Using the driver API (only), you cannot provide CUDA C++ device source code as input. You must first use nvcc
(or NVRTC) to compile the CUDA C++ device source code to PTX (or alternatively, CUBIN) format file. Therefore, if you look at a project like vectorAddDrv
, and study it carefully, you will observe that there is a compilation process for the .cu file that contains the CUDA C++ kernel definition, and that must be compiled with nvcc
(or NVRTC). The compilation step there creates a PTX file which the driver API can read directly. The second compilation process handles the .cpp file which includes actual driver API calls, and that particular compilation process can be done with the host compiler only (nvcc
is not required).
I was answering for this second process. When compiling the .cpp file that has for example your main
routine in it, and is calling driver API library routines, you can compile that using the host compiler. It only requires linking against cuda.lib
and it will require that you include the cuda.h
header file.
If you want to understand how to compile CUDA C++ device source code (e.g. CUDA C++ kernel code) to make it “ready” for consumption by the driver API, why not study a sample project like vectorAddDrv
and see how the settings are for the .cu
file (the kernel code) in that project?
The project settings are fairly simple. You will add the .cu file to the project as a file to be compiled by nvcc
, and you will designate that the compilation output be PTX (for example).
If you are asking how to start with a C++ console project that knows nothing about nvcc
, and add all the project customizations that are needed to use nvcc
properly as a primary compiler (so that, for example, you can compile a .cu file containing a kernel definition), I don’t have a recipe for you. Speaking for myself, personally, I would never attempt that. The integration work has been done for you already if you select the proper project type, and I don’t know of anywhere that NVIDIA documents all the integration needed to make VS and nvcc
work together. Furthermore, it is almost certainly specific to a particular version of VS and probably other factors (like CUDA version). Good luck!
(whenever I have done things for which the VS project structure stumps me, I usually revert to using command line compilation on windows. Also not formally documented by NVIDIA, so it requires trial and error, and inspection/study of console output from test cases constructed using the VS project structure.)
(Alternatively, NVRTC obviates the need for the nvcc
compilation step, but that goes outside of what is provided only by the driver API. Nevertheless, with NVRTC, it should be possible to handle everything with the host compiler, including compilation of CUDA C++ device source code.)
