Installing the NVIDIA display driver…
The driver installation is unable to locate the kernel source. Please make sure that the kernel source packages are installed and set up correctly.
If you know that the kernel source packages are installed and set up correctly, you may pass the location of the kernel source with the ‘–kernel-source-path’ flag.
Installing Nvidia CUDA 8.0 on Ubuntu 16.04 for Linux GPU Computing (New...
If you want to train deep neural networks, you should probably be familiar with packages like Caffe, Keras, TensorFlow, Theano, and Torch. These libraries use GPU computation power that you will probably want to use to further speed up training,...
