Like You can see, the test shows that cuda has been installed properly.
krs@krs-GP73-Leopard-8RE:/usr/local/cuda-10.0/samples/bin/x86_64/linux/release$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce GTX 1060"
CUDA Driver Version / Runtime Version 10.0 / 10.0
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 6078 MBytes (6373572608 bytes)
(10) Multiprocessors, (128) CUDA Cores/MP: 1280 CUDA Cores
GPU Max Clock rate: 1733 MHz (1.73 GHz)
Memory Clock rate: 4004 Mhz
Memory Bus Width: 192-bit
L2 Cache Size: 1572864 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.0, CUDA Runtime Version = 10.0, NumDevs = 1
Result = PASS
Here you have my list of directories were cuda should be installed, in cuda directory has been unpacked cudnn, cuda has been installed in cuda-10.0, the cuda header cuda.h is not where cudnn has beeun unpacked.
krs@krs-GP73-Leopard-8RE:~$ cd /usr/local
krs@krs-GP73-Leopard-8RE:/usr/local$ ls -l
total 40
drwxr-xr-x 2 root root 4096 maj 20 22:09 bin
drwxr-xr-x 4 root root 4096 maj 20 22:21 cuda
drwxr-xr-x 20 root root 4096 maj 25 15:18 cuda-10.0
drwxr-xr-x 2 root root 4096 lut 10 01:12 etc
drwxr-xr-x 2 root root 4096 lut 10 01:12 games
drwxr-xr-x 3 root root 4096 maj 20 22:09 include
drwxr-xr-x 5 root root 4096 maj 20 22:09 lib
lrwxrwxrwx 1 root root 9 maj 20 19:20 man -> share/man
drwxr-xr-x 2 root root 4096 lut 10 01:12 sbin
drwxr-xr-x 6 root root 4096 lut 10 01:15 share
drwxr-xr-x 2 root root 4096 lut 10 01:12 src
That is why
cat: /usr/local/cuda/include/cuda.h: No such file or directory
and
/bin/sh: 1: /usr/local/cuda/bin/nvcc: not found
I have installed it already with this guide twice
Please help
Should I maybe change name of cuda-10.0 directory to cuda or something? Or is there other way to do it?
