Is Direct3D9Ex interop supported?
I just downloaded the CUDA 6 Toolkit and compiled the “simpleD3D9Texture” example. It works well as is.
Now, if I simply replace the Direct3D9 device by a Direct3D9Ex device, keeping all of the other code identical, I get the following error at run-time, in RunCuda():
Here are the only modifications to the code I made:
//IDirect3D             *g_pD3D; // Used to create the D3DDevice
IDirect3D9Ex          *g_pD3D; // Used to create the D3DDevice
//IDirect3DDevice9      *g_pD3DDevice;
IDirect3DDevice9Ex    *g_pD3DDevice;
//if (NULL == (g_pD3D = Direct3DCreate9(D3D_SDK_VERSION)))
if (NULL == (Direct3DCreate9Ex(D3D_SDK_VERSION, &g_pD3D)))
//if (FAILED(g_pD3D->CreateDevice(g_iAdapter, D3DDEVTYPE_HAL, hWnd,
//                                D3DCREATE_HARDWARE_VERTEXPROCESSING,
//                                &d3dpp, &g_pD3DDevice)))
if (FAILED(g_pD3D->CreateDeviceEx(g_iAdapter, D3DDEVTYPE_HAL, hWnd,
                                  &d3dpp, nullptr, &g_pD3DDevice)))
Is Direct3D9Ex interop supported and if so, are there particular cuda methods that are not compatible? What causes this error?
EDIT: NVM, obvious oversight:
needs to be != instead of ==. facepalm It works fine after that.
