I’ve been trying for a few days now to get the dev drivers installed for Fedora 15 with no luck. Can some one help?
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Tue Aug 16 14:08:40 2011
installer version: 270.41.19
PATH:
/opt/gcc44/bin:/usr/lib64/ccache:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/
usr/sbin:/sbin:/home/goddard/bin
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
precompiled interfaces : true
no ncurses color : false
query latest version : false
no questions : false
silent : false
no recursion : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : false
no ABI note : false
no RPMs : false
no kernel module : false
force SELinux : default
no X server check : false
no cc version check : false
run distro scripts : true
no nouveau check : false
run nvidia-xconfig : false
sigwinch work around : true
force tls : (not specified)
force compat32 tls : (not specified)
X install prefix : (not specified)
X library install path : (not specified)
X module install path : (not specified)
OpenGL install prefix : (not specified)
OpenGL install libdir : (not specified)
compat32 install chroot : (not specified)
compat32 install prefix : (not specified)
compat32 install libdir : (not specified)
utility install prefix : (not specified)
utility install libdir : (not specified)
installer prefix : (not specified)
doc install prefix : (not specified)
kernel name : (not specified)
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
precompiled kernel interfaces path : (not specified)
precompiled kernel interfaces url : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp mirror : ftp://download.nvidia.com
RPM file list : (not specified)
selinux chcon type : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 270.41.19.
-> Performing CC sanity check with CC="cc".
-> Performing CC version check with CC="cc".
-> Kernel source path: '/lib/modules/2.6.40-4.fc15.x86_64/source'
-> Kernel output path: '/lib/modules/2.6.40-4.fc15.x86_64/build'
ERROR: If you are using a Linux 2.4 kernel, please make sure
you either have configured kernel sources matching your
kernel or the correct set of kernel headers installed
on your system.
If you are using a Linux 2.6 kernel, please make sure
you have configured kernel sources matching your kernel
installed on your system. If you specified a separate
output directory using either the "KBUILD_OUTPUT" or
the "O" KBUILD parameter, make sure to specify this
directory with the SYSOUT environment variable or with
the equivalent nvidia-installer command line option.
Depending on where and how the kernel sources (or the
kernel headers) were installed, you may need to specify
their location with the SYSSRC environment variable or
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at www.nvidia.com.
I gave up trying to use the nvidia CUDA driver installer and switched to the one supplied via yum (akmod-nvidia + xorg-x11-drv-nvidia-libs packages) as discussed at if !1 0 (Fedora 14 nVidia Drivers Installation instructions). Doing this installs the 280.13 driver which does support CUDA (at least I haven’t had any issues so far with the SDK examples). You will need to modify the common.mk files within the SDK to include /usr/lib64/nvidia as an additional directory to link against.
Given that Fedora 16(!) is slated to be released in ~2 months and to currently use CUDA with the latest Fedora distros requires one to compile and install a separate gcc4.4 compiler, it is an open question in my mind if nvidia is going to continue to support Fedora.
I would check that the compiled binaries are using the libraries in /usr/lib64/nvidia and that /proc/driver/nvidia/version provides identical output to that listed above.
Given that you reported that you were able to successfully compile the SDK examples (I’m assuming your gcc44 installation is correct) and we know that the SDK examples are not buggy, that only leaves the runtime system (libraries and drivers) which could be introducing the error for non-graphical SDK examples (such as deviceQuery). I always run deviceQuery to confirm correct CUDA installation. I also run additional non-graphical and graphical examples as well.
You also check if the nvidia driver is actually loaded into the kernel with lsmod | grep nvidia. Running this on my system results in
I have the driver installed, but I’m trying to compile OpenCV with TBB and I’m getting an error. I’m guessing it was a problem with TBB, but not sure. I force compile and it claims I’m not using CUDA.
I read some where that the toolkit and the driver need to match, but I’m new to CUDA.
Hmmm … you’re out of my league with regards to CUDA integration into OpenCV. I don’t have a lot of experience with OpenCV.
If OpenCV is relying on libnvidia-tls (local thread storage libraries) for nvidia native OpenGL support then the location of these libraries has changed to /usr/lib64/nvidia/tls. See nvidia driver installed components writeup.
I do not think that you need to have toolkit and driver match with CUDA (at least for support for older features) Every driver should be backwards compatible with older toolkits. Just don’t expect to be able to run, say concurrent kernels, on a device when using an older toolkit since they may have needed to modify the toolkit to deal with this.
Nvidia is now supporting Fedora 14 with their 4.1RC2 release, but given that Fedora is now on 16 and working on 17, is nvidia always going to be two releases behind in their Fedora support? Does anyone at nvidia wish to comment on what their Fedora support policy is?
I don’t work for NVIDIA, but when this has come up in the past (typically regarding Ubuntu), the response has been that the QA process for CUDA takes long enough that they will probably not support a distribution release that happens after the middle the CUDA release cycle. Given that a CUDA release happens every 6-9 months, and Fedora and Ubuntu both use 6 month release cycles, CUDA is pretty much guaranteed to be one distribution release out of date. While this has not been stated as explicit policy, this has been the reality for several years of CUDA releases.
So the real question is why Fedora 15 is not (yet) supported in CUDA 4.1, as that was released only a few months after CUDA 4.0.
Yes, I agree that differing release cycles will cause CUDA to get out of sync with Fedora (and other open source) releases. I do think that it would be helpful to Fedora and Ubuntu users if nvidia would sync their CUDA release cycles to the Fedora/Ubuntu release cycles, but this is probably asking too much.
I also agree with your question asking why Fedora 15 is not yet supported by CUDA? It would be helpful to have someone at nvidia weigh in on this topic. I do believe that six month release cycles encourages open source software innovation as discussed on the Fedora Release Life Cycle page.
