cuda crash without any message
When I switch on the computer , the fist time I Starting the software It will crash without any message.
but the next time I Starting the software ,everything is normal.
And It will be normal until Next time I switch on the computer and starting the software.
Thanks,
TUshar
perhaps then only switch on the computer every other time…
with “software”, are you referring to an application you wrote, or the ide itself?
yes the software is a application I wrote.
When Debugging It will crash at “cudaDeviceSynchronize();”
and almost every time I switch on the computer I will happen.
But I do not why It crash at the First time ,but run normally in the next operation.
i would worry if it crashes in the debugger, and largely focus on that
if it crashes on the cudaDeviceSynchronize call, it is perhaps something upstream
i presume you have a kernel just prior to the crashing cudaDeviceSynchronize, with memory copies perhaps
perhaps check for errors (cudaSuccess) prior to the kernel launch, and after it
alternatively, post some code
Hi:
I add cudaSuccess before every memery operation. And I can sure that there is no memery error.
This is my code
global void Top_One_Function(DFX::Top_Tree::Top_Tree_DataTop_Tree_Data_ , DFX::Middle_Teee::Middle_Tree_DataMiddle_Tree_Data_
,unsigned intIndex_One_Frame , unsigned short intShift_Index_One_Frame , boolMiddle_Tree_Bool , int Middle_limid /,intBool_Index_Txt/
, int Top_Limid /, intHaha_Thread*/)
if (threadIdx.x > 125 )
return;
int offset = blockIdx.y*gridDim.x + blockIdx.x;
int offset_Volume = offset * 125 + threadIdx.x;
int Temple_Top_Tree = Index_One_Frame[offset_Volume];
if (!Temple_Top_Tree)
return;
unsigned short int Shift = Shift_Index_One_Frame[offset_Volume];
int Z = ((Shift>> 0)&1)4;
int Y = ((Shift>> 1)&1)2;
int X = ((Shift>> 2)&1);
int Top_One_Shift = Top_Tree_Data_[Temple_Top_Tree].Index;
int Bool_Index = Top_One_Shift + X + Y + Z;
/Bool_Index_Txt[offset_Volume] = Bool_Index;/
__syncthreads();
if (Bool_Index > Middle_limid||(!Middle_Tree_Bool)||Bool_Index < 0)
return;
		if (!Middle_Tree_Data_[Bool_Index].Index)
			Middle_Tree_Bool[Bool_Index] = true;
            /*Middle_Bool_Temp[Bool_Index] = true;*/
		/*Haha_Thread[offset_Volume] = Bool_Index + 100;*/
It is crash in this funciont. and I used “cudaDeviceSynchronize” to detect other function.I sure that no error happen before this function.
And today I found that If i add “Haha_Thread” I will not crash. I just use “Haha_Thread” to record some variable, If i Comment out it .It will crash in this function.
So I doubt If it is because Memory alignment.
@xiangxiango, you could try: “cuda-memcheck --report-api-errors all ”.
Also, cuda-memcheck has many many other options that you can try.
return;
return;
/__syncthreads();/
you like trouble, don’t you?
i am also not sure whether it is a brilliant idea to pass a kernel: DFX::Top_Tree::Top_Tree_DataTop_Tree_Data_ , DFX::Middle_Teee::Middle_Tree_DataMiddle_Tree_Data_
you mean that I should not use like that
or I should use __syncthreads();???
it is never really a sound idea to call __syncthreads() in divergent code - all threads should be able to reach the __syncthreads(), otherwise you may end up ‘having a bad time’
i would interpret calling __syncthreads() after some threads have already exited, as a case of calling __syncthreads() in divergent code
just turn the conditionals around:
if (threadIdx.x < 125 )
work
__syncthreads(); // if necesssary
if (Temple_Top_Tree)
work
thank you sir I will modify my code as you tell.
I had use the memcheck to check where cause the crash
I restart my PC twice.
at the first It did not crash. And memcheck tell that"no error"
but the second time It tell that “unspecified launch failure” then crash happen.
use cudaGetLastError() just before and after your kernel launch, to determine whether your kernel actually launches
as mentioned:
yes I had put cudaGetLastError().
End I sure that There is a wrong existing that function.
sorry sir I do not know what “pass to kernel” mean
I am from China . My english pool.
your kernel declaration:
, int Top_Limid /, intHaha_Thread*/);
from that, your kernel parameters, passed to the kernel
having kernel parameter: unsigned intIndex_One_Frame, and passing to the kernel: unsigned intIndex_One_Frame; that i can accept
having kernel parameter: DFX::Top_Tree::Top_Tree_DataTop_Tree_Data_ and passing to the kernel
Top_Tree_Data_ ; that worries me slightly
