I’d really like to avoid reinstalling the OS, since I have many programs, data, etc.
Edit: also because I spent two days just getting sound to work because Mint’s audio drivers refused to work with my motherboard, so I spent two days rebooting and cursing before finally finding out what to do.
But I’m relatively new to Linux, so I really don’t know, maybe that’s the way to go - or it may be the way to go exactly because of that.
As you say, I did install first from installer file, then I did
sudo apt-get install nvidia-cuda-toolkit
Things started to get downhill from that point on.
So for another try at this, I read the Linux Getting Started guide and uninstalled CUDA, but couldn’t uninstall driver runfile with this:
sudo /usr/bin/nvidia-uninstall
sudo: /usr/bin/nvidia-uninstall: command not found
I also did this:
sudo apt-get uninstall nvidia-cuda-toolkit
Then I reinstalled CUDA 7.5 from the runfile.
Then I read the thread here: https://devtalk.nvidia.com/default/topic/760872/ubuntu-12-04-error-cudagetdevicecount-returned-30/
deviceQuery still says:
deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 30
-> unknown error
Result = FAIL
Commands from the mentioned thread return these results:
nvidia-settings -q NvidiaDriverVersion
Attribute 'NvidiaDriverVersion' (virostatiq:0.0): 352.63
Attribute 'NvidiaDriverVersion' (virostatiq:0[gpu:0]): 352.63
uname -r
3.16.0-38-generic
cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 352.63 Sat Nov 7 21:25:42 PST 2015
GCC version: gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04)
lsmod | grep -i nvidia
nvidia_uvm 76757 0
nvidia 8642894 59 nvidia_uvm
drm 311018 5 i915,drm_kms_helper,nvidia
That below the reason I installed nvidia cuda toolkit via apt over runfile install the last time. Before that it returned something that I read it should, I forgot exactly why.
nvcc -V
The program 'nvcc' is currently not installed. You can install it by typing:
nvidia-smi
Fri Dec 25 15:49:01 2015
| NVIDIA-SMI 352.63 Driver Version: 352.63 |
| 0 GeForce GTX 980 Ti Off | 0000:01:00.0 On | N/A |
| 0% 51C P8 17W / 250W | 307MiB / 6143MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 4157 G /usr/bin/X 174MiB |
| 0 4336 G cinnamon 41MiB |
| 0 4488 G ...s-passed-by-fd --v8-snapshot-passed-by-fd 67MiB |
cat /etc/ld.so.conf.d/nvidia-lib64.conf
cat: /etc/ld.so.conf.d/nvidia-lib64.conf: No such file or directory
sudo modinfo nvidia-352-uvm
filename: /lib/modules/3.16.0-38-generic/kernel/drivers/video/nvidia_352_uvm.ko
supported: external
license: MIT
srcversion: A347F556C35EE8E88DF9DEB
depends: nvidia
vermagic: 3.16.0-38-generic SMP mod_unload modversions
parm: NVuvm_prefetch_stats:int
parm: NVuvm_prefetch_threshold:int
parm: NVuvm_prefetch_adaptive:int
parm: NVuvm_prefetch_epoch:int
parm: NVuvm_prefetch_sparsity_inc:int
parm: NVuvm_prefetch_sparsity_dec:int
parm: NVuvm_prefetch:int
sudo update-alternatives --config x86_64-linux-gnu_gl_conf
There are 3 choices for the alternative x86_64-linux-gnu_gl_conf (providing /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf).
Selection Path Priority Status
0 /usr/lib/nvidia-352/ld.so.conf 8604 auto mode
1 /usr/lib/nvidia-352-prime/ld.so.conf 8603 manual mode
* 2 /usr/lib/nvidia-352/ld.so.conf 8604 manual mode
3 /usr/lib/x86_64-linux-gnu/mesa/ld.so.conf 500 manual mode
Contents of /usr/lib/nvidia-352-prime/ld.so.conf:
/usr/lib/i386-linux-gnu/mesa
Contents of /usr/lib/nvidia-352/ld.so.conf:
/usr/lib/nvidia-352
/usr/lib32/nvidia-352
Is there anything I can do to avoid OS reinstall? I’m afraid wrong settings may now be in many files, and short of finding them all it’s impossible, but I’m willing to try.
I’d be very grateful for any help.
Thanks,
Marko
