"RuntimeError: CUDA error: all CUDA-capable devices are busy or unavailable" on Ubuntu 16.04
I am getting the following error from the sample code:
import torch
torch.zeros((2,2)).to(torch.device("cuda")
However I have 4 GPUs installed all with abundant memory and no running processes.
Thu Jan 23 23:50:29 2020
| NVIDIA-SMI 440.33.01    Driver Version: 440.33.01    CUDA Version: 10.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX TIT...  Off  | 00000000:05:00.0 Off |                  N/A |
| 26%   63C    P0    76W / 250W |      0MiB / 12212MiB |      0%      Default |
|   1  GeForce GTX 108...  Off  | 00000000:06:00.0 Off |                  N/A |
| 39%   51C    P0    58W / 250W |      0MiB / 11178MiB |      0%      Default |
|   2  GeForce GTX 108...  Off  | 00000000:09:00.0 Off |                  N/A |
| 37%   49C    P0    60W / 250W |      0MiB / 11178MiB |      0%      Default |
|   3  GeForce GTX 108...  Off  | 00000000:0A:00.0 Off |                  N/A |
| 23%   39C    P0    57W / 250W |      0MiB / 11178MiB |      3%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|  No running processes found                                                 |
Moreover all GPUs have compute mode set to Default. So its not a permissions issue.
System Details
Ubuntu 16.04
CUDA Version: 10.2
I get the same issue when compiling C code with nvcc and running something as simple as cudaalloc.
My code does detect GPUs. For example the following code:
#include <stdio.h>
#include <cuda_runtime_api.h>
#include <cuda.h>
int main() {
  int nDevices;
  cudaGetDeviceCount(&nDevices);
  for (int i = 0; i < nDevices; i++) {
    cudaDeviceProp prop;
    cudaGetDeviceProperties(&prop, i);
    printf("Device Number: %d\n", i);
    printf("  Device name: %s\n", prop.name);
    printf("  Memory Clock Rate (KHz): %d\n",
           prop.memoryClockRate);
    printf("  Memory Bus Width (bits): %d\n",
           prop.memoryBusWidth);
    printf("  Peak Memory Bandwidth (GB/s): %f\n\n",
           2.0*prop.memoryClockRate*(prop.memoryBusWidth/8)/1.0e6);
Prints out:
Device Number: 0
  Device name: GeForce GTX 1080 Ti
  Memory Clock Rate (KHz): 5505000
  Memory Bus Width (bits): 352
  Peak Memory Bandwidth (GB/s): 484.440000
Device Number: 1
Device Number: 2
Device Number: 3
  Device name: GeForce GTX TITAN X
  Memory Clock Rate (KHz): 3505000
  Memory Bus Width (bits): 384
  Peak Memory Bandwidth (GB/s): 336.480000
Interesting enough when I run
nvidia-smi -r
I get the error
GPU Reset couldn't run because GPU 00000000:05:00.0 is the primary GPU.
. But if I try to reset any of the remaining 3 GPUs I do not get this error. I tried disabling this GPU and running the code with the remaking GPUs to no luck. Could this be a hardware installation issue? I tried rebooting my machine which did not help either.
