I am trying to set up a Tesla K40c on Ubuntu (4.4.0-34-generic), but the driver installer NVIDIA-Linux-x86_64-352.99.run recommended by the nvidia website for this configuration dies as follows. Running ./NVIDIA-Linux-x86_64-352.99.run with sudo produces the log file:
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Tue Aug 9 11:45:44 2016
installer version: 352.99
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> Detected 8 CPUs online; setting concurrency level to 8.
WARNING: The NVIDIA Quadro FX 1700 GPU installed in this system is supported through the NVIDIA 340.xx legacy Linux graphics drivers. Please visit http://www.nvidia.com/object/unix.html for more information. The 352.99 NVIDIA Linux graphics driver will ignore this GPU.
-> License accepted.
-> Installing NVIDIA driver version 352.99.
-> Performing CC sanity check with CC=“gcc-5.3”.
ERROR: Unable to determine the version of the kernel sources located in ‘/lib/modules/4.4.0-34-generic/build’. Please make sure you have installed the kernel source files for your kernel and that they are properly configured; on Red Hat Linux systems, for example, be sure you have the ‘kernel-source’ or ‘kernel-devel’ RPM installed. If you know the correct kernel source files are installed, you may specify the kernel source path with the ‘–kernel-source-path’ command line option.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
The kernel header and source files are installed (using apt-get) and the kernel header file exists as:
/lib/modules/4.4.0-34-generic/build/include/linux/kernel.h
Running the installer again with:
./NVIDIA-Linux-x86_64-352.99.run --kernel-source-path=/lib/modules/4.4.0-34-generic/build/include
produces log file:
creation time: Tue Aug 9 11:19:50 2016
./nvidia-installer
–kernel-source-path=/lib/modules/4.4.0-34-generic/build/include
-> Using the kernel source path ‘/lib/modules/4.4.0-34-generic/build/include’ as specified by the ‘–kernel-source-path’ commandline option.
ERROR: The kernel header file ‘/lib/modules/4.4.0-34-generic/build/include/include/linux/kernel.h’ does not exist. The most likely reason for this is that the kernel source path ‘/lib/modules/4.4.0-34-generic/build/include’ is incorrect. Please make sure you have installed the kernel source files for your kernel and that they are properly configured; on Red Hat Linux systems, for example, be sure you have the ‘kernel-source’ or ‘kernel-devel’ RPM installed. If you know the correct kernel source files are installed, you may specify the kernel source path with the ‘–kernel-source-path’ command line option.
The driver installer seems to be having trouble with the kernel source files’ path. Even when explicitly running:
for which the installer should, based on the second log output, search for and find /lib/modules/4.4.0-34-generic/build/include/linux/kernel.h, the installer dies with the following (same terminating error as the initial run):
creation time: Tue Aug 9 11:18:08 2016
./nvidia-installer
-> Using the kernel source path ‘/lib/modules/4.4.0-34-generic/build’ as specified by the ‘–kernel-source-path’ commandline option.
Any help is greatly appreciated.
