I am trying to crop a section of a 1920x1080 image and pass that ROI through a neural net like in https://github.com/dusty-nv/jetson-inference/blob/master/detectnet-camera/detectnet-camera.cpp. We want to crop out an ROI of the imgRGBA image. We’ve found a crop function in https://github.com/dusty-nv/jetson-video/blob/master/cuda/cudaCrop.cu and tried to edit it to only crop an ROI like this:
template <typename T>
__global__ void gpuCrop( T* input, int inputWidth, T* output, int outputWidth, int outputHeight, int xMin, int yMin )
const int y = blockDim.y * blockIdx.y + threadIdx.y;
const int x = blockDim.x * blockIdx.x + threadIdx.x;
if( x >= outputWidth + xMin || y >= outputHeight + yMin || x < xMin || y < yMin)
return;
const T px = input[y * inputWidth + x];
output[(y-yMin) * outputWidth + (x-xMin)] = px;
cudaError_t cudaCrop( float4* input, const dim3& inputSize, float4* output, const dim3& outputSize, int xMin, int yMin )
if( !input || !output )
return cudaErrorInvalidDevicePointer;
if( inputSize.x == 0 || inputSize.y == 0 || inputSize.z == 0 || outputSize.x == 0 || outputSize.y == 0 || outputSize.z == 0 )
return cudaErrorInvalidValue;
//const int inputAlignedWidth = inputSize.z / sizeof(uint8_t); - we commented these out, what do they do?
//const int outputAlignedWidth = outputSize.z / sizeof(uint8_t);
// launch kernel
const dim3 blockDim(8, 8);
const dim3 gridDim(iDivUp(outputSize.x,blockDim.x), iDivUp(outputSize.y,blockDim.y));
gpuCrop<float4><<<gridDim, blockDim>>>(input, inputSize.x, output, outputSize.x, outputSize.y, xMin, yMin);
return CUDA(cudaGetLastError());
However, when we run this, we get an image where the silhouettes of certain items in the frame are vaguely recognizable but everything is bright yellow or white. I’m also not entirely sure that it’s actually doing the cropping. What am I doing wrong?
Thank you so much!
