cudnn install error
li@li-System-Product-Name:~/cudnn_samples_v7/mnistCUDNN$ sudo make clean && make
rm -rf *o
rm -rf mnistCUDNN
Linking agains cublasLt = false
CUDA VERSION: 10000
TARGET ARCH: x86_64
HOST_ARCH: x86_64
TARGET OS: linux
SMS: 30 35 50 53 60 61 62 70 72 75
/bin/sh: 1: cannot create test.c: Permission denied
g++: error: test.c: No such file or directory
g++: warning: ‘-x c’ after last input file has no effect
g++: fatal error: no input files
compilation terminated.
>>> WARNING - FreeImage is not set up correctly. Please ensure FreeImage is set up correctly. <<<
[@] /usr/local/cuda/bin/nvcc -ccbin g++ -I/usr/local/cuda/include -IFreeImage/include -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_72,code=sm_72 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_75,code=compute_75 -o fp16_dev.o -c fp16_dev.cu
[@] g++ -I/usr/local/cuda/include -IFreeImage/include -o fp16_emu.o -c fp16_emu.cpp
[@] g++ -I/usr/local/cuda/include -IFreeImage/include -o mnistCUDNN.o -c mnistCUDNN.cpp
[@] /usr/local/cuda/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_72,code=sm_72 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_75,code=compute_75 -o mnistCUDNN fp16_dev.o fp16_emu.o mnistCUDNN.o -I/usr/local/cuda/include -IFreeImage/include -LFreeImage/lib/linux/x86_64 -LFreeImage/lib/linux -lcudart -lcublas -lcudnn -lfreeimage -lstdc++ -lm
li@li-System-Product-Name:~/cudnn_samples_v7/mnistCUDNN$ ./mnistCUDNN
bash: ./mnistCUDNN: No such file or directory
when i install cudnn ,i find some error .
hello,i have same error ,but solved it now.
it look like system can’t create new folder
try chmod 777 for mnistCUDNN then try again,it work for me.
Hi!
Solution provided by @jick155 worked for me. Thanks!
Yup, @jick155’s solution worked for me
works for me
what is the command exactly, can u please comment correct command i dont know how to do this
Suppose you are in the folder of mnistCUDNN, go to one level above it (jump out of this folder).
Then run command: sudo chmod 777 mnistCUDNN.
In this way, you can change the permission of the folder.
For me, this change helps it possible to successfully run make command.
