Sanjib1.nfo (4.5 MB)
Need help how to resolve this issue. I’ve read other forums and could not find a solution.
I’ve attached the system info.
Thanks in advance.
Thanks in advance.
The attached is a Windows XML file (xmllint shows properly formed). So I suspect that this needs to be moved to a new forum.
The Jetson series is a series of small embedded computers running almost entirely on Ubuntu Linux, and having their own GPU and special software for use with CUDA, so it is “sort of” related if you are trying to use CUDA with an NVIDIA GPU.
Are you trying to use a discrete NVIDIA GPU (on PCIe bus) with Windows? If so, then instead of posting for Jetsons, you probably need to post for this CUDA forum:
https://forums.developer.nvidia.com/c/accelerated-computing/cuda/206
If you can verify that, then probably a moderator will move the discussion there.
