “x64\Debug\kernel.cu-693168652.deps”.
1>Using “GenerateDeps” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “GenerateDeps”
1> C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\x86_amd64\cl.exe /E /nologo /showIncludes /TP /D__CUDACC
/DWIN32 /DWIN64 /D_DEBUG /D_CONSOLE /D_MBCS /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include” /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin" /I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include" /I. /FIcuda_runtime.h /c D:\test_nv\test_nv\test_nv\kernel.cu
1>Done executing task “GenerateDeps”.
1>Task “MakeDir”
1>Done building target “AddCudaCompileDeps” in project “test_nv.vcxproj”.
1>Target “AddCudaCompilePropsDeps” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “CudaBuild” depends on it):
1>Building target “AddCudaCompilePropsDeps” completely.
1>Output file “x64\Debug\kernel.cu.cache” does not exist.
1>Task “ReadLinesFromFile” skipped, due to false condition; (Exists(‘%(CudaCompile.PropsCacheOutputPath)’)) was evaluated as (Exists(‘x64\Debug\kernel.cu.cache’)).
1>Using “XmlPeek” task from assembly “Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “XmlPeek”
1> Found “CudaToolkitCustomDir”.
1> Found “AdditionalDeps”.
1> Found “CompileOut”.
1> Found “Include”.
1> Found “UseHostInclude”.
1> Found “Keep”.
1> Found “KeepDir”.
1> Found “GenerateRelocatableDeviceCode”.
1> Found “NvccCompilation”.
1> Found “CudaRuntime”.
1> Found “NvccPath”.
1> Found “RequiredIncludes”.
1> Found “TargetMachinePlatform”.
1> Found “InterleaveSourceInPTX”.
1> Found “CodeGeneration”.
1> Found “GPUDebugInfo”.
1> Found “GenerateLineInfo”.
1> Found “MaxRegCount”.
1> Found “PtxAsOptionV”.
1> Found “AdditionalCompilerOptions”.
1> Found “Defines”.
1> Found “UseHostDefines”.
1> Found “Emulation”.
1> Found “HostDebugInfo”.
1> Found “FastMath”.
1> Found “Optimization”.
1> Found “Runtime”.
1> Found “RuntimeChecks”.
1> Found “TypeInfo”.
1> Found “Warning”.
1> Found “AdditionalOptions”.
1> Found “CommandLineTemplate”.
1> Found “PerformDeviceLink”.
1> Found “LinkOut”.
1> Found “AdditionalLibraryDirectories”.
1> Found “UseHostLibraryDirectories”.
1> Found “AdditionalDependencies”.
1> Found “UseHostLibraryDependencies”.
1> Found “Warning”.
1> Found “Runtime”.
1> Found “Inputs”.
1>Done executing task “XmlPeek”.
1>Using “ReadMetadataLinesFromItems” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “ReadMetadataLinesFromItems”
1>Done executing task “ReadMetadataLinesFromItems”.
1>Done building target “AddCudaCompilePropsDeps” in project “test_nv.vcxproj”.
1>Target “ValidateCudaBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “CudaBuild” depends on it):
1>Task “Error” skipped, due to false condition; (!Exists($(CudaToolkitDir))) was evaluated as (!Exists(C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0)).
1>Done building target “ValidateCudaBuild” in project “test_nv.vcxproj”.
1>Target “ValidateCudaCodeGeneration” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “CudaBuild” depends on it):
1>Building target “ValidateCudaCodeGeneration” completely.
1>Using “CountItems” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “CountItems”
1>Done executing task “CountItems”.
1>Task “Error” skipped, due to false condition; (‘%(CudaCompile.NvccCompilation)’ != ‘compile’ AND $(ValidateCudaCodeGenerationCount) > 1) was evaluated as (‘compile’ != ‘compile’ AND 1 > 1).
1>Done building target “ValidateCudaCodeGeneration” in project “test_nv.vcxproj”.
1>Target “ComputeCudaCompileOutput” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “CudaBuild” depends on it):
1>Building target “ComputeCudaCompileOutput” completely.
1>Done building target “ComputeCudaCompileOutput” in project “test_nv.vcxproj”.
1>Target “PrepareForCudaBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “CudaBuild” depends on it):
1>Using “CudaSetEnvironmentVariable” task from assembly “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\Nvda.Build.CudaTasks.v9.0.dll”.
1>Task “CudaSetEnvironmentVariable”
1> Nvda.Build.CudaTasks.CudaSetEnvironmentVariable: Setting ‘CUDAFE_FLAGS’ to ‘–sdk_dir “C:\Program Files (x86)\Windows Kits\8.0”’
1>Done executing task “CudaSetEnvironmentVariable”.
1>Done building target “PrepareForCudaBuild” in project “test_nv.vcxproj”.
1>Target “CudaBuild” in file “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\BuildCustomizations\CUDA 9.0.targets” from project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” (target “_BuildGenerateSourcesAction” depends on it):
1>Using “MSBuild” task from assembly “Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a”.
1>Task “MSBuild”
1> Overriding Global Properties for project “D:\test_nv\test_nv\test_nv\test_nv.vcxproj” with:
1> Platform=x64
1> __CompileIn=D:\test_nv\test_nv\test_nv\kernel.cu
1> __CompileRelativeDir=
1> __CompileFilename=kernel
1> __CompileOut=x64\Debug\kernel.cu.obj
1> __ProjectDeps=test_nv.vcxproj
1> __Deps=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include\cuda_runtime.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_config.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_config.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\sal.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\ConcurrencySal.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\vadefs.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\limits.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\stddef.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\crtdefs.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\library_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\channel_descriptor.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_device_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_runtime_api.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\common_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/common_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\host_defines.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\string.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\time.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\wtime.inl;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\time.inl;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\math_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\host_defines.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\math.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\stdlib.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\cmath;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\yvals.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\xkeycheck.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\use_ansi.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\math.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\xtgmath.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\xtr1common;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\cstdlib;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\math_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\channel_descriptor.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\channel_descriptor.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/device_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\device_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\device_double_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\device_double_functions.hpp;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_20_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_32_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_35_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_32_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_60_atomic_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_20_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_30_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_32_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_35_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_32_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\sm_61_intrinsics.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\sm_70_rt.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_fetch_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\cuda_texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_indirect_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_indirect_functions.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\builtin_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\driver_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\surface_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\texture_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\crt/host_defines.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\device_launch_parameters.h;c:\program files\nvidia gpu computing toolkit\cuda\v9.0\include\vector_types.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include\cuda_runtime.h;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include\device_launch_parameters.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\stdio.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\crtdefs.h;C:\Program Files %28x86%29\Microsoft Visual Studio 11.0\VC\include\swprintf.inl
1> __AdditionalDependencies=
1> __SelectedFilesDep=
1> __ExcludedFromBuild=
1> __ExecutionDescription=Compiling CUDA source file kernel.cu…
1> __ExclusionDescription=Skipping CUDA source file kernel.cu %28excluded from build%29.
1> __Api=Runtime
1> __AdditionalCompilerOptions=
1> __AdditionalDeps=
1> __Include=;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include
1> __GenerateRelocatableDeviceCode=false
1> __NvccCompilation=compile
1> __CudaRuntime=Static
1> __NvccPath=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin\nvcc.exe
1> __RequiredIncludes=C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include
1> __TargetMachinePlatform=64
1> __InterleaveSourceInPTX=false
1> __CodeGeneration=arch=compute_30,code="sm_30,compute_30"
1> __GPUDebugInfo=true
1> __GenerateLineInfo=false
1> __Keep=false
1> __KeepDir=x64\Debug
1> __MaxRegCount=0
1> __PtxAsOptionV=false
1> __Defines=WIN32 WIN64 _DEBUG _CONSOLE _MBCS
1> __Emulation=false
1&
1>Task “CudaCompile”
1> cmd.exe /C “C:\Users\admin\AppData\Local\Temp\tmp78ac6fd35f424f9aa70d3fc39ae882f5.cmd”
1> “C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" --use-local-env --cl-version 2012 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Zi /RTC1 /MDd " -o x64\Debug\kernel.cu.obj “D:\test_nv\test_nv\test_nv\kernel.cu”
1>
1> D:\test_nv\test_nv\test_nv>“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" --use-local-env --cl-version 2012 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Zi /RTC1 /MDd " -o x64\Debug\kernel.cu.obj “D:\test_nv\test_nv\test_nv\kernel.cu”
1> nvcc fatal : Failed to detect host compiler properties.
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\v110\BuildCustomizations\CUDA 9.0.targets(707,9): error MSB3721: The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin\nvcc.exe” -gencode=arch=compute_30,code="sm_30,compute_30" --use-local-env --cl-version 2012 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\x86_amd64” -x cu -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include” -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /Od /Zi /RTC1 /MDd " -o x64\Debug\kernel.cu.obj “D:\test_nv\test_nv\test_nv\kernel.cu”” exited with code 1.
1>Done executing task “CudaCompile” – FAILED.
1>Done building target “CudaBuildCore” in project “test_nv.vcxproj” – FAILED.
1>Done executing task “MSBuild” – FAILED.
1>Done building target “CudaBuild” in project “test_nv.vcxproj” – FAILED.
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:00.46
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Something about your install or setup is broken. nvcc is not able to locate or use the host compiler (VS 2012) correctly.
Were you able to build CUDA sample projects correctly?
Thanks txbob. I am unable to build the sample projects also.
I installed the drivers first, Visual studio second and then the CUDA toolkit 9.0. the setup finished successfully. Could you please suggest, how do I fix this problem?
It may be that you have an incorrect version of VS2012 installed. I am not able to determine the issue from this output.
Hi txbob,
I have Windows 8 (64 bit) OS. There are two NVIDIA cards - Telsa K20 C and Quadro K2000 (Fujitsu Workstation).
I am trying to install CUDA 9.0 on this configuration. I have also installed Visual Studio 2012 and test it by building a VC++ project which works fine.
The issue faced is either the drivers are not installed properly or I am missing some settings in Visual Studio towards integrating CUDA tools.
How can check if the driver is installed properly?
How can I get proper settings in Visual studio? I followed the steps mentioned in installation guide for windows.
Please see the snapshot of the summary message got after installing CUDA 9.0 toolkit. The message does not mention about installation status of CUDA.
