Hi folks,
I try to realize WPF application using CUDA calculations and Direct3D 9 graphics. So I use following approach:
I create WPF application using MSDN “Walkthrough: Hosting Direct3D9 Content in WPF”
Then I create DLL using MSDN “Walkthrough: Creating Direct3D9 Content for Hosting in WPF”
I works, I see a rotating triangle.
- Then I try to realize Direct3D 9 interop according to part 3.2.11.2 of “NVIDIA CUDA C Programming Guide”. But cudaGraphicsD3D9RegisterResource function returns error.
I declare CUDA graphics resource variable in class:
#pragma once
class CTriangleRenderer : public CRenderer
public:
static HRESULT Create(IDirect3D9 *pD3D, IDirect3D9Ex *pD3DEx, HWND hwnd, UINT uAdapter, CRenderer **ppRenderer);
~CTriangleRenderer();
HRESULT Render();
protected:
HRESULT Init(IDirect3D9 *pD3D, IDirect3D9Ex *pD3DEx, HWND hwnd, UINT uAdapter);
private:
IDirect3DVertexBuffer9 *m_pd3dVB;
struct cudaGraphicsResource* positionsVB_CUDA;
cudaGraphicsD3D9RegisterResource function call is this class member:
HRESULT
CTriangleRenderer::Init(IDirect3D9 *pD3D, IDirect3D9Ex *pD3DEx, HWND hwnd, UINT uAdapter)
HRESULT hr = S_OK;
D3DXMATRIXA16 matView, matProj;
D3DXVECTOR3 vEyePt(0.0f, 0.0f,-5.0f);
D3DXVECTOR3 vLookatPt(0.0f, 0.0f, 0.0f);
D3DXVECTOR3 vUpVec(0.0f, 1.0f, 0.0f);
// Call base to create the device and render target
IFC(CRenderer::Init(pD3D, pD3DEx, hwnd, uAdapter));
printf("> Adapter: %d\n", uAdapter);
// Set up the VB
CUSTOMVERTEX vertices[] =
{ -1.0f, -1.0f, 0.0f, 0xffff0000, }, // x, y, z, color
{ 1.0f, -1.0f, 0.0f, 0xff00ff00, },
{ 0.0f, 1.0f, 0.0f, 0xff00ffff, },
IFC(m_pd3dDevice->CreateVertexBuffer(sizeof(vertices), 0, D3DFVF_CUSTOMVERTEX, D3DPOOL_DEFAULT, &m_pd3dVB, NULL));
cudaGraphicsD3D9RegisterResource(&positionsVB_CUDA, m_pd3dVB, cudaGraphicsRegisterFlagsNone);
cutilCheckMsg("cudaGraphicsD3D9RegisterResource failed");
cudaGraphicsResourceSetMapFlags(positionsVB_CUDA, cudaGraphicsMapFlagsWriteDiscard);
void *pVertices;
IFC(m_pd3dVB->Lock(0, sizeof(vertices), &pVertices, 0));
memcpy(pVertices, vertices, sizeof(vertices));
m_pd3dVB->Unlock();
// Set up the camera
D3DXMatrixLookAtLH(&matView, &vEyePt, &vLookatPt, &vUpVec);
IFC(m_pd3dDevice->SetTransform(D3DTS_VIEW, &matView));
D3DXMatrixPerspectiveFovLH(&matProj, D3DX_PI / 4, 1.0f, 1.0f, 100.0f);
IFC(m_pd3dDevice->SetTransform(D3DTS_PROJECTION, &matProj));
// Set up the global state
IFC(m_pd3dDevice->SetRenderState(D3DRS_CULLMODE, D3DCULL_NONE));
IFC(m_pd3dDevice->SetRenderState(D3DRS_LIGHTING, FALSE));
IFC(m_pd3dDevice->SetStreamSource(0, m_pd3dVB, 0, sizeof(CUSTOMVERTEX)));
IFC(m_pd3dDevice->SetFVF(D3DFVF_CUSTOMVERTEX));
Cleanup:
return hr;
positionsVB_CUDA variable value is 0xcdcdcdcd before cudaGraphicsD3D9RegisterResource call and the same value after.
Where is my error? Direct3D 9 interop example from CUDA SDK works fine. My configuration:
[i]NVIDIA GTX 260 800 MB
NVIDIA GTX 460 2 GB
CUDA 4.0
Windows 7 64-bit
8GB RAM
Visual Studio 2010
[/i]
Best regards,
Vitaliy
