Greetings all,
I am trying to write a host function and kernel that will integrate with a project on which I am working. This project is being developed in VS2008 on Windows XP 64. In this project we are using the Boost Libraries for added functionality, but I am having an issue when I try to compile my function. In the Boost libraries there is a piece of code of the form:
struct __declspec(align(32)) a32 {
Which when compiled produces the error “error: invalid alignment specifier value.”
While this form is normally not valid, the compiler for Microsoft allows the use of integers larger than 16 when using align, http://msdn.microsoft.com/en-us/library/83ythb65.aspx . I think the problem arises when nvcc is used to compile code that contains this header file. Has anyone else come across this problem and been able to resolve it?
K
tobsen
November 27, 2009, 9:37am
#2
Greetings all,
K
Hi smokeyjayl,
have you found any solution to this? I’m currently stuck with the same problem.
Greetings,
To
Greetings all,
K
Hey, i’ve come across this kind of error while compiling using alignment in cuda. how did you fix it? i’m working on it now.
#define d_4(t,n,b,e,f,g,h) EXTERN ALIGN CONST XP_DIR t n[4][256]
where ALIGN is defined as
#define ALIGN __declspec(align(TABLE_ALIGN))
compiling this gives undefined error but not in EMU & host mode.
thanks.
Greetings all,
K
thanks.
chero
June 14, 2010, 3:38pm
#5
I’ve the same problem with NVCC compiler and Boost (VS 2005). Has you a solution for this behavior?
Regards
chero :rolleyes:
