The Compiler SDK is indeed available as part of the CUDA 5.5 Toolkit.
You should see a “nvvm/” directory at the top-level of the CUDA toolkit installation that contains include files, libraries (libnvvm, libdevice), and samples. The “doc/” toolkit directory also contains several documents relating to these components.
On my Windows box, here is the path to the nvvm directory after installing to the default location:
