Installing the NVIDIA display driver…
The driver installation is unable to locate the kernel source. Please make sure that the kernel source packages are installed and set up correctly.
If you know that the kernel source packages are installed and set up correctly, you may pass the location of the kernel source with the ‘–kernel-source-path’ flag.
= Summary =
Driver: Installation Failed
Toolkit: Installation skipped
Samples: Not Selected
gtx1080+i7+ubuntu-14.04.5-desktop-amd64
sudo vi /etc/modprobe.d/blacklist-nouveau.conf
write content
blacklist nouveau
options nouveau modeset=0
reboot system
sudo service lightdm stop
sudo service lightdm stop sudo update-initramfs -u sudo ./cuda_8.0.61_375.26_linux.run
anyone helps?
