Nvidia-smi and nvaccelinfo doesn't work at OpenSUSE Leap Server 15.5
I have already installed HPC SDK and CUDA Toolkit on my server, and to verify that I ran nvcc --version of which the result is as follows:
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Wed_Jul_14_19:41:19_PDT_2021
Cuda compilation tools, release 11.4, V11.4.100
Build cuda_11.4.r11.4/compiler.30188945_0
nvfortran --version:
nvfortran 21.9-0 64-bit target on x86-64 Linux -tp skylake
NVIDIA Compilers and Tools
Copyright (c) 2021, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
nvc++ --version:
nvc++ 21.9-0 64-bit target on x86-64 Linux -tp skylake
Note that I’m using a deprecated version of HPC SDK, that is only to make sure the programs I’m trying to run are on par with the standalone device I was using before. However, when I run nvidia-smi or nvaccelinfo, I get these messages:
nvidia-smi:
If ‘nvidia-smi’ is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf nvidia-smi
nvaccelinfo -v:
CUDA Driver: 12060
could not initialize CUDA runtime, error code=100
No accelerators found.
Check the permissions on your CUDA device
I also tried to install the corresponding NVIDIA driver to my device.
sudo zypper in nvidia-video-G06 (installation command, repo additions are done before this stage)
inxi -G (to get the hardware info):
Graphics:
Device-1: NVIDIA GV100GL [Quadro GV100] driver: N/A
Device-2: NVIDIA GP107GL [Quadro P620] driver: N/A
Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5 driver: N/A tty: 166x45
API: OpenGL Message: GL data unavailable in console. Try -G --display
Can you help me fix this issue? Thank you in advance.
your CUDA toolkit install is broken. select the latest cuda toolkit and install it by carefully following the directions here.
Do not proceed with any further usage or validation steps until nvidia-smi returns a sensible result.
Thanks. I’ve uninstalled CUDA Toolkit from my device and reinstalled it by following the instructions. The result is still the same:
If 'nvidia-smi' is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf nvidia-smi
Are there any other suggestions to what I can do? Again, thank you in advance for your help.
you’re doing something wrong in the install process. The driver install is failing. The document indicates multiple install paths, either package manager or runfile installer. Which path did you follow?
I used the package manager, specifically, I used the network repo. I did not use the runfile installer.
probably would need to see the full console output from the install process, both your commands and the spew from the packages installation.
The following is for the driver installation:
Refreshing service 'NVIDIA'.
Refreshing service 'openSUSE'.
Loading repository data...
Reading installed packages...
Resolving package dependencies...
Problem: the to be installed nvidia-video-G06-550.120-lp155.28.1.x86_64 requires 'nvidia-compute-G06 = 550.120', but this requirement cannot be provided
  not installable providers: nvidia-compute-G06-550.120-lp155.27.1.x86_64[NVIDIA]
                   nvidia-compute-G06-550.120-lp155.28.1.x86_64[NVIDIA]
                   nvidia-compute-G06-550.120-lp155.27.1.x86_64[NVIDIA:repo-non-free]
                   nvidia-compute-G06-550.120-lp155.28.1.x86_64[NVIDIA:repo-non-free]
 Solution 1: Following actions will be done:
  downgrade of nvidia-compute-G06-560.35.03-0.x86_64 to nvidia-compute-G06-550.120-lp155.28.1.x86_64
  install nvidia-compute-G06-550.120-lp155.28.1.x86_64 from vendor obs://build.suse.de/Proprietary:X11:Drivers
    replacing nvidia-compute-G06-560.35.03-0.x86_64 from vendor  (no vendor)
  downgrade of nvidia-driver-G06-kmp-default-560.35.03_k4.12.14_lp150.12.82-0.x86_64 to nvidia-driver-G06-kmp-default-550.120_k5.14.21_150500.53-lp155.28.2.x86_64
  install nvidia-driver-G06-kmp-default-550.120_k5.14.21_150500.53-lp155.28.2.x86_64 from vendor obs://build.suse.de/Proprietary:X11:Drivers
    replacing nvidia-driver-G06-kmp-default-560.35.03_k4.12.14_lp150.12.82-0.x86_64 from vendor  (no vendor)
  downgrade of nvidia-compute-G06-32bit-560.35.03-0.x86_64 to nvidia-compute-G06-32bit-550.120-lp155.28.1.x86_64
  install nvidia-compute-G06-32bit-550.120-lp155.28.1.x86_64 from vendor obs://build.suse.de/Proprietary:X11:Drivers
    replacing nvidia-compute-G06-32bit-560.35.03-0.x86_64 from vendor  (no vendor)
  downgrade of nvidia-gl-G06-560.35.03-0.x86_64 to nvidia-gl-G06-550.120-lp155.28.1.x86_64
  install nvidia-gl-G06-550.120-lp155.28.1.x86_64 from vendor obs://build.suse.de/Proprietary:X11:Drivers
    replacing nvidia-gl-G06-560.35.03-0.x86_64 from vendor  (no vendor)
  downgrade of nvidia-gl-G06-32bit-560.35.03-0.x86_64 to nvidia-gl-G06-32bit-550.120-lp155.28.1.x86_64
  install nvidia-gl-G06-32bit-550.120-lp155.28.1.x86_64 from vendor obs://build.suse.de/Proprietary:X11:Drivers
    replacing nvidia-gl-G06-32bit-560.35.03-0.x86_64 from vendor  (no vendor)
 Solution 2: do not install nvidia-video-G06-550.120-lp155.28.1.x86_64
 Solution 3: break nvidia-video-G06-550.120-lp155.28.1.x86_64 by ignoring some of its dependencies
Choose from above solutions by number or cancel [1/2/3/c/d/?] (c): 1
Resolving dependencies...
The following 5 packages are going to be downgraded:
  nvidia-compute-G06 nvidia-compute-G06-32bit nvidia-driver-G06-kmp-default nvidia-gl-G06 nvidia-gl-G06-32bit
The following recommended package was automatically selected:
  nvidia-video-G06-32bit
The following 5 packages are going to change vendor:
  nvidia-compute-G06              -> obs://build.suse.de/Proprietary:X11:Drivers
  nvidia-compute-G06-32bit        -> obs://build.suse.de/Proprietary:X11:Drivers
  nvidia-driver-G06-kmp-default   -> obs://build.suse.de/Proprietary:X11:Drivers
  nvidia-gl-G06                   -> obs://build.suse.de/Proprietary:X11:Drivers
  nvidia-gl-G06-32bit             -> obs://build.suse.de/Proprietary:X11:Drivers
The following 7 NEW packages are going to be installed:
  kernel-default-devel-5.14.21-150500.53.2 kernel-devel-5.14.21-150500.53.2 libOpenCL1 libOpenCL1-32bit libvdpau1-32bit nvidia-video-G06 nvidia-video-G06-32bit
5 packages to downgrade, 7 new, 5  to change vendor.
Overall download size: 326,8 MiB. Already cached: 0 B. After the operation, 61,9 MiB will be freed.
Continue? [y/n/v/...? shows all options] (y): y
(Use arrows or pgUp/pgDown keys to scroll the text by lines or pages.)
In order to install 'nvidia-compute-G06-32bit', you must agree to terms of the following license agreement:
In order to install 'nvidia-compute-G06', you must agree to terms of the following license agreement:
In order to install 'nvidia-driver-G06-kmp-default', you must agree to terms of the following license agreement:
In order to install 'nvidia-gl-G06-32bit', you must agree to terms of the following license agreement:
In order to install 'nvidia-gl-G06', you must agree to terms of the following license agreement:
In order to install 'nvidia-video-G06-32bit', you must agree to terms of the following license agreement:
In order to install 'nvidia-video-G06', you must agree to terms of the following license agreement:
           License For Customer Use of NVIDIA Software
IMPORTANT NOTICE -- READ CAREFULLY: This License For Customer Use of
NVIDIA Software ("LICENSE") is the agreement which governs use of
the software of NVIDIA Corporation and its subsidiaries ("NVIDIA")
downloadable herefrom, including computer software and associated
printed materials ("SOFTWARE").  By downloading, installing, copying,
or otherwise using the SOFTWARE, you agree to be bound by the terms
of this LICENSE.  If you do not agree to the terms of this LICENSE,
do not download the SOFTWARE.
RECITALS
Use of NVIDIA's products requires three elements: the SOFTWARE, the
hardware on a graphics controller board, and a personal computer. The
SOFTWARE is protected by copyright laws and international copyright
treaties, as well as other intellectual property laws and treaties.
The SOFTWARE is not sold, and instead is only licensed for use,
strictly in accordance with this document.  The hardware is protected
by various patents, and is sold, but this agreement does not cover
that sale, since it may not necessarily be sold as a package with
the SOFTWARE.  This agreement sets forth the terms and conditions
of the SOFTWARE LICENSE only.
1.  DEFINITIONS
1.1  Customer.  Customer means the entity or individual that
downloads the SOFTWARE.
2.  GRANT OF LICENSE
2.1  Rights and Limitations of Grant.  NVIDIA hereby grants Customer
the following non-exclusive, non-transferable right to use the
SOFTWARE, with the following limitations:
2.1.1  Rights.  Customer may install and use one copy of the SOFTWARE
on a single computer, and except for making one back-up copy of
the Software, may not otherwise copy the SOFTWARE.  This LICENSE
of SOFTWARE may not be shared or used concurrently on different
computers.
2.1.2  Linux/FreeBSD Exception.  Notwithstanding the foregoing terms
of Section 2.1.1, SOFTWARE designed exclusively for use on the Linux or
FreeBSD operating systems, or other operating systems derived from the
source code to these operating systems, may be copied and redistributed,
provided that the binary files thereof are not modified in any way
(except for unzipping of compressed files).
2.1.3  Limitations.
No Reverse Engineering.  Customer may not reverse engineer,
decompile, or disassemble the SOFTWARE, nor attempt in any other
manner to obtain the source code.
No Separation of Components.  The SOFTWARE is licensed as a
single product.  Its component parts may not be separated for use
on more than one computer, nor otherwise used separately from the
other parts.
No Rental.  Customer may not rent or lease the SOFTWARE to someone
else.
3.  TERMINATION
This LICENSE will automatically terminate if Customer fails to
comply with any of the terms and conditions hereof.  In such event,
Customer must destroy all copies of the SOFTWARE and all of its
component parts.
Defensive Suspension.  If Customer commences or participates in any legal
proceeding against NVIDIA, then NVIDIA may, in its sole discretion,
suspend or terminate all license grants and any other rights provided
under this LICENSE during the pendency of such legal proceedings.
4.  COPYRIGHT
All title and copyrights in and to the SOFTWARE (including but
not limited to all images, photographs, animations, video, audio,
music, text, and other information incorporated into the SOFTWARE),
the accompanying printed materials, and any copies of the SOFTWARE,
are owned by NVIDIA, or its suppliers.  The SOFTWARE is protected
by copyright laws and international treaty provisions.  Accordingly,
Customer is required to treat the SOFTWARE like any other copyrighted
material, except as otherwise allowed pursuant to this LICENSE
and that it may make one copy of the SOFTWARE solely for backup or
archive purposes.
5.  APPLICABLE LAW
This agreement shall be deemed to have been made in, and shall be
construed pursuant to, the laws of the State of California.
6.  DISCLAIMER OF WARRANTIES AND LIMITATION ON LIABILITY
6.1  No Warranties.  TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE
LAW, THE SOFTWARE IS PROVIDED "AS IS" AND NVIDIA AND ITS SUPPLIERS
DISCLAIM ALL WARRANTIES, EITHER EXPRESS OR IMPLIED, INCLUDING, BUT
NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
FOR A PARTICULAR PURPOSE.
6.2  No Liability for Consequential Damages.  TO THE MAXIMUM
EXTENT PERMITTED BY APPLICABLE LAW, IN NO EVENT SHALL NVIDIA OR
ITS SUPPLIERS BE LIABLE FOR ANY SPECIAL, INCIDENTAL, INDIRECT, OR
CONSEQUENTIAL DAMAGES WHATSOEVER (INCLUDING, WITHOUT LIMITATION,
DAMAGES FOR LOSS OF BUSINESS PROFITS, BUSINESS INTERRUPTION, LOSS
OF BUSINESS INFORMATION, OR ANY OTHER PECUNIARY LOSS) ARISING OUT
OF THE USE OF OR INABILITY TO USE THE SOFTWARE, EVEN IF NVIDIA HAS
BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
7.  MISCELLANEOUS
The United Nations Convention on Contracts for the International
Sale of Goods is specifically disclaimed.  If any provision of this
LICENSE is inconsistent with, or cannot be fully enforced under,
the law, such provision will be construed as limited to the extent
necessary to be consistent with and fully enforceable under the law.
This agreement is the final, complete and exclusive agreement between
the parties relating to the subject matter hereof, and supersedes
all prior or contemporaneous understandings and agreements relating
to such subject matter, whether oral or written.  Customer agrees
that it will not ship, transfer or export the SOFTWARE into any
country, or use the SOFTWARE in any manner, prohibited by the
United States Bureau of Export Administration or any export laws,
restrictions or regulations.  This LICENSE may only be modified in
writing signed by an authorized officer of NVIDIA.
Do you agree with the terms of the license? [yes/no] (no): ^[[Byes
: Invalid answer 'yes'. Enter 'y' for 'yes' or 'n' for 'no' if nothing else works for you.
[yes/no] (no): y
Retrieving: kernel-devel-5.14.21-150500.53.2.noarch (repo-oss (15.5))        (1/12),  24,3 MiB
Retrieving: kernel-devel-5.14.21-150500.53.2.noarch.rpm ...........................................................................................[done (15,8 MiB/s)]
Retrieving: kernel-default-devel-5.14.21-150500.53.2.x86_64 (repo-oss (15.5))        (2/12),  13,4 MiB
Retrieving: kernel-default-devel-5.14.21-150500.53.2.x86_64.rpm ...................................................................................[done (23,2 MiB/s)]
Retrieving: libOpenCL1-2.3.1-150100.8.9.5.x86_64 (update-sle (15.5))        (3/12),  53,3 KiB
Retrieving: libOpenCL1-2.3.1-150100.8.9.5.x86_64.rpm ...............................................................................................[done (9,9 KiB/s)]
Retrieving: libOpenCL1-32bit-2.3.1-150100.8.9.5.x86_64 (update-sle (15.5))        (4/12),  45,0 KiB
Retrieving: libOpenCL1-32bit-2.3.1-150100.8.9.5.x86_64.rpm .....................................................................................................[done]
Retrieving: libvdpau1-32bit-1.1.1-150000.3.4.1.x86_64 (update-sle (15.5))        (5/12),  18,3 KiB
Retrieving: libvdpau1-32bit-1.1.1-150000.3.4.1.x86_64.rpm ......................................................................................................[done]
Retrieving: nvidia-driver-G06-kmp-default-550.120_k5.14.21_150500.53-lp155.28.2.x86_64 (NVIDIA)                                                  (6/12),  39,6 MiB
Retrieving: nvidia-driver-G06-kmp-default-550.120_k5.14.21_150500.53-lp155.28.2.x86_64.rpm ........................................................[done (12,6 MiB/s)]
Retrieving: nvidia-compute-G06-550.120-lp155.28.1.x86_64 (NVIDIA)        (7/12),  40,1 MiB
Retrieving: nvidia-compute-G06-550.120-lp155.28.1.x86_64.rpm .......................................................................................[done (9,9 MiB/s)]
Retrieving: nvidia-compute-G06-32bit-550.120-lp155.28.1.x86_64 (NVIDIA)        (8/12),  35,7 MiB
Retrieving: nvidia-compute-G06-32bit-550.120-lp155.28.1.x86_64.rpm ................................................................................[done (17,8 MiB/s)]
Retrieving: nvidia-gl-G06-550.120-lp155.28.1.x86_64 (NVIDIA)        (9/12), 138,8 MiB
Retrieving: nvidia-gl-G06-550.120-lp155.28.1.x86_64.rpm ...........................................................................................[done (17,2 MiB/s)]
Retrieving: nvidia-gl-G06-32bit-550.120-lp155.28.1.x86_64 (NVIDIA)        (10/12),  29,9 MiB
Retrieving: nvidia-gl-G06-32bit-550.120-lp155.28.1.x86_64.rpm ......................................................................................[done (9,6 MiB/s)]
Retrieving: nvidia-video-G06-550.120-lp155.28.1.x86_64 (NVIDIA)        (11/12),   2,6 MiB
Retrieving: nvidia-video-G06-550.120-lp155.28.1.x86_64.rpm .........................................................................................[done (1,9 MiB/s)]
Retrieving: nvidia-video-G06-32bit-550.120-lp155.28.1.x86_64 (NVIDIA)        (12/12),   2,3 MiB
Retrieving: nvidia-video-G06-32bit-550.120-lp155.28.1.x86_64.rpm ...................................................................................[done (1,2 MiB/s)]
Checking for file conflicts: ...................................................................................................................................[done]
Changing symlink /usr/src/linux from linux-5.14.21-150500.55.80 to linux-5.14.21-150500.53
( 1/12) Installing: kernel-devel-5.14.21-150500.53.2.noarch ....................................................................................................[done]
Changing symlink /usr/src/linux-obj/x86_64/default from ../../linux-5.14.21-150500.55.80-obj/x86_64/default to ../../linux-5.14.21-150500.53-obj/x86_64/default
( 2/12) Installing: kernel-default-devel-5.14.21-150500.53.2.x86_64 ............................................................................................[done]
( 3/12) Installing: libOpenCL1-2.3.1-150100.8.9.5.x86_64 .......................................................................................................[done]
( 4/12) Installing: libOpenCL1-32bit-2.3.1-150100.8.9.5.x86_64 .................................................................................................[done]
( 5/12) Installing: libvdpau1-32bit-1.1.1-150000.3.4.1.x86_64 ..................................................................................................[done]
make: Entering directory '/usr/src/linux-5.14.21-150500.53-obj/x86_64/default'
  MODPOST /usr/src/kernel-modules/nvidia-550.120-default/Module.symvers
make: Leaving directory '/usr/src/linux-5.14.21-150500.53-obj/x86_64/default'
/usr/src/kernel-modules/nvidia-550.120-default /
make[1]: Entering directory '/usr/src/linux-5.14.21-150500.53'
make[2]: Entering directory '/usr/src/linux-5.14.21-150500.53-obj/x86_64/default'
  SYMLINK /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-kernel.o
  SYMLINK /usr/src/kernel-modules/nvidia-550.120-default/nvidia-modeset/nv-modeset-kernel.o
 CONFTEST: hash__remap_4k_pfn
 CONFTEST: set_pages_uc
 CONFTEST: list_is_first
 CONFTEST: set_memory_uc
 CONFTEST: set_memory_array_uc
 CONFTEST: set_pages_array_uc
 CONFTEST: ioremap_cache
 CONFTEST: ioremap_wc
 CONFTEST: ioremap_driver_hardened
 CONFTEST: ioremap_driver_hardened_wc
 CONFTEST: ioremap_cache_shared
 CONFTEST: pci_get_domain_bus_and_slot
 CONFTEST: get_num_physpages
 CONFTEST: pde_data
 CONFTEST: xen_ioemu_inject_msi
 CONFTEST: phys_to_dma
 CONFTEST: get_dma_ops
 CONFTEST: dma_attr_macros
 CONFTEST: dma_map_page_attrs
 CONFTEST: write_cr4
 CONFTEST: of_find_node_by_phandle
 CONFTEST: of_node_to_nid
 CONFTEST: pnv_pci_get_npu_dev
 CONFTEST: of_get_ibm_chip_id
 CONFTEST: pci_bus_address
 CONFTEST: pci_stop_and_remove_bus_device
 CONFTEST: pci_rebar_get_possible_sizes
 CONFTEST: wait_for_random_bytes
 CONFTEST: register_cpu_notifier
 CONFTEST: cpuhp_setup_state
 CONFTEST: dma_map_resource
 CONFTEST: get_backlight_device_by_name
 CONFTEST: timer_setup
 CONFTEST: pci_enable_msix_range
 CONFTEST: kernel_read_has_pointer_pos_arg
 CONFTEST: kernel_write_has_pointer_pos_arg
 CONFTEST: dma_direct_map_resource
 CONFTEST: tegra_get_platform
 CONFTEST: tegra_bpmp_send_receive
 CONFTEST: flush_cache_all
 CONFTEST: vmf_insert_pfn
 CONFTEST: jiffies_to_timespec
 CONFTEST: ktime_get_raw_ts64
 CONFTEST: ktime_get_real_ts64
 CONFTEST: full_name_hash
 CONFTEST: pci_enable_atomic_ops_to_root
 CONFTEST: vga_tryget
 CONFTEST: cc_platform_has
 CONFTEST: cc_attr_guest_sev_snp
 CONFTEST: hv_get_isolation_type
 CONFTEST: seq_read_iter
 CONFTEST: follow_pfn
 CONFTEST: drm_gem_object_get
 CONFTEST: drm_gem_object_put_unlocked
 CONFTEST: add_memory_driver_managed
 CONFTEST: device_property_read_u64
 CONFTEST: devm_of_platform_populate
 CONFTEST: of_dma_configure
 CONFTEST: of_property_count_elems_of_size
 CONFTEST: of_property_read_variable_u8_array
 CONFTEST: of_property_read_variable_u32_array
 CONFTEST: i2c_new_client_device
 CONFTEST: i2c_unregister_device
 CONFTEST: of_get_named_gpio
 CONFTEST: devm_gpio_request_one
 CONFTEST: gpio_direction_input
 CONFTEST: gpio_direction_output
 CONFTEST: gpio_get_value
 CONFTEST: gpio_set_value
 CONFTEST: gpio_to_irq
 CONFTEST: icc_get
 CONFTEST: icc_put
 CONFTEST: icc_set_bw
 CONFTEST: dma_buf_export_args
 CONFTEST: dma_buf_ops_has_kmap
 CONFTEST: dma_buf_ops_has_kmap_atomic
 CONFTEST: dma_buf_ops_has_map
 CONFTEST: dma_buf_ops_has_map_atomic
 CONFTEST: dma_buf_has_dynamic_attachment
 CONFTEST: dma_buf_attachment_has_peer2peer
 CONFTEST: dma_set_mask_and_coherent
 CONFTEST: devm_clk_bulk_get_all
 CONFTEST: get_task_ioprio
 CONFTEST: mdev_set_iommu_device
 CONFTEST: offline_and_remove_memory
 CONFTEST: crypto_tfm_ctx_aligned
 CONFTEST: wait_on_bit_lock_argument_count
 CONFTEST: radix_tree_empty
 CONFTEST: radix_tree_replace_slot
 CONFTEST: pnv_npu2_init_context
 CONFTEST: cpumask_of_node
 CONFTEST: ioasid_get
 CONFTEST: mm_pasid_drop
 CONFTEST: mmget_not_zero
 CONFTEST: mmgrab
 CONFTEST: iommu_sva_bind_device_has_drvdata_arg
 CONFTEST: vm_fault_to_errno
 CONFTEST: find_next_bit_wrap
 CONFTEST: iommu_is_dma_domain
 CONFTEST: acpi_video_backlight_use_native
 CONFTEST: drm_dev_unref
 CONFTEST: drm_reinit_primary_mode_group
 CONFTEST: get_user_pages_remote
 CONFTEST: pin_user_pages_remote
 CONFTEST: drm_gem_object_lookup
 CONFTEST: drm_atomic_state_ref_counting
 CONFTEST: drm_driver_has_gem_prime_res_obj
 CONFTEST: drm_atomic_helper_connector_dpms
 CONFTEST: drm_connector_funcs_have_mode_in_name
 CONFTEST: drm_connector_has_vrr_capable_property
 CONFTEST: drm_framebuffer_get
 CONFTEST: drm_dev_put
 CONFTEST: drm_format_num_planes
 CONFTEST: drm_connector_for_each_possible_encoder
 CONFTEST: drm_rotation_available
 CONFTEST: drm_vma_offset_exact_lookup_locked
 CONFTEST: nvhost_dma_fence_unpack
 CONFTEST: dma_fence_set_error
 CONFTEST: fence_set_error
 CONFTEST: sync_file_get_fence
 CONFTEST: drm_aperture_remove_conflicting_pci_framebuffers
 CONFTEST: drm_fbdev_generic_setup
 CONFTEST: drm_fbdev_ttm_setup
 CONFTEST: drm_connector_attach_hdr_output_metadata_property
 CONFTEST: drm_helper_crtc_enable_color_mgmt
 CONFTEST: drm_crtc_enable_color_mgmt
 CONFTEST: drm_atomic_helper_legacy_gamma_set
 CONFTEST: is_export_symbol_gpl_of_node_to_nid
 CONFTEST: is_export_symbol_gpl_sme_active
 CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
 CONFTEST: is_export_symbol_present_swiotlb_dma_ops
 CONFTEST: is_export_symbol_present___close_fd
 CONFTEST: is_export_symbol_present_close_fd
 CONFTEST: is_export_symbol_present_get_unused_fd
 CONFTEST: is_export_symbol_present_get_unused_fd_flags
 CONFTEST: is_export_symbol_present_nvhost_get_default_device
 CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
 CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
 CONFTEST: is_export_symbol_present_tegra_dce_register_ipc_client
 CONFTEST: is_export_symbol_present_tegra_dce_unregister_ipc_client
 CONFTEST: is_export_symbol_present_tegra_dce_client_ipc_send_recv
 CONFTEST: is_export_symbol_present_dram_clk_to_mc_clk
 CONFTEST: is_export_symbol_present_get_dram_num_channels
 CONFTEST: is_export_symbol_present_tegra_dram_types
 CONFTEST: is_export_symbol_present_pxm_to_node
 CONFTEST: is_export_symbol_present_screen_info
 CONFTEST: is_export_symbol_gpl_screen_info
 CONFTEST: is_export_symbol_present_i2c_bus_status
 CONFTEST: is_export_symbol_present_tegra_fuse_control_read
 CONFTEST: is_export_symbol_present_tegra_get_platform
 CONFTEST: is_export_symbol_present_pci_find_host_bridge
 CONFTEST: is_export_symbol_present_tsec_comms_send_cmd
 CONFTEST: is_export_symbol_present_tsec_comms_set_init_cb
 CONFTEST: is_export_symbol_present_tsec_comms_clear_init_cb
 CONFTEST: is_export_symbol_present_tsec_comms_alloc_mem_from_gscco
 CONFTEST: is_export_symbol_present_tsec_comms_free_gscco_mem
 CONFTEST: is_export_symbol_present_memory_block_size_bytes
 CONFTEST: crypto
 CONFTEST: is_export_symbol_present_follow_pte
 CONFTEST: is_export_symbol_present_int_active_memcg
 CONFTEST: is_export_symbol_present_migrate_vma_setup
 CONFTEST: dma_ops
 CONFTEST: swiotlb_dma_ops
 CONFTEST: noncoherent_swiotlb_dma_ops
 CONFTEST: vm_fault_has_address
 CONFTEST: vm_insert_pfn_prot
 CONFTEST: vmf_insert_pfn_prot
 CONFTEST: vm_ops_fault_removed_vma_arg
 CONFTEST: kmem_cache_has_kobj_remove_work
 CONFTEST: sysfs_slab_unlink
 CONFTEST: proc_ops
 CONFTEST: timespec64
 CONFTEST: vmalloc_has_pgprot_t_arg
 CONFTEST: mm_has_mmap_lock
 CONFTEST: pci_channel_state
 CONFTEST: pci_dev_has_ats_enabled
 CONFTEST: remove_memory_has_nid_arg
 CONFTEST: add_memory_driver_managed_has_mhp_flags_arg
 CONFTEST: num_registered_fb
 CONFTEST: pci_driver_has_driver_managed_dma
 CONFTEST: vm_area_struct_has_const_vm_flags
 CONFTEST: memory_failure_has_trapno_arg
 CONFTEST: foll_longterm_present
 CONFTEST: bus_type_has_iommu_ops
 CONFTEST: backing_dev_info
 CONFTEST: mm_context_t
 CONFTEST: mmu_notifier_ops_invalidate_range
 CONFTEST: mmu_notifier_ops_arch_invalidate_secondary_tlbs
 CONFTEST: migrate_vma_added_flags
 CONFTEST: migrate_device_range
 CONFTEST: handle_mm_fault_has_mm_arg
 CONFTEST: handle_mm_fault_has_pt_regs_arg
 CONFTEST: mempolicy_has_unified_nodes
 CONFTEST: mempolicy_has_home_node
 CONFTEST: mpol_preferred_many_present
 CONFTEST: mmu_interval_notifier
 CONFTEST: drm_bus_present
 CONFTEST: drm_bus_has_bus_type
 CONFTEST: drm_bus_has_get_irq
 CONFTEST: drm_bus_has_get_name
 CONFTEST: drm_driver_has_device_list
 CONFTEST: drm_driver_has_legacy_dev_list
 CONFTEST: drm_driver_has_set_busid
 CONFTEST: drm_crtc_state_has_connectors_changed
 CONFTEST: drm_init_function_args
 CONFTEST: drm_helper_mode_fill_fb_struct
 CONFTEST: drm_master_drop_has_from_release_arg
 CONFTEST: drm_driver_unload_has_int_return_type
 CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
 CONFTEST: drm_atomic_helper_plane_destroy_state_has_plane_arg
 CONFTEST: drm_mode_object_find_has_file_priv_arg
 CONFTEST: dma_buf_owner
 CONFTEST: drm_connector_list_iter
 CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
 CONFTEST: drm_driver_prime_flag_present
 CONFTEST: drm_gem_object_has_resv
 CONFTEST: drm_crtc_state_has_async_flip
 CONFTEST: drm_crtc_state_has_pageflip_flags
 CONFTEST: drm_crtc_state_has_vrr_enabled
 CONFTEST: drm_format_modifiers_present
 CONFTEST: drm_vma_node_is_allowed_has_tag_arg
 CONFTEST: drm_vma_offset_node_has_readonly
 CONFTEST: drm_display_mode_has_vrefresh
 CONFTEST: drm_driver_master_set_has_int_return_type
 CONFTEST: drm_driver_has_gem_free_object
 CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
 CONFTEST: drm_driver_has_gem_prime_callbacks
 CONFTEST: drm_crtc_atomic_check_has_atomic_state_arg
 CONFTEST: drm_gem_object_vmap_has_map_arg
 CONFTEST: drm_plane_atomic_check_has_atomic_state_arg
 CONFTEST: drm_device_has_pdev
 CONFTEST: drm_crtc_state_has_no_vblank
 CONFTEST: drm_mode_config_has_allow_fb_modifiers
 CONFTEST: drm_has_hdr_output_metadata
 CONFTEST: dma_resv_add_fence
 CONFTEST: dma_resv_reserve_fences
 CONFTEST: reservation_object_reserve_shared_has_num_fences_arg
 CONFTEST: drm_connector_has_override_edid
 CONFTEST: drm_master_has_leases
 CONFTEST: drm_file_get_master
 CONFTEST: drm_modeset_lock_all_end
 CONFTEST: drm_connector_lookup
 CONFTEST: drm_connector_put
 CONFTEST: drm_driver_has_dumb_destroy
 CONFTEST: fence_ops_use_64bit_seqno
 CONFTEST: drm_aperture_remove_conflicting_pci_framebuffers_has_driver_arg
 CONFTEST: drm_mode_create_dp_colorspace_property_has_supported_colorspaces_arg
 CONFTEST: drm_unlocked_ioctl_flag_present
 CONFTEST: drm_output_poll_changed
 CONFTEST: dom0_kernel_present
 CONFTEST: nvidia_vgpu_kvm_build
 CONFTEST: nvidia_grid_build
 CONFTEST: nvidia_grid_csp_build
 CONFTEST: pm_runtime_available
 CONFTEST: pci_class_multimedia_hd_audio
 CONFTEST: drm_available
 CONFTEST: vfio_pci_core_available
 CONFTEST: mdev_available
 CONFTEST: cmd_uphy_display_port_init
 CONFTEST: cmd_uphy_display_port_off
 CONFTEST: memory_failure_mf_sw_simulated_defined
 CONFTEST: drm_atomic_available
 CONFTEST: is_export_symbol_gpl_refcount_inc
 CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
 CONFTEST: drm_alpha_blending_available
 CONFTEST: is_export_symbol_present_drm_gem_prime_fd_to_handle
 CONFTEST: is_export_symbol_present_drm_gem_prime_handle_to_fd
 CONFTEST: ib_peer_memory_symbols
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-pci.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-dmabuf.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-nano-timer.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-acpi.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-cray.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-dma.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-i2c.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-mmap.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-p2p.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-pat.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-procfs.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-usermap.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-vm.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-vtophys.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/os-interface.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/os-mlock.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/os-pci.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/os-registry.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/os-usermap.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-modeset-interface.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-pci-table.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-kthread-q.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-memdbg.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-ibmnpu.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-report-err.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-rsync.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-msi.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-caps.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-caps-imex.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv_uvm_interface.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_aead.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_ecc.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_hkdf.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_rand.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_shash.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_rsa.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_aead_aes_gcm.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_sha.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_hmac_sha.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_internal_crypt_lib.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_hkdf_sha.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_ec.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_x509.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_rsa_ext.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nvlink_linux.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nvlink_caps.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/linux_nvswitch.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/procfs_nvswitch.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia/i2c_nvswitch.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_ats_sva.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_conf_computing.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_sec2_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_maxwell_sec2.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_hopper_sec2.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_common.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_linux.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/nvstatus.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/nvCpuUuid.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/nv-kthread-q.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/nv-kthread-q-selftest.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_tools.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_global.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_gpu.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_gpu_isr.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_procfs.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_va_space.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_va_space_mm.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_gpu_semaphore.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_mem.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_rm_mem.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_channel.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_lock.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_hal.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_processors.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_range_tree.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_rb_tree.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_range_allocator.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_va_range.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_va_policy.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_va_block.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_range_group.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_gpu_replayable_faults.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_gpu_non_replayable_faults.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_gpu_access_counters.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_perf_events.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_perf_module.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_mmu.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_pte_batch.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_tlb_batch.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_push.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_pushbuffer.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_thread_context.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_tracker.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_maxwell.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_maxwell_host.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_maxwell_ce.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_maxwell_mmu.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_maxwell_fault_buffer.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_maxwell_access_counter_buffer.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_pascal.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_pascal_ce.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_pascal_host.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_pascal_mmu.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_pascal_fault_buffer.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_volta_ce.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_volta_host.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_volta_mmu.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_volta.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_volta_fault_buffer.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_volta_access_counter_buffer.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_turing.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_turing_access_counter_buffer.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_turing_fault_buffer.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_turing_mmu.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_turing_host.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_ampere.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_ampere_ce.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_ampere_host.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_ampere_mmu.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_hopper.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_hopper_fault_buffer.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_hopper_ce.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_hopper_host.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_hopper_mmu.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_ada.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_policy.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_perf_utils.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_kvmalloc.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_pmm_sysmem.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_pmm_gpu.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_populate_pageable.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_migrate.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_migrate_pageable.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_map_external.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_user_channel.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_hmm.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_perf_heuristics.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_perf_thrashing.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_perf_prefetch.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_ats.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_ats_ibm.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_ats_faults.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_test_rng.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_range_tree_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_range_allocator_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_gpu_semaphore_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_mem_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_rm_mem_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_page_tree_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_tracker_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_push_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_channel_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_ce_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_host_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_lock_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_perf_utils_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_kvmalloc_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_pmm_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_pmm_sysmem_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_perf_events_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_perf_module_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_get_rm_ptes_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_fault_buffer_flush_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_peer_identity_mappings_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_va_block_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_range_group_tree_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_thread_context_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm/uvm_rb_tree_test.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-modeset/nvidia-modeset-linux.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-modeset/nv-kthread-q.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-drv.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-utils.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-crtc.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-encoder.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-connector.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-gem.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-fb.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-modeset.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-fence.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-helper.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nv-kthread-q.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nv-pci-table.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-gem-user-memory.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-gem-dma-buf.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-format.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-os-interface.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-linux.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-peermem/nvidia-peermem.o
  LD [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia.o
ld.bfd -r -o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-interface.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-pci.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-dmabuf.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-nano-timer.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-acpi.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-cray.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-dma.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-i2c.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-mmap.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-p2p.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-pat.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-procfs.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-usermap.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-vm.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-vtophys.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/os-interface.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/os-mlock.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/os-pci.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/os-registry.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/os-usermap.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-modeset-interface.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-pci-table.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-kthread-q.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-memdbg.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-ibmnpu.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-report-err.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-rsync.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-msi.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-caps.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv-caps-imex.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nv_uvm_interface.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_aead.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_ecc.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_hkdf.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_rand.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_shash.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_rsa.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_aead_aes_gcm.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_sha.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_hmac_sha.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_internal_crypt_lib.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_hkdf_sha.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_ec.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_x509.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/libspdm_rsa_ext.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nvlink_linux.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/nvlink_caps.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/linux_nvswitch.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/procfs_nvswitch.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia/i2c_nvswitch.o
/usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-drv.c: In function ‘nv_drm_register_drm_device’:
/usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm/nvidia-drm-drv.c:1799:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
     bool bus_is_pci =
  LD [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-peermem.o
  LD [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm.o
ld.bfd -r -o /usr/src/kernel-modules/nvidia-550.120-default/nvidia-modeset/nv-modeset-interface.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia-modeset/nvidia-modeset-linux.o /usr/src/kernel-modules/nvidia-550.120-default/nvidia-modeset/nv-kthread-q.o
  LD [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-modeset.o
  LD [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-modeset.mod.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm.mod.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-peermem.mod.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia.mod.o
  CC [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm.mod.o
  LD [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-modeset.ko
  LD [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-peermem.ko
  LD [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm.ko
  LD [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm.ko
  LD [M]  /usr/src/kernel-modules/nvidia-550.120-default/nvidia.ko
  BTF [M] /usr/src/kernel-modules/nvidia-550.120-default/nvidia-peermem.ko
Skipping BTF generation for /usr/src/kernel-modules/nvidia-550.120-default/nvidia-peermem.ko due to unavailability of vmlinux
  BTF [M] /usr/src/kernel-modules/nvidia-550.120-default/nvidia-modeset.ko
Skipping BTF generation for /usr/src/kernel-modules/nvidia-550.120-default/nvidia-modeset.ko due to unavailability of vmlinux
  BTF [M] /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm.ko
Skipping BTF generation for /usr/src/kernel-modules/nvidia-550.120-default/nvidia-drm.ko due to unavailability of vmlinux
  BTF [M] /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm.ko
Skipping BTF generation for /usr/src/kernel-modules/nvidia-550.120-default/nvidia-uvm.ko due to unavailability of vmlinux
  BTF [M] /usr/src/kernel-modules/nvidia-550.120-default/nvidia.ko
Skipping BTF generation for /usr/src/kernel-modules/nvidia-550.120-default/nvidia.ko due to unavailability of vmlinux
make[2]: Leaving directory '/usr/src/linux-5.14.21-150500.53-obj/x86_64/default'
make[1]: Leaving directory '/usr/src/linux-5.14.21-150500.53'
ld.bfd  -T /usr/src/linux-5.14.21-150500.53-obj/x86_64/default/scripts/module.lds -r -o nv-linux.o \
  nvidia.mod.o nvidia/nv-interface.o
rm -f -r conftest
  CLEAN   /usr/src/kernel-modules/nvidia-550.120-default
  CLEAN   /usr/src/kernel-modules/nvidia-550.120-default/Module.symvers
Modprobe blacklist files have been created at /etc/modprobe.d to prevent Nouveau from loading. This can be reverted by deleting /etc/modprobe.d/nvidia-*.conf.
*** Reboot your computer and verify that the NVIDIA graphics driver can be loaded. ***
( 6/12) Installing: nvidia-driver-G06-kmp-default-550.120_k5.14.21_150500.53-lp155.28.2.x86_64 .................................................................[done]
( 7/12) Installing: nvidia-compute-G06-550.120-lp155.28.1.x86_64 ...............................................................................................[done]
( 8/12) Installing: nvidia-compute-G06-32bit-550.120-lp155.28.1.x86_64 .........................................................................................[done]
( 9/12) Installing: nvidia-gl-G06-550.120-lp155.28.1.x86_64 ....................................................................................................[done]
(10/12) Installing: nvidia-gl-G06-32bit-550.120-lp155.28.1.x86_64 ..............................................................................................[done]
(11/12) Installing: nvidia-video-G06-550.120-lp155.28.1.x86_64 .................................................................................................[done]
(12/12) Installing: nvidia-video-G06-32bit-550.120-lp155.28.1.x86_64 ...........................................................................................[done]
Executing %posttrans scripts ...................................................................................................................................[done]
There are running programs which still use files and libraries deleted or updated by recent upgrades. They should be restarted to benefit from the latest updates. Run 'zypper ps -s' to list these programs.
Then I rebooted my system to see if nvidia-smi returns anything. Unfortunately, the result is the same; however, I also ran nvaccelinfo:
nvaccelinfo
CUDA Driver Version:           12040
NVRM version:                  NVIDIA UNIX x86_64 Kernel Module  550.120  Fri Sep 13 10:10:01 UTC 2024
Device Number:                 0
Device Name:                   Quadro GV100
Device Revision Number:        7.0
Global Memory Size:            34069872640
Number of Multiprocessors:     80
Concurrent Copy and Execution: Yes
Total Constant Memory:         65536
Total Shared Memory per Block: 49152
Registers per Block:           65536
Warp Size:                     32
Maximum Threads per Block:     1024
Maximum Block Dimensions:      1024, 1024, 64
Maximum Grid Dimensions:       2147483647 x 65535 x 65535
Maximum Memory Pitch:          2147483647B
Texture Alignment:             512B
Clock Rate:                    1627 MHz
Execution Timeout:             Yes
Integrated Device:             No
Can Map Host Memory:           Yes
Compute Mode:                  default
Concurrent Kernels:            Yes
ECC Enabled:                   No
Memory Clock Rate:             850 MHz
Memory Bus Width:              4096 bits
L2 Cache Size:                 6291456 bytes
Max Threads Per SMP:           2048
Async Engines:                 2
Unified Addressing:            Yes
Managed Memory:                Yes
Concurrent Managed Memory:     Yes
Preemption Supported:          Yes
Cooperative Launch:            Yes
  Multi-Device:                Yes
Default Target:                cc70
Device Number:                 1
Device Name:                   Quadro P620
Device Revision Number:        6.1
Global Memory Size:            2086797312
Number of Multiprocessors:     4
Warp Size:                     32
Clock Rate:                    1354 MHz
ECC Enabled:                   No
Memory Clock Rate:             2505 MHz
Memory Bus Width:              128 bits
L2 Cache Size:                 524288 bytes
Async Engines:                 2
Managed Memory:                Yes
  Multi-Device:                Yes
Default Target:                cc61
I am waiting for your response to continue further with this. Thanks again for your help.
That doesn’t look like you are following the instructions I suggested. I won’t be able to help with whatever you are doing there.
If you want follow the instructions I suggest, please use the commands listed here for driver install on OpenSUSE.
I’m reproducing the specifics here:
##### Download Installer for Linux OpenSUSE 15 x86_64
The base installer is available for download below.
|CUDA Toolkit Installer||
|Installation Instructions:|
wget https://developer.download.nvidia.com/compute/cuda/12.6.2/local_installers/cuda-repo-opensuse15-12-6-local-12.6.2_560.35.03-1.x86_64.rpmsudo rpm -i cuda-repo-opensuse15-12-6-local-12.6.2_560.35.03-1.x86_64.rpmsudo zypper refreshsudo zypper install -y cuda-toolkit-12-6
|Additional installation options are detailed [here](https://docs.nvidia.com/cuda/cuda-installation-guide-linux/#meta-packages).|
|Driver Installer||
|NVIDIA Driver Instructions (choose one option)|
|To install the open kernel module flavor:|
sudo zypper install -y nvidia-open
|To install the legacy kernel module flavor:|
sudo zypper install -y cuda-drivers
That may or may not work because you have used OpenSUSE packages that I won’t be able to help you with and don’t know how to clean up/unwind. If you want to start over with a clean OS install you may have better results.
Thanks. I was trying to understand what made nvaccelinfo return a sensible result (also, I can compile and run programs without any visible error now which I was unable to before); I removed the CUDA Toolkit repository from my server, which was forcing an install that required a kernel version (basically a kernel mismatch) which I wasn’t able to acquire, hence I was getting errors whilst installing it. When I have installed the recommended driver version for my graphics card, compilation errors and etc. did not appear. If for any reason I decide to flush my system I will follow your instructions. Again, thanks for your help, you made me realize what was wrong.
