I’m new with CUDA technology.
I’ve recently installed CUDA 3.0 on Linux OS machine.
Is there any command to know what CUDA driver and what CUDA SDK installed on my system?
I know the command “nvcc --version”
the answer I get is:
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2009 NVIDIA Corporation
Built on Mon_Oct_26_09:40:14_PDT_2009
Cuda compilation tools, release 3.0, V0.2.1221
What can I learn from that answer? Is it SDK’s version or driver?
also I run “devicequery”
And i get all my GPU’s details, here’s one paragraph of what I get:
Device 7: “Tesla T10 Processor”
CUDA Driver Version: 3.0
CUDA Runtime Version: 2.30
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 3
Total amount of global memory: 4294770688 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.30 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: No
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
