Hi there,
I am getting a conflict from apt when I am trying to upgrade and doing sudo apt --fix-broken install
does not fix it. I’ve tried reaching out to the Pop!_OS devs but they are telling me to sudo apt purge
the nvidia drivers but I can’t purge until I am get rid of the drivers. Is there a way to aviod this conflict from the NVIDIA side? Thanks in advance
(base) ➜ ~ sudo apt update && sudo apt upgrade -y
Hit:1 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64 InRelease
Hit:2 http://packages.microsoft.com/repos/code stable InRelease
Hit:3 https://packages.microsoft.com/repos/ms-teams stable InRelease
Hit:4 http://apt.pop-os.org/proprietary jammy InRelease
Hit:5 http://apt.pop-os.org/release jammy InRelease
Hit:6 http://apt.pop-os.org/ubuntu jammy InRelease
Get:8 http://apt.pop-os.org/ubuntu jammy-security InRelease [110 kB]
Get:9 http://apt.pop-os.org/ubuntu jammy-updates InRelease [114 kB]
Hit:7 https://packagecloud.io/slacktechnologies/slack/debian jessie InRelease
Get:10 http://apt.pop-os.org/ubuntu jammy-backports InRelease [99.8 kB]
Fetched 324 kB in 1s (257 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
28 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: https://packagecloud.io/slacktechnologies/slack/debian/dists/jessie/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
cuda-drivers : Depends: cuda-drivers-520 (= 520.61.05-1) but it is not installed
libnvidia-compute-495 : Depends: libnvidia-compute-515 but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
(base) ➜ ~ sudo apt --fix-broken install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libaccinj64-11.5 libcupti11.5 libnvidia-egl-wayland1 node-html5shiv nvidia-cuda-toolkit-doc
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
cuda-drivers-520 libgles2:i386 libnvidia-cfg1-520 libnvidia-extra-520 libnvidia-fbc1-520:i386 libnvidia-gl-520:i386
libopengl0:i386 nvidia-compute-utils-520 nvidia-dkms-520 nvidia-driver-520 nvidia-kernel-common-520
nvidia-kernel-source-520 nvidia-modprobe nvidia-settings nvidia-utils-520 xserver-xorg-video-nvidia-520
Recommended packages:
nvidia-prime libnvidia-compute-520:i386 libnvidia-decode-520:i386 libnvidia-encode-520:i386
The following packages will be REMOVED:
libcuinj64-11.5 libnvidia-cfg1-515 libnvidia-compute-495 libnvidia-extra-515 nvidia-dkms-515 nvidia-kernel-common-515
nvidia-kernel-source-515 nvidia-profiler nvidia-visual-profiler xserver-xorg-video-nvidia-515
The following NEW packages will be installed:
nvidia-kernel-source-520 nvidia-utils-520 xserver-xorg-video-nvidia-520
The following packages will be upgraded:
2 upgraded, 14 newly installed, 10 to remove and 26 not upgraded.
7 not fully installed or removed.
Need to get 0 B/110 MB of archives.
After this operation, 3,721 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 519429 files and directories currently installed.)
Preparing to unpack .../nvidia-compute-utils-520_520.61.05-0ubuntu1_amd64.deb ...
Unpacking nvidia-compute-utils-520 (520.61.05-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/nvidia-compute-utils-520_520.61.05-0ubuntu1_amd64.deb (--unpack):
trying to overwrite '/usr/bin/nvidia-powerd', which is also in package nvidia-kernel-common-515 515.65.01-1pop0~1663626642~22
.04~1f94f41
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
