Hey I’m having some trouble with cuda debugger api.(http://docs.nvidia.com/cuda/debugger-api/r_main.html#r_main). It works up to the point where it tries to run the kernel where it freezes. When it freezes in the main thread the event CUDBG_EVENT_INTERNAL_ERROR is added to the event queue with the error CUDBG_ERROR_INVALID_CONTEXT.
Is it possible that the error may be caused by the cuda kernel being launched in the same process as the debugger api?
What does an invalid context mean exactly?
Does it work on another machine?
Any help or ideas would be appreciated.
Code
#include <stdio.h>
#include <signal.h>
#include "cudadebugger.h"
#include "cuda_stdint.h"
#include <pthread.h>
#include <iostream>
CUDBGAPI cudbgAPI;
__global__ void helloWorld()
printf("Hi\n");
//this is required becuase if the program freezes you want
//to be able to exit without requiring a restart
void finalizeAndExit( int filler = 0)
printf("\nExiting Safely\n");
cudbgAPI->finalize();
exit(-1);
void cudbgError( CUDBGResult res )
if ( res != CUDBG_SUCCESS )
printf ( " \x1b[33m \nERROR: %s\n\n", cudbgGetErrorString ( res ));
finalizeAndExit();
void printEvent()
CUDBGEvent event;
CUDBGResult res;
for (res = cudbgAPI->getNextEvent( CUDBG_EVENT_QUEUE_TYPE_SYNC, &event);
res == CUDBG_SUCCESS && event.kind != CUDBG_EVENT_INVALID;
res = cudbgAPI->getNextEvent( CUDBG_EVENT_QUEUE_TYPE_SYNC, &event))
switch (event.kind)
case CUDBG_EVENT_INVALID:
printf("CUDBG_EVENT_INVALID\n");
break;
case CUDBG_EVENT_ELF_IMAGE_LOADED:
printf("CUDBG_EVENT_ELF_IMAGE_LOADED\n");
break;
case CUDBG_EVENT_KERNEL_READY:
printf("CUDBG_EVENT_KERNEL_READY\n");
break;
case CUDBG_EVENT_KERNEL_FINISHED:
printf("CUDBG_EVENT_KERNEL_FINISHED\n");
break;
case CUDBG_EVENT_INTERNAL_ERROR:
printf("CUDBG_EVENT_INTERNAL_ERROR %s\n", cudbgGetErrorString( event.cases.internalError.errorType ) );
break;
case CUDBG_EVENT_CTX_PUSH:
printf("CUDBG_EVENT_CTX_PUSH\n");
break;
case CUDBG_EVENT_CTX_POP:
printf("CUDBG_EVENT_CTX_POP\n");
break;
case CUDBG_EVENT_CTX_CREATE:
printf("CUDBG_EVENT_CTX_CREATE\n");
break;
case CUDBG_EVENT_CTX_DESTROY:
printf("CUDBG_EVENT_CTX_DESTROY\n");
break;
case CUDBG_EVENT_TIMEOUT:
printf("CUDBG_EVENT_TIMEOUT\n");
break;
case CUDBG_EVENT_ATTACH_COMPLETE:
printf("CUDBG_EVENT_ATTACH_COMPLETE\n");
break;
case CUDBG_EVENT_DETACH_COMPLETE:
printf("CUDBG_EVENT_DETACH_COMPLETE\n");
break;
case CUDBG_EVENT_ELF_IMAGE_UNLOADED:
printf("CUDBG_EVENT_ELF_IMAGE_UNLOADED\n");
break;
void *mannageEvent(void *null)
while( true ) {
printEvent();
int main(int argc, char const *argv[])
signal( SIGINT, finalizeAndExit );
//gets the api
uint32_t major,minor,rev;
cudbgGetAPIVersion ( &major, &minor, &rev );
cudbgGetAPI( major, minor, rev, &cudbgAPI );
cudbgError( cudbgAPI->initialize() );
//starts thread to print out events
pthread_t mannage_event_thread;
pthread_create( &mannage_event_thread, NULL, mannageEvent, NULL);
//Causes the program to freeze
helloWorld<<<2,2,2>>>();
//stop
finalizeAndExit();
return 0;
Console Output
CUDBG_EVENT_INTERNAL_ERROR CUDBG_ERROR_INVALID_CONTEXT
CUDBG_EVENT_TIMEOUT
What I would expect from the successful program is that this event would happen CUDBG_EVENT_ELF_IMAGE_LOADED followed by CUDBG_EVENT_KERNEL_READY (maybe some context pushes or pops)
