malcolm75 nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
malcolm76 ls -l /dev/nv*
crw-rw-rw-. 1 root root 195, 255 Jan 5 12:28 /dev/nvidiactl
crw-------. 1 root root 240, 0 Jan 4 23:27 /dev/nvme0
brw-rw----. 1 root disk 259, 0 Jan 4 23:27 /dev/nvme0n1
brw-rw----. 1 root disk 259, 1 Jan 4 23:27 /dev/nvme0n1p1
brw-rw----. 1 root disk 259, 2 Jan 4 23:27 /dev/nvme0n1p2
brw-rw----. 1 root disk 259, 3 Jan 4 23:27 /dev/nvme0n1p3
crw-------. 1 root root 240, 1 Jan 4 23:27 /dev/nvme1
brw-rw----. 1 root disk 259, 4 Jan 4 23:27 /dev/nvme1n1
crw-------. 1 root root 10, 144 Jan 4 23:27 /dev/nvram
malcolm77 lsmod | grep nvidia
malcolm78 lsmod | grep nouveau
malcolm79
I am very surprised about smi result, as I had run that before and it seemed fine. I guess it isn’t now! Malcolm
Mat, as I said, the link does not include info for Cuda 12.3. For 12.2 it recommends 535.129.03. Other Nvidia documentation states flatly 545.23.08. Where do I download this from, and where do I save it to?
Sorry I’m not clear what the issue is. As long as the CUDA Driver is newer than the CUDA SDK you’re compiling with, then you’re fine. The driver is backwards compatible except for very old devices.
Mat, the 12.3 Update Release Notes clearly say that 545.23.08 is needed. Actually, from another forum, the correct number is 545.23.06. I have found it on the Nvidia site, and installed it. I can now use nvaccelinfo, as shown below. I wonder whether this was related to earlier problem with QD? Malcolm.
malcolm189 nvaccelinfo
CUDA Driver Version: 12030
NVRM version: NVIDIA UNIX x86_64 Kernel Module 545.23.06 Sun Oct 15 17:43:11 UTC 2023
Device Number: 0
Device Name: Quadro GP100
Device Revision Number: 6.0
Global Memory Size: 17064263680
Number of Multiprocessors: 56
Concurrent Copy and Execution: Yes
Total Constant Memory: 65536
Total Shared Memory per Block: 49152
Registers per Block: 65536
Warp Size: 32
Maximum Threads per Block: 1024
Maximum Block Dimensions: 1024, 1024, 64
Maximum Grid Dimensions: 2147483647 x 65535 x 65535
Maximum Memory Pitch: 2147483647B
Texture Alignment: 512B
Clock Rate: 1442 MHz
Execution Timeout: No
Integrated Device: No
Can Map Host Memory: Yes
Compute Mode: default
Concurrent Kernels: Yes
ECC Enabled: No
Memory Clock Rate: 715 MHz
Memory Bus Width: 4096 bits
L2 Cache Size: 4194304 bytes
Max Threads Per SMP: 2048
Async Engines: 2
Unified Addressing: Yes
Managed Memory: Yes
Concurrent Managed Memory: Yes
Preemption Supported: Yes
Cooperative Launch: Yes
Default Target: cc60
malcolm190
It says that 545.23.08 is the minimum needed so more recent drivers such as the current 535.146.02 can be used as well. Though I’m glad it’s working for you.
Still unclear what was causing the CUDAROOT issue but given before you installed the drivers the CUDA version was shown in nvaccelinfo (then failed) might be an indication that the stub libcuda.so was getting picked up. (libcuda.so is the CUDA driver, and the stub library is only used to resolve symbols during linking but has no functionality).
