I have just updated my graphics driver on Windows 11. Therewith I installed the newest version of Cuda toolkits on WSL2 Ubuntu, following the instructions on the website of NVIDIA.
$ nvidia-smi
Sat Mar 30 19:31:17 2024
| NVIDIA-SMI 550.65 Driver Version: 551.86 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 2060 On | 00000000:01:00.0 On | N/A |
| N/A 45C P8 11W / 115W | 848MiB / 6144MiB | 3% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
unable-to-access-cuda-device-with-openacc-on-wsl2-ubuntu-error-code-34
I have read the post above, and set the LD_LIBRARY_PATH
in my environment to include /usr/lib/wsl/lib
, where libcuda.so
was indeed installed. To show that, I run the command below:
$ echo $LD_LIBRARY_PATH
/usr/lib/wsl/lib:/home/jack/aocl/4.2.0/aocc/lib
…@LAPTOP-NIVREMOJ:/usr/lib/wsl/lib$ sudo ls
libcuda.so
However, my nvaccelinfo
command still reports the error:
$ nvaccelinfo -v
libcuda.so not found
No accelerators found.
Check that you have installed the CUDA driver properly
Check that your LD_LIBRARY_PATH environment variable points to the CUDA runtime installation directory
I need your help.
