Assertion failure in cuda-gdb printing a variable gives 'cuda-gdb internal error'
I am debugging a program and I am getting errors from cuda-gdb.
The system is a dual c1060 running Fedora 10 and CUDA 2.3.
I have reduced the program to the smallest possible that still gives the error.
a debug session is like this
(cuda-gdb) b 37
Breakpoint 1 at 0x417d2e: file GDBug.cu, line 37.
(cuda-gdb) r
Starting program: /home/cuda/Mappa/GDBug
[Thread debugging using libthread_db enabled]
[New process 6013]
[New Thread 139998076090112 (LWP 6013)]
Warning: a GPU was made unavailable to the application due to debugging
constraints. This may change the application behaviour!
[Switching to Thread 139998076090112 (LWP 6013)]
[Current CUDA Thread <<<(0,0),(0,0,0)>>>]
Breakpoint 1, itera () at GDBug.cu:38
38 ranmar(m, SEED, x, NM);
Current language: auto; currently c++
(cuda-gdb) p m
Assertion failure at /home/buildmeister/build/sw/rel/gpu_drv/r190/r190_00/drivers/gpgpu/cuda/src/debugger/cudbgtarget.c, line 2278: cuda-gdb internal error
Aborted
Probably I am doing something wrong but cuda-gdb shouldn’t do that.
Thanks,
G
P.S.
The Upload keeps failing so I cannot attach the file I’ll paste it here…
#include <stdlib.h>
#include <cuda.h>
#include “cutil_inline.h”
#define NM 200
#define NT 512
#define NB 100
#define SEED 12345
global void itera();
int main(int argc,char **argv)
cudaSetDevice(0);
// Kernel invocation
itera<<<NB, NT>>>();
cutilSafeCall(cudaThreadSynchronize());
device void ranmar(int ij, int kl, double *rvec, int len);
//device double ta;
global void itera()
double x[NM];
int nt = blockDim.x; // How many Threads in Block
int i = threadIdx.x; // My thread
int b = blockIdx.x; // My block
int m=0;
// my index
m=b*nt+i;
int ivec;
double uni;
float u[98], cm;
int i97, j97;
cm = 16777213.0 / 16777216.0;
i97 = 97;
j97 = 33;
for (ivec=0; ivec<len; ivec++)
{ uni = u[i97] - u[j97];
rvec[ivec] = uni - cm;
Thank for submitting the bug. The next version of the CUDA tools, whose beta version will be available next month, fixes the issue.
Alban.
