C++ editor in VC is so weak, I like to use CDT to develop C++ apps.
It’s avalible to use CDT to develop cuda apps on windows.
Follow these step:
1.Of course,you need CDT ,Cygwin , Mingw installed on windows;
2.Install cuda toolkit,SDK compatible with you cuda driver(can view in nvidia panel);
3.VC compiler is esencial for nvcc on windows, you can install VS C++ Express edition
(note: the nvcc in CUDA 3.2 can only compatible with VC compiler 8/9,so it cant work with VS2010)
4.Set system environment. now added the path “…\NVIDIA GPU Computing SDK 3.2\shared\inc” and “…\NVIDIA GPU Computing SDK 3.2\C\common\inc” in CUDA_INC_PATH, add CUDA_LIB_PATH “…\Program\NVIDIA GPU Computing SDK 3.2\C\common\lib” and “…\Program\NVIDIA GPU Computing SDK 3.2\shared\lib”;
5.Open CDT, create new C++ project with the type MakeFile and toolchains Cygwin GCC;
6.Set project properties.In C++/C build–>Environment, add variable PATH , LIB, INCLUDE with following value:
PATH: ${CUDA_BIN_PATH};the dir of Cygwin\bin;the dir of MinGW\bin;the dir of \VC\bin;
LIB: ${CUDA_LIB_PATH};the dir of \VC\lib;the dir of Microsoft SDKs\Windows\v6.0A\Lib;
INCLUDE: ${CUDA_INC_PATH};the dir of \VC\include;
7.add *.cu file type into performence–>C/C+±->file type
8.Write a makefile in project. A simple example:
CXX = nvcc
app = cudatest.exe
obj = debug/cudatest.o
src = src/*.c*
traget=debug/$(app)
$(traget): $(obj)
$(CXX) $(src) -o $(src)
all: $(traget)
Ok, program in a *.cu file then build and run it.
Good luck, it’s effective in my CDT, the nvcc can compile the *.cu file.
