Install Nvidia driver for Tesla K40c
I upgraded my OS to ubuntu 16.04. With that my GCC version got upgraded to 5.4. I initially had CUDA 7.5 installed in my system prior to the OS upgrade. My actual intention was to install OPencv with CUDA enabled. So while i was installing OpenCV i got error in compiling CUDA files of OpenCV saying CUDA 7.5 doest support gcc 4.9 and later. So I had to go for CUDA 8.0. Now when I run
$ modinfo nv
modinfo: ERROR: Module nv not found.
AND
$ nvidia-smi
Failed to initialize NVML: Driver/library version mismatch
which made me think that I have to install Nvidia driver for Tesla K40c which i found out as nvidia-361.93.02( since my OS -Ubuntu 64 bit). Do I have to install the driver. My machine has got another Nvidia display card. My display Nvidia cards are
sudo lshw -numeric -C display
*-display
description: 3D controller
product: GK110BGL [Tesla K40c] [10DE:1024]
vendor: NVIDIA Corporation [10DE]
physical id: 0
bus info: pci@0000:05:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=nvidia latency=0
resources: irq:42 memory:ee000000-eeffffff memory:b0000000-bfffffff memory:c0000000-c1ffffff
*-display
description: VGA compatible controller
product: GK107GL [Quadro K600] [10DE:FFA]
physical id: 0
bus info: pci@0000:04:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
resources: irq:41 memory:ec000000-ecffffff memory:d0000000-dfffffff memory:e0000000-e1ffffff ioport:c000(size=128) memory:ed000000-ed07ffff
can someone guide me in this. Do i have to install the nvidia driver
I installed “sudo apt-get install nvidia-361.93.02”
I get result for $ nvidia-smi
| NVIDIA-SMI 361.42 Driver Version: 361.42 |
| 0 Quadro K600 Off | 0000:04:00.0 On | N/A |
| 25% 46C P8 N/A / N/A | 49MiB / 1023MiB | 0% Default |
| 1 Tesla K40c Off | 0000:05:00.0 Off | 0 |
| 23% 43C P8 21W / 235W | 23MiB / 11519MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1029 G /usr/lib/xorg/Xorg 0MiB |
| 0 20576 G /usr/lib/xorg/Xorg 39MiB |
Result for $ modinfo nv
No change
linux - Why does modinfo say “could not find module”, yet lsmod claims the module is loaded? - Unix & Linux Stack Exchange Why would modinfo say a module is not found when it appears with lsmod - Ask Ubuntu Found the following link which speak about modinfo and Nvidia driver [/url]
and [url]
It says run $ depmod -a
and $ modprobe --resolve-alias nvidia, from the result get the alias name and run "$ modinfo
You’ve not installed the driver correctly.
Follow the instructions in the linux install guide for CUDA 8.0 carefully.
